Leggt Clutched January 28, 2014 Share January 28, 2014 Hi there, you can drive over for us to check. Need not make appointment. Look for Superman Hi. So you do maintain SAAB cars? Link to post Share on other sites More sharing options...
DMSG 3rd Gear January 28, 2014 Author Share January 28, 2014 Hi Sir, Yes we do, you might wanna reach us at 6363 5112 to find out more. Cheers Thanks for your interests with DM Hi. So you do maintain SAAB cars? Link to post Share on other sites More sharing options...
Keithchue 5th Gear February 12, 2014 Share February 12, 2014 HI Dynamics Mechanics team, I have a 14 month old VW Jetta. with irritating creaking noise from the steering column when the steering is in operation. been in VW 6time without any resolution. creaking occurs when the steering wheel is turned, no matter if vehicle is stationery or moving. they have mentioned that the slip ring is the cause of the noise and they have replace the ring 5 times. each replacement will last 2-4 weeks before the noise is back. front suspension mounts are also replaced as well in view of the noise. no airbag warning light is present. car performs the way it should be over humps and bumps. car is still in VW as of today. seems like VW is incapable of resolving the issue. please help, TIA Link to post Share on other sites More sharing options...
DMSG 3rd Gear February 13, 2014 Author Share February 13, 2014 Hi Sir Keith, please dropby DM for a free check on your noise issues. We do have specialist to eliminate noise problems and it does require patience, experience and experts to 'fish' out the faulty worn parts. It might take a while. It might be from your steering rack, underarms or linkage as well. Please dropby DM and seek assistance from our Manager Superman. Cheers! HI Dynamics Mechanics team, I have a 14 month old VW Jetta. with irritating creaking noise from the steering column when the steering is in operation. been in VW 6time without any resolution. creaking occurs when the steering wheel is turned, no matter if vehicle is stationery or moving. they have mentioned that the slip ring is the cause of the noise and they have replace the ring 5 times. each replacement will last 2-4 weeks before the noise is back. front suspension mounts are also replaced as well in view of the noise. no airbag warning light is present. car performs the way it should be over humps and bumps. car is still in VW as of today. seems like VW is incapable of resolving the issue. please help, TIA 1 Link to post Share on other sites More sharing options...
Tonydeath 4th Gear February 22, 2014 Share February 22, 2014 I'm driving a Subaru Forester 2.5XT, SH9. Steering wheel keeps turning slightly anti-clockwise when driving (when I'm not holding on to it). When braking, it turns strongly anti-clockwise. Kindly advise. I also have this problem can I come on Monday? Link to post Share on other sites More sharing options...
DMSG 3rd Gear February 23, 2014 Author Share February 23, 2014 (edited) I also have this problem can I come on Monday? Sure Sir, please make a trip down to DM and we will check it out for you! Thank you for your interest. Have a nice Day! Cheers! Edited February 23, 2014 by DMSG Link to post Share on other sites More sharing options...
Tonydeath 4th Gear February 23, 2014 Share February 23, 2014 Sure Sir, please make a trip down to DM and we will check it out for you! Thank you for your interest. Have a nice Day! Cheers! Great Link to post Share on other sites More sharing options...
DMSG 3rd Gear February 23, 2014 Author Share February 23, 2014 Great Sir, See you soon! Link to post Share on other sites More sharing options...
EXO 4th Gear February 28, 2014 Share February 28, 2014 Sometimes after braking and lifting off the brake pedal, the screeching sound persists for quite a distance if I'm traveling at slow speed. If I travel at higher speed, the sound will go off. Through visual inspection, I can see that my brake pads still have ample life in them. I also noticed that the screeching sound comes from the rear left wheel. Any idea what problem could this be? Thanks :) Link to post Share on other sites More sharing options...
DMSG 3rd Gear March 2, 2014 Author Share March 2, 2014 Hi Sir, Thanks for taking your time to seek technical advice from us. Few possibilities for your noise problem faced :- 1> Uneven wearing of your brake pads. 2> Inner Pads worn but you can't determine as it's hidden behind (per rotor disc has two pads clamming on it, see picture below) 3> Some unwanted stone particles or debris caught onto your pads and causing abrasion between the disc surfaces and your pads 4> Disc Wrap 5> Disc Worn and due for change 6> Louse Fitments of any brake mechanism Sir, for eliminating and a proper diagnostics, please dropby DM for a check to be safe. Brakes are the most important mechanism any ride. Our Checks are Free. Please dial 6363 5112 or just drive through and our friendly mechanics will be there for you! Thanks for your seeking info here and hope to see you and solve your problems too. Sometimes after braking and lifting off the brake pedal, the screeching sound persists for quite a distance if I'm traveling at slow speed. If I travel at higher speed, the sound will go off. Through visual inspection, I can see that my brake pads still have ample life in them. I also noticed that the screeching sound comes from the rear left wheel. Any idea what problem could this be? Thanks :) Link to post Share on other sites More sharing options...
DMSG 3rd Gear March 2, 2014 Author Share March 2, 2014 'Best Service and Repair Award' among 1100 over workshops 'Best Safety and handling Award' 'Best Promising New Establishment Award' We always wanna be the BEST for you! Link to post Share on other sites More sharing options...
Mnbvcxz Neutral Newbie March 14, 2014 Share March 14, 2014 PLEASE feel free to post any of your car related problems, we will be able to give advises and also free diagnostics works for your vehicle woes. You might want to create a new posting under this thread for your queries. DYNAMICS MECHANIC - THE BOUTIQUE GARAGE 184 WOODLANDS INDUSTRIAL PARK E5 #01-03/04 SINGAPORE 757514 HOTLINE : 6363 5112 This morning, my wife informed that she heard a strange noise and vibrations coming out the engine of our 8yr old nissan latio. She mentioned it sounded like those of diesel engine. With these symptoms, what are the possible cause? Thanks. Link to post Share on other sites More sharing options...
DMSG 3rd Gear March 16, 2014 Author Share March 16, 2014 This morning, my wife informed that she heard a strange noise and vibrations coming out the engine of our 8yr old nissan latio. She mentioned it sounded like those of diesel engine. With these symptoms, what are the possible cause? Thanks. Hi Sir, Few possibilities here :- 1> Bad Spark Plugs 2> Faulty Ignition coils 3> Worn Belts 4> Bad Engine Mounts Any over heat symptoms or warning lights ? And slip in gearing? Do keep us updated Sir, you might wanna drive your ride over for a free detail check by our mechanic. Feel free to contact us at 6363 5112. Cheers and if the car is not safe to drive, please don't drive it. Link to post Share on other sites More sharing options...
DMSG 3rd Gear March 18, 2014 Author Share March 18, 2014 Want to better your Fuel Efficiency ? THEN go for our Nano Treatment from Blue Chem Germany. Sure increase engine performance and also extra millage with increased fuel efficiency with extra 30-50km per full tank . BLUECHEM TECHNOLOGY FROM GERMANY - Used by Most CarMake Agents for engine protection and reconditioning in Europe http://www.youtube.com/watch?gl=SG&hl=en-GB&v=MJ_CFwXvV4U "Products made in Germany are not only domestically but also internationally perceived very positively, because they stand for high quality, functionality and reliability. This applies particularly to products for the automotive industry." BEST engine protection and reviving your ride to new car performance with Nano protection at it's max. A technology car agent used secretly to enhance and prolong engine damage. SOMETHING we bring in to give you the BEST again. Hot Selling Conditioner in Dynamics Mechanic. WHY BLUE CHEM ? Because we need to protect our engines for my cars to last longer (No choice, we will need to hold on to our Cars Now at such situations, so reconditioning to protect is a measure to counter major break down) FULL TREATment 3 IN 1 at only $138 (usual $188) PARTIAL TREATMENT 2 IN 1 at only $88 (usual $108) Check us and like us at : - www.facebook.com/dynamicsmechanic Link to post Share on other sites More sharing options...
Snokey 1st Gear March 18, 2014 Share March 18, 2014 hi, i'm driving a Mazda 2 and when i move off from my parking lot and turn the steering wheel, i can hear a "guud guud" or a "tiak tiak" sound, like the steering not very smooth like that. i just did my 30km servicing and the workshop didn't find any issues with the steering. there's no such sound when i'm driving on the road though. what could be the possible causes please? i'm due for a change of my tyres as well, will changing the tyres help? thanks Link to post Share on other sites More sharing options...
DMSG 3rd Gear March 18, 2014 Author Share March 18, 2014 hi, i'm driving a Mazda 2 and when i move off from my parking lot and turn the steering wheel, i can hear a "guud guud" or a "tiak tiak" sound, like the steering not very smooth like that. i just did my 30km servicing and the workshop didn't find any issues with the steering. there's no such sound when i'm driving on the road though. what could be the possible causes please? i'm due for a change of my tyres as well, will changing the tyres help? thanks Hi Sir, Few possibilities as follow :- 1> Steering Rack worn 2> Tie Rod Worn 3> Steering Shaft Faulty 4> Tie Rod Linkage faulty or worn Sir, please drive to our garage for a free check and if need any replacement, we will quote you accordingly and then you decide whether to proceed with the repair or not. Dynamics Mechanic Garage has always been reputable for good customer service and friendly Mechanics, so dropby and let us help to solve your problem. Cheers! Link to post Share on other sites More sharing options...
DMSG 3rd Gear March 18, 2014 Author Share March 18, 2014 Link to post Share on other sites More sharing options...
DMSG 3rd Gear March 20, 2014 Author Share March 20, 2014 " Best Servicing & Repair" Award among 1100 over workshops in Singapore " Best Handling and Safety" Award for safety performance products (Force Big Brake Kit, TUNED coilovers) " Best New Promising Establishment" Award by Sgcarmart (number 1 online automotive online portal) http://youtu.be/Gh3tmzElgOI Link to post Share on other sites More sharing options...
Help with STA report remarks
HELP! Upstairs neighbour causing sleepness nights
Exporting Gmail Contacts (Pls help)
