Chuapcd 1st Gear January 25, 2014 Share January 25, 2014 Hi: Anyone know how much to replace the Mazda 5 (2007) head lamp hi beam bulb? Where to replace ? Just sent for inspection and it was not working. Thanks in advance ! ↡ Advertisement Link to post Share on other sites More sharing options...
Simpleonly 5th Gear January 25, 2014 Share January 25, 2014 Just the bulb ? Not the whole lamp right? Then any WS also can fix.. Just cost ard $10... Else buy from stockist n Diy lor, just open the cover n change only Mah.. Just make sure u dun touch the bulb (glass part) with your finger. Less then 5 Min job Link to post Share on other sites More sharing options...
Chuapcd 1st Gear January 27, 2014 Author Share January 27, 2014 Just the bulb ? Not the whole lamp right? Then any WS also can fix.. Just cost ard $10... Else buy from stockist n Diy lor, just open the cover n change only Mah.. Just make sure u dun touch the bulb (glass part) with your finger. Less then 5 Min job thanks for the advice.....Went to do my servicing and get Mazda to change for me....they said $40-50..... Anyway, I have been told that my starter motor is having problem and need to change...cost me $1000..is it too high? The problem is sometimes I need to start my engine the 2nd time before it gets starter. Is there other alternatives that I can go? $1000 seem too expensive....... Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 28, 2014 Share January 28, 2014 thanks for the advice.....Went to do my servicing and get Mazda to change for me....they said $40-50..... Anyway, I have been told that my starter motor is having problem and need to change...cost me $1000..is it too high? The problem is sometimes I need to start my engine the 2nd time before it gets starter. Is there other alternatives that I can go? $1000 seem too expensive....... dont get carrot. it could be your battery that is the problem. but they tell you otherwise starter going to spoil. get your battery check first before doing any further conclusion. Link to post Share on other sites More sharing options...
Notsogoodman 4th Gear February 7, 2014 Share February 7, 2014 thanks for the advice.....Went to do my servicing and get Mazda to change for me....they said $40-50..... Anyway, I have been told that my starter motor is having problem and need to change...cost me $1000..is it too high? The problem is sometimes I need to start my engine the 2nd time before it gets starter. Is there other alternatives that I can go? $1000 seem too expensive....... If your warranty is over, do your repairs outside... I had a starter motor issue on my Mazda 6 2yrs back & was prepared to spend $500 to replace it (my friend spent that amt on his 6)... Surprisingly, the workshop managed to repair the starter motor for $180... I don't suppose Mazda 5 & 6's motor will differ that much Link to post Share on other sites More sharing options...
Chuapcd 1st Gear February 9, 2014 Author Share February 9, 2014 Hi...Can you let me know the name and place of the workshop that repaired for you? Thanks in advance. Link to post Share on other sites More sharing options...
Notsogoodman 4th Gear February 9, 2014 Share February 9, 2014 (edited) Hi...Can you let me know the name and place of the workshop that repaired for you? Thanks in advance.Lion City Electric (at Alexandre Village), Tel: 62702713try to call & talk to Ms Yeo before going over. NOTE THAT they are electrical experts (batteries, starter motor, windows etc).... Edited February 9, 2014 by Notsogoodman ↡ Advertisement Link to post Share on other sites More sharing options...
MAZDA 6
MAZDA 6
2019 All new Mazda 3
The Rotary-Electric Mazda Iconic SP Concept Could Save the Sports Car
2022 Mazda CX-60
2022 Mazda CX-60
Mazda Rx8 owners..pls come in
120k servicing at Ubi Mazda...BM model....
