SGCMmadman 6th Gear March 6, 2014 Share March 6, 2014 Reached home n wen switched off lights, a/c, radio den engine, realised brake light n rear taillights still on n cant be switched off. Plsssss advice wat to do coz if lights remain on whole nite, battery sure flat. Car is hyundai verna 06 auto. Thks ↡ Advertisement Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged March 6, 2014 Share March 6, 2014 Remove battery or remove fuse. Check manual for the correct one. My friend Hyundai once had this problem also. Battery drained overnight. Quick fix for $50 or so. Link to post Share on other sites More sharing options...
TVT Supercharged March 6, 2014 Share March 6, 2014 Or remove the bulbs first....but beware it could be hot! Wear gloves. Link to post Share on other sites More sharing options...
SGCMmadman 6th Gear March 6, 2014 Author Share March 6, 2014 Was advised to disconnect negative connector to battery n tat worked. Morning will drive to workshop. Hope no problem wen connect back n hope car can start. Thks Link to post Share on other sites More sharing options...
Mgmgphyo 1st Gear March 6, 2014 Share March 6, 2014 Happened to my old car before.rubber Washer between peddle and switch worn out.I just used drinking water cap to fill the gap. Link to post Share on other sites More sharing options...
Kb27 Supersonic March 6, 2014 Share March 6, 2014 (edited) Reached home n wen switched off lights, a/c, radio den engine, realised brake light n rear taillights still on n cant be switched off. Plsssss advice wat to do coz if lights remain on whole nite, battery sure flat. Car is hyundai verna 06 auto. Thks Usually, the plastic pressing the brake switch is broken. When it can't press the brake switch, the brake light is always on. Look for the brake switch. You would see a missing plastic piece. Put something like 4 mm thick piece of plastic there, taped it up, to press the switch, then the light will go out. Edited March 6, 2014 by Kb27 Link to post Share on other sites More sharing options...
Dafansu Turbocharged March 6, 2014 Share March 6, 2014 Likely your brake switch. It's At the pedal area. I changed it previously for my vios at about $30. Link to post Share on other sites More sharing options...
TVT Supercharged March 7, 2014 Share March 7, 2014 Usually, the plastic pressing the brake switch is broken. When it can't press the brake switch, the brake light is always on. Brake switch can DIY to replace it or not ? Link to post Share on other sites More sharing options...
Ahgong Supercharged March 7, 2014 Share March 7, 2014 hmm... is this a common problem? Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 7, 2014 Share March 7, 2014 hmm... is this a common problem? Suppose so for Hyundai cars, my kena too, my mechanic do it for free, takes around 1 minute to rectify. Link to post Share on other sites More sharing options...
Ahgong Supercharged March 7, 2014 Share March 7, 2014 Suppose so for Hyundai cars, my kena too, my mechanic do it for free, takes around 1 minute to rectify. what was the cause? faulty electronics? what was the resolution? I am curious, cos i am also driving the same model. Link to post Share on other sites More sharing options...
Bornno1 1st Gear March 7, 2014 Share March 7, 2014 look upwards at the pedal area, u might find a rubber plug disintegrating which is supposed to prevent metal contact with brake pedal, replace that 1 Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 7, 2014 Share March 7, 2014 what was the cause? faulty electronics? what was the resolution? I am curious, cos i am also driving the same model. The plastic rubber thats suppose to activate the brake lights worn off after several years of usage. Brake up turn on all the way even when driving, have to disconnect the batt when parking at home. Mechanic bend certain part of the foot brake paddle so that it can disengage the brake light when it's not engage. 1 Link to post Share on other sites More sharing options...
SGCMmadman 6th Gear March 7, 2014 Author Share March 7, 2014 Jason at auto101 managed to solve problem by tightening sum spring near pedal at no cost in few mins. Thks for all replies. Link to post Share on other sites More sharing options...
Xers007 Supercharged March 7, 2014 Share March 7, 2014 Just happened to me 2 weeks ago.. the brake lights and 3rd brake light dont turn off... found out that there is a rubber plug on the brake pedal which is suppose to be pressing on the brake light switch when the pedal is depressed breaks and dropped off... i just make a hole on the original rubber (lucky found on my floorboard) and use cable tie to secure back to the pedal... zero dollar fix but neck breaking... Link to post Share on other sites More sharing options...
Knoobie Supercharged March 7, 2014 Share March 7, 2014 Just happened to me 2 weeks ago.. the brake lights and 3rd brake light dont turn off... found out that there is a rubber plug on the brake pedal which is suppose to be pressing on the brake light switch when the pedal is depressed breaks and dropped off... i just make a hole on the original rubber (lucky found on my floorboard) and use cable tie to secure back to the pedal... zero dollar fix but neck breaking... behold the power of cable tie!! Link to post Share on other sites More sharing options...
Kb27 Supersonic March 7, 2014 Share March 7, 2014 (edited) Brake switch can DIY to replace it or not ? Yes you can. Need to pull the plastic connector out. Remove the brake switch, and any nuts holding it down. hmm... is this a common problem? I've seen this happened on a few cars, Vios, City, Getz, Sunny, Matrix. The problem happened usually to older cars. After long usage and probably people letting go of the brake too fast, the pedal slams the switch on the plastic stopper repeatedly. One day the plastic just cracks and dropped off. You will see bits and pieces of it on the ground. Then the brake lights remain on all the time. Edited March 7, 2014 by Kb27 Link to post Share on other sites More sharing options...
2BDriver Hypersonic March 7, 2014 Share March 7, 2014 behold the power of cable tie!! S M R T ! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Traffic junction without traffic lights
Advice on exhaust.
Advice on exhaust.
