Ktglfc Hypersonic October 11, 2015 Share October 11, 2015 Thankfully it was on ground and that no passengers on board, except for an engineer ... And luckily no injuries... Hopefully a thorough investigation will shed some light on what is the main cause, and SIA can then rectify ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Friendstar Supercharged October 11, 2015 Share October 11, 2015 IMO. It is almost impossible for the system to be overridden this way. Unless the plane is on repair mode 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic October 11, 2015 Share October 11, 2015 Shiat... Booked on a380 to HK and Shanghai next month 😓 Its ok. I think they have more than one. 4 Link to post Share on other sites More sharing options...
Vid Hypersonic October 11, 2015 Share October 11, 2015 Its ok. I think they have more than one. They have more than one A380. But to HK, there's only one A380. Good luck @Enye. Contact me if you reach safely 3 Link to post Share on other sites More sharing options...
Maskedrider 4th Gear October 11, 2015 Share October 11, 2015 Siao Liao .... Coe going shot high again cos SIA going to bid for replacement plane 2 Link to post Share on other sites More sharing options...
Baal Supersonic October 11, 2015 Share October 11, 2015 Cat E which can be used for all vehicles will shoot high. Cat a & b safe. 2 Link to post Share on other sites More sharing options...
Fitvip Supersonic October 11, 2015 Share October 11, 2015 An engineer was on aboard the SIA plane doing some checks when it happened. So, it could be screwed up check. Press wrong button or some locks not in place before checks. Expensive damage. Something like this also happened to EVA.... This looks like boeing 747! Link to post Share on other sites More sharing options...
Kangadrool Supersonic October 11, 2015 Share October 11, 2015 こにちわ Link to post Share on other sites More sharing options...
Old-driver 5th Gear October 11, 2015 Share October 11, 2015 Shiat... Booked on a380 to HK and Shanghai next month 😓 its not a A-380. its a 330 2 Link to post Share on other sites More sharing options...
Boringchap Turbocharged October 11, 2015 Share October 11, 2015 Not A380 but a smaller A330. If you look at the pictures carefully, you can see that the aircraft door was also ripped out. I think the aero-bridge would have sustained some damage. Thankfully there were no injuries. Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic October 11, 2015 Share October 11, 2015 Not A380 but a smaller A330. If you look at the pictures carefully, you can see that the aircraft door was also ripped out. I think the aero-bridge would have sustained some damage. Thankfully there were no injuries. Front wheels allegedly retracted?? Is someone fiddling with the buttons? Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 11, 2015 Share October 11, 2015 Cat E which can be used for all vehicles will shoot high. Cat a & b safe. hmmm you trying to say aeroplane also will need Cat E soon ? Waa this KBW si beh KNS ! kekekeke 2 1 Link to post Share on other sites More sharing options...
Boringchap Turbocharged October 11, 2015 Share October 11, 2015 Front wheels allegedly retracted?? Is someone fiddling with the buttons? SIA has not issued any official statement. The press reported that there was an engineer onboard the aircraft, performing some pre-flight engineering checks. The nose wheel retraction is a fact. The pictures show it. The front nose retracted back into the aircraft and not collapsed. The funny thing is how come the aircraft front wheel can retract even though the aircraft is on the ground. I am not an aircraft engineer but I would have thought there would be some safety mechanism such that even if the engineer or pilot pressed the wrong button, the wheels shouldn't retract while the plane is on the ground. Or maybe it was a computer virus? Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic October 11, 2015 Share October 11, 2015 its not a A-380. its a 330 I just took 330-300 last week lol Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic October 11, 2015 Share October 11, 2015 Front wheels allegedly retracted?? Is someone fiddling with the buttons? Front wheel forgot to eat wai ge hahaha 3 Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic October 11, 2015 Share October 11, 2015 SIA has not issued any official statement. The press reported that there was an engineer onboard the aircraft, performing some pre-flight engineering checks. The nose wheel retraction is a fact. The pictures show it. The front nose retracted back into the aircraft and not collapsed. The funny thing is how come the aircraft front wheel can retract even though the aircraft is on the ground. I am not an aircraft engineer but I would have thought there would be some safety mechanism such that even if the engineer or pilot pressed the wrong button, the wheels shouldn't retract while the plane is on the ground. Or maybe it was a computer virus? I am concerned about the structural integrity of the aircraft hull. Can fly again arnot or write off leow? 1 Link to post Share on other sites More sharing options...
Boringchap Turbocharged October 11, 2015 Share October 11, 2015 I am concerned about the structural integrity of the aircraft hull. Can fly again arnot or write off leow? I am not qualified to answer your question. Hopefully, SIA will address this when they finally say what happened. Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic October 11, 2015 Share October 11, 2015 (edited) Front wheel forgot to eat wai ge hahaha Wat's wai ge? Or plane drink too much coconut juice? :p . Edited October 11, 2015 by Toothiewabbit ↡ Advertisement Link to post Share on other sites More sharing options...
Fatty Kim going crazy again
Sg Election 2025!
Sg Election 2025!
Singapore Airlines and Malaysia Airlines to launch code share flights
SIA ditches ‘flight to nowhere’ idea, rolls out A380 restaurant, delivery menu and training facilities tour
New problems on the now grounded Boeing 737 Max found!
Japan Airlines plane bursts into flames upon landing at Tokyo’s Haneda airport
Singapore Airlines returns to profit as Asia travel surges
