Xers007 Supercharged July 2, 2014 Share July 2, 2014 bought a power bank, but the inputs and output is an issue for me, I want to ask anyone out there how to over come it. The power bank comes with USB heads, but the car camera is with cigarette lighter adapter. how do i get a male cigarette lighter head to a USB input to the power bank and also a USB output head to a female cigarette lighter adapter? Anyone can advice? u need this type of cable... google "3.5mm x 1.35mm to usb"... sim lim sure have... ↡ Advertisement Link to post Share on other sites More sharing options...
Columbian78 6th Gear July 2, 2014 Share July 2, 2014 I am not against using power banks with Li-base secondary cells in the car. I just want to point out that such cells have higher risk of fire due to their inherent chemical properties compared to batteries of other chemistry like lead acid. Just make sure you are aware of the risks and accept it. The more cells and higher capacity you have, the higher the risk. Famous examples are Boeing 787 dreamliner and Tesla electric cars. These are highly sophisticated systems that have comprehensive built-in protection systems to mitigate the risks when mishap occurs. I started a thread sometime ago to discuss the fire hazard of Li batteries. http://www.mycarforum.com/topic/2688631-lithium-battery-fire-hazards-in-our-cars/?do=findComment&comment=4853182 You can mitigate the risk by ensuring the usage of good quality products from reputable brands. Avoid cheap products from no-name brands. At the cell level, check for safety certification like UL1642. I currently use Itronics ITB-100sp and Vicovation tf2+ in my car which do not have built-in Lithium battery. I am not against using Li batteries or power banks employing them. I am for using them safely and using safer alternatives if possible. 3 Link to post Share on other sites More sharing options...
Ahgong Supercharged July 2, 2014 Share July 2, 2014 bought a power bank, but the inputs and output is an issue for me, I want to ask anyone out there how to over come it. The power bank comes with USB heads, but the car camera is with cigarette lighter adapter. how do i get a male cigarette lighter head to a USB input to the power bank and also a USB output head to a female cigarette lighter adapter? Anyone can advice? splice the wire and make your own with USB connector parts? you can find a whole list of DIY sites that teaches you how to do it. Link to post Share on other sites More sharing options...
jirotan Neutral Newbie July 3, 2014 Share July 3, 2014 Thanks TVT, Xers007 & ahgong for your sharing... will explore the options. Most car cam comes with both a USB cable and a 12V socket head (cigarette adapter). Yours don't have the USD cable ? Mine, only came with 12V socket. didn't have USB. :( Link to post Share on other sites More sharing options...
TVT Supercharged July 3, 2014 Share July 3, 2014 Thanks TVT, Xers007 & ahgong for your sharing... will explore the options. Mine, only came with 12V socket. didn't have USB. :( Does your camera set has a USB socket ? If have can buy a USB cable (both sides USB) and plug in.... Anyway there's sure to be some kind of adapter to solve this issue. A visit to a electrical or auto accessory should be able to find it. Good luck. Link to post Share on other sites More sharing options...
jirotan Neutral Newbie July 4, 2014 Share July 4, 2014 Does your camera set has a USB socket ? If have can buy a USB cable (both sides USB) and plug in.... Anyway there's sure to be some kind of adapter to solve this issue. A visit to a electrical or auto accessory should be able to find it. Good luck. Thanks Bro... will continue to search around for the right solution :) Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear July 5, 2014 Share July 5, 2014 Just got a 10000mah xiao mi power bank.. gg to try on the camera... Link to post Share on other sites More sharing options...
Jenius81 1st Gear January 29, 2015 Share January 29, 2015 Just got a 10000mah xiao mi power bank.. gg to try on the camera... any one tried using xm power bank to power DVR in car? Link to post Share on other sites More sharing options...
quantumtron Neutral Newbie February 20, 2015 Share February 20, 2015 using it is a good idea, dont drain your car battery Link to post Share on other sites More sharing options...
Sgspurs 1st Gear February 20, 2015 Share February 20, 2015 using it is a good idea, dont drain your car battery How's does it work ? Any picture? Link to post Share on other sites More sharing options...
Azzurro 1st Gear February 20, 2015 Share February 20, 2015 Make sure the powerbank is not exposed under sun light as I think it is dangerous. Anyway personally I will not do this trick. Link to post Share on other sites More sharing options...
Johnnylim 5th Gear February 20, 2015 Share February 20, 2015 How's does it work ? Any picture? U serious? Just plug the cable into powerbank from the car cam Link to post Share on other sites More sharing options...
Sgspurs 1st Gear February 21, 2015 Share February 21, 2015 Lol...seriously. .was actually want to see pictures if any one has managed to hide the wires.... U serious? Just plug the cable into powerbank from the car cam Link to post Share on other sites More sharing options...
abcedcch 1st Gear February 21, 2015 Share February 21, 2015 I used xiaomi 16000mah for the cam after car parked. Can last roughly 3 to 4 days. I find it troublesome as the port batt cant gain much charging during driving as only drive about 1-1.5hr per day. Infact 16000mah is rated for 3.7v. If based on 5v which is the car cam, the actual cap is only about 10000mah. Say the cam is 1A at 5v=5watts of power needed. 10000mah=10Ah Batt cap =10Ah x 5V=50Wh. 50Wh/5watts=10hrs only. At best the batt can last one overnight. Link to post Share on other sites More sharing options...
Zippaboy 4th Gear February 21, 2015 Share February 21, 2015 previouusly i am using a secondary motorcycle battery in my boot. Yuasa YTX14 working great !!! now i change to those deep cycle battery i bought from Sim lim tower. even better. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 22, 2015 Share February 22, 2015 previouusly i am using a secondary motorcycle battery in my boot. Yuasa YTX14 working great !!! now i change to those deep cycle battery i bought from Sim lim tower. even better. Yr deep cycle battery will last longer in between charging if you us a deep cycle battery charger as conventional battery charger may no be able to fully charge the battery. Link to post Share on other sites More sharing options...
TVT Supercharged February 23, 2015 Share February 23, 2015 now i change to those deep cycle battery i bought from Sim lim tower. even better. Where you place your deep cycle battery? Link to post Share on other sites More sharing options...
Cllee 2nd Gear April 8, 2015 Share April 8, 2015 I used xiaomi 16000mah for the cam after car parked. Can last roughly 3 to 4 days. I find it troublesome as the port batt cant gain much charging during driving as only drive about 1-1.5hr per day. Infact 16000mah is rated for 3.7v. If based on 5v which is the car cam, the actual cap is only about 10000mah. Say the cam is 1A at 5v=5watts of power needed. 10000mah=10Ah Batt cap =10Ah x 5V=50Wh. 50Wh/5watts=10hrs only. At best the batt can last one overnight. Hi, need to ask electrical shifu here if i connect 1st power bank to 2nd power bank then connect the car camera to 2nd power bank, will the 2 power banks able to last two times longer than if only 1 power bank is used? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
My EV journey to the i4
Marbella DashCam Users
Car camera recommendation
Request for dark mode
The Electric Vehicle Charging Problem
