Karu 6th Gear November 8, 2013 Share November 8, 2013 Interesting comparison. Surprisingly, Golf is the cheapest base on this Article. Is it the same DSG gearbox as the old model? If so, then have to steer clear of the German... http://www.sgcarmart.com/news/review.php?AID=618 ↡ Advertisement Link to post Share on other sites More sharing options...
13177 Supersonic November 8, 2013 Share November 8, 2013 Between these 3 cars, i would pick either aurius or i30. Link to post Share on other sites More sharing options...
Glyuen 3rd Gear November 8, 2013 Share November 8, 2013 Golf is the best in every aspect but I'll avoid it for the DSG alone. Auris is actually very good. The drive and handling is much better than vios/altis etc. However no match for Golf. i30 is for space. Do check out OMV as well. If i'm not wrong, Auris has the highest OMV. Link to post Share on other sites More sharing options...
Karu 6th Gear November 8, 2013 Author Share November 8, 2013 Golf is the best in every aspect but I'll avoid it for the DSG alone. Auris is actually very good. The drive and handling is much better than vios/altis etc. However no match for Golf. i30 is for space. Do check out OMV as well. If i'm not wrong, Auris has the highest OMV. Should indent manual Golf... Possible? Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 8, 2013 Share November 8, 2013 (edited) The letdown of Golf is DSG, the letdown of Auris is CVT. If use gun to point at me, I choose Auris (CVT over DSG). Edited November 8, 2013 by Kangadrool Link to post Share on other sites More sharing options...
13177 Supersonic November 8, 2013 Share November 8, 2013 The letdown of Golf is DSG, the letdown of Auris is CVT. If use gun to point at me, I choose Auris (CVT over DSG). Always heard people also try to avoid CVT, wonder what's the reason? Link to post Share on other sites More sharing options...
Vega Turbocharged November 8, 2013 Share November 8, 2013 Is the current golf 7 still plague by DSG problem? Link to post Share on other sites More sharing options...
Coltplussport Turbocharged November 8, 2013 Share November 8, 2013 A check with sg carmart found out that Aurius is made in UK, and the kerb weight for the car is 1355kg!!! Incredible for a jap car. Link to post Share on other sites More sharing options...
Datsun366 Turbocharged November 8, 2013 Share November 8, 2013 Too tiny for me. Auris look good, feel hood, drive good. For small buggers. Have to go with Golf stick. Kimchi gives me gas, not socially appropriate... 1 Link to post Share on other sites More sharing options...
Tohto Hypersonic November 8, 2013 Share November 8, 2013 A check with sg carmart found out that Aurius is made in UK, and the kerb weight for the car is 1355kg!!! Incredible for a jap car. Because it is made in conti, so it must weight like a conti mah Link to post Share on other sites More sharing options...
Baal Supersonic November 8, 2013 Share November 8, 2013 Always heard people also try to avoid CVT, wonder what's the reason? My Mech told me that CVT is not as durable as AT, just like AT is not as durable as MT. Some reasons that gave it a bad rep will be using ATF instead of CVTF, causing premature breakdown. Less tolerance for added stress. My mech told me for 1 of his cust, he change his rim from the stock 14 inch to 17inch. (Fit 1.3) Had to overhaul at the 60k mark. Some pefer the revvy feel of gears......feel the engine characteristics, rather than the flat feel of CVT. But accd to wiki, it said that most CVTs would out accelerate an AT based on the same car/capacity. just that due to the linear power delivery it "feels" slower. An excolleague who drove a Vios 1.5 4AT & then a Fit 1.3 CVT, said that the Vios felt revier/racier but the Fit felt more torquey. CVT always adjust the vitual ratios such that u get the best mix of perf & economy. But the trade off is more fragile. Needs for Tender Loving Care (TLC). Link to post Share on other sites More sharing options...
Knoobie Supercharged November 8, 2013 Share November 8, 2013 me friend bought golf and hearsay the DSG is different already. Agent say no more problem. no sure true or not. Link to post Share on other sites More sharing options...
Baal Supersonic November 8, 2013 Share November 8, 2013 Perhaps no problem by the 7DSG standards ? I recalled reading that DSG in general not as suitable for stop go traffic. This is because, for AT, if u break while in D mode, no issue, even long term basis. But on DSG or automated manual systems, it will cause accerlerated wear of the clutch plate. And u keep changing D & N & D & N......be it DSG or AT, it will wear more quickly. Link to post Share on other sites More sharing options...
Coltplussport Turbocharged November 8, 2013 Share November 8, 2013 (edited) Because it is made in conti, so it must weight like a conti mah The PI also have aurius from japan, 1.5 weighing in at 1270kg. Wonder why it is so much heavier? More conti feel? maybe? me friend bought golf and hearsay the DSG is different already. Agent say no more problem. no sure true or not. If I'm the agent, i also 拍胸脯guarantee no problem. Edited November 8, 2013 by Coltplussport Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 8, 2013 Share November 8, 2013 A check with sg carmart found out that Aurius is made in UK, and the kerb weight for the car is 1355kg!!! Incredible for a jap car. As heavy as similar conti hatchback with diesel engine. Link to post Share on other sites More sharing options...
Knoobie Supercharged November 8, 2013 Share November 8, 2013 The PI also have aurius from japan, 1.5 weighing in at 1270kg. Wonder why it is so much heavier? More conti feel? maybe? If I'm the agent, i also 拍胸脯guarantee no problem. lol we can only wait and see lor. hopefully problem fix lah.. VW not that bad of a brand.. its a pity to see they are plague with the GB problem.. Link to post Share on other sites More sharing options...
Limpeh23 2nd Gear November 8, 2013 Share November 8, 2013 The auris comes with '7 speed' cvt and also paddle shifters, plus dual zone aircon etc. The handling is surprisingly good and the acceleration feels faster than its quoted time. i30 is very spacious and well built, almost like a continental car. However, the golf is probably still the best all round package among the 3, although the DSG is a potential stumbling block. Link to post Share on other sites More sharing options...
Coltplussport Turbocharged November 8, 2013 Share November 8, 2013 As heavy as similar conti hatchback with diesel engine. To illustrate Toyota Yaris 1.5 weighs 1075kg Toyota Wish 1.8 weighs 1370kg The Aurius is only 15kg lighter, but it is much smaller than a Wish. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota GR Corolla
2027 Volkswagen Golf previewed
VW Golf R 333 Special Edition Will Get a Rad Akrapovič Exhaust
MK8 Golf GTI Clubsport vs 2022 Audi A5 195kw quattro sline
VW Golf 9 In Doubt Due To Rising Costs With Development Of ICE Cars
VW Golf 2017
VW Golf 2017
VW Golf Owners
VW Golf Owners
[FB Live] Get Exclusive Prices Across The Entire Volkswagen Range On Our Facebook LIVE featuring Julian and Idris!
