Baal Supersonic November 30, 2013 Share November 30, 2013 China contractor using china sub-con who uses china workers and made in china materials? Such combination is getting more and more common. Result of excessive relian ce of chip foreign labour n add a dose of karma. ↡ Advertisement Link to post Share on other sites More sharing options...
Camrysfa Turbocharged November 30, 2013 Share November 30, 2013 Are they going to close for 1 to 2 weeks to inspect all the glasses? C'mon give the owners a break. the word CLOSE is not what they envision......sure they want JEM to be close to everything, but not closed for 3rd time in 6 months. Link to post Share on other sites More sharing options...
Cindytan 3rd Gear November 30, 2013 Share November 30, 2013 Someone sing so horribly and cause the glass to break isit Link to post Share on other sites More sharing options...
Chiawy 1st Gear December 2, 2013 Share December 2, 2013 (edited) Does not seems right for the glass, glass should be metal too right? So should still left earth element... hmmm... earth... cave-in? Edited December 2, 2013 by Chiawy Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 2, 2013 Share December 2, 2013 Does not seems right for the glass, glass should be metal too right? So should still left earth element... hmmm... earth... cave-in? Glass is made from sand. Link to post Share on other sites More sharing options...
Neost 6th Gear December 2, 2013 Share December 2, 2013 Result of excessive relian ce of chip foreign labour n add a dose of karma. Foreign labour is not cheap nowadays. And also, these are the types of jobs that local sian far far. Link to post Share on other sites More sharing options...
Knoobie Supercharged December 2, 2013 Share December 2, 2013 I can't believe when I saw comments about haunting and suay-ness. I mean these things can be explained. Installing the glass panel takes skill. Dan there's the other things like car catching fire. This is car owner's issue. Water pipe leakage is not easy to detect. And water with pressure is quite destructive even with low pressure. Small tiny gap or hole it will quickly grow into a big one. This is not the 19th century when ppl are uneducated and superstitious. Why they are superstitious is becoz they can't find an explanation. These are all link to the negligence of of the contractors and car owner. Like that also blame it on the ghost? How ridiculous does it sounds? Well, I guess the unexplainable here is why all these things happened to JEM whereas we're not seeing it happening to shopping malls that have been around for very long time. Still suay I will say. 1 Link to post Share on other sites More sharing options...
Berncsp76 6th Gear December 2, 2013 Share December 2, 2013 (edited) no leh, glass=sand=earth ? http://www.ask.com/question/where-does-glass-come-from Does not seems right for the glass, glass should be metal too right? So should still left earth element... hmmm... earth... cave-in? Edited December 2, 2013 by Berncsp76 1 Link to post Share on other sites More sharing options...
Little_prince Supersonic December 2, 2013 Share December 2, 2013 Does not seems right for the glass, glass should be metal too right? So should still left earth element... hmmm... earth... cave-in? glass is earth. silica mah 1 Link to post Share on other sites More sharing options...
2BDriver Hypersonic December 2, 2013 Share December 2, 2013 名付其实的。。。“ 麦卡佛任风水大师 ” 1 Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic December 3, 2013 Share December 3, 2013 Still got one, 'Wood' .... I think they better hold a sale on 'coffin' .... Link to post Share on other sites More sharing options...
Yrvsport 2nd Gear December 3, 2013 Share December 3, 2013 Should change the name from "JEM" to "GEMS".......if not the owner have to flower bath the whole building with "REDS FLOWERS" 1 Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged December 3, 2013 Share December 3, 2013 * sitting down in my cosy sofa, popcorn in hand, anxiously waiting * You had better wear a safety helmet and a rain coat...later ceiling drop on you This building completed too fast liao...I attribute all faults to poor workmanship 2 Link to post Share on other sites More sharing options...
Kangadrool Supersonic December 3, 2013 Share December 3, 2013 Pray hard no quake or haiyan. Link to post Share on other sites More sharing options...
Little_prince Supersonic December 3, 2013 Share December 3, 2013 sibei jialat shopping centre.... parking problematic too Link to post Share on other sites More sharing options...
Nightkids 6th Gear December 3, 2013 Share December 3, 2013 sibei jialat shopping centre.... parking problematic too wat is so interesting inside? all the shops i assume JP, IMM all have..... Link to post Share on other sites More sharing options...
Little_prince Supersonic December 3, 2013 Share December 3, 2013 wat is so interesting inside? all the shops i assume JP, IMM all have..... you didn't miss anything much. Link to post Share on other sites More sharing options...
Nightkids 6th Gear December 3, 2013 Share December 3, 2013 you didn't miss anything much. i find locals very the ' new toilet ' mentality, in cantonese we called it ' 新屎坑 '.....england call wat sheep don-know-wat syndrome..... new thing ppl all chiong.....after a while the heat die out nobody go..... but that stupiak dangerous mall so happening still so many ppl go....don scare die.... ↡ Advertisement Link to post Share on other sites More sharing options...
Digital Door Lock
Digital Door Lock
New Age Polish --> Volkswagen Portfolio
New Age Polish --> Hyundai Portfolio
Hdb main door
Hdb main door
products to remove tree gum on paint & glass
Aluminium Doors Contractor
Double sided tape for door visor
