Spken1976 1st Gear May 26, 2014 Share May 26, 2014 Hi all, need some advices from you all out there. I'm driving a 2007 Nissan Latio Premium. Recently I felt my car lost power when accelerate. When picking up that time, the car like no power. But when it reaches 60km/h, it's back to normal. At first I thought is the throttle dirty and had went to my workshop to get it washed. And i had also done my servicing. But after driving for 4 days, the problem back again. Anyone had face this problem before? Would appreciate if someone could help me on this. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic May 26, 2014 Share May 26, 2014 Is it the CVT gearbox? You hear the engine roar but no power transmitted onto the wheels? Aiya. Since it's a used car trade-in to get another used car with less problem. Link to post Share on other sites More sharing options...
Neost 6th Gear May 26, 2014 Share May 26, 2014 Ask workshop to check the ignition cables to the sparks plugs. I used to have a ride which will lose power suddenly when I step on the throttle. And after slushing for a while, it will suddenly pick up speed. I went to workshop and the mechanic said change the ignition cables will do. It works. Or, wrong octave petrol used. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged May 26, 2014 Share May 26, 2014 did you just change e/o Link to post Share on other sites More sharing options...
Spken1976 1st Gear May 26, 2014 Author Share May 26, 2014 Ask workshop to check the ignition cables to the sparks plugs. I used to have a ride which will lose power suddenly when I step on the throttle. And after slushing for a while, it will suddenly pick up speed. I went to workshop and the mechanic said change the ignition cables will do. It works. Or, wrong octave petrol used. OK Thks for the advice. Btw how much will it cost to change the cables? did you just change e/o Recently just change my four Coils for misfiring. Link to post Share on other sites More sharing options...
Tianmo Hypersonic May 26, 2014 Share May 26, 2014 i once had the same problem...........top gasket harden........EO ran into spark plug chambers..........ended up not enough spark...............changed the gasket...........rev and burn off the oil...........saw white smoke coming out..............after that soon soon liao............ Link to post Share on other sites More sharing options...
Spken1976 1st Gear May 26, 2014 Author Share May 26, 2014 i once had the same problem...........top gasket harden........EO ran into spark plug chambers..........ended up not enough spark...............changed the gasket...........rev and burn off the oil...........saw white smoke coming out..............after that soon soon liao............Wow like that quite bad. Mine still not up to this state. Link to post Share on other sites More sharing options...
Spken1976 1st Gear May 26, 2014 Author Share May 26, 2014 Btw anyone know how much will it cost to change the ignition Cable For Nissan Latio? Link to post Share on other sites More sharing options...
Tianmo Hypersonic May 26, 2014 Share May 26, 2014 Wow like that quite bad. Mine still not up to this state. same same lost of power.............check see got any sign of EO leakage or not...........you wouldn't know until you remove the spake plugs.... Link to post Share on other sites More sharing options...
Spken1976 1st Gear May 26, 2014 Author Share May 26, 2014 same same lost of power.............check see got any sign of EO leakage or not...........you wouldn't know until you remove the spake plugs.... Will do. Thks for your advice. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear May 27, 2014 Share May 27, 2014 Loss of power is a very big scope to diagnose. Unless u have very strong indicating factors to point to a certain point of failure like plug or coil..etc, better to let agent diagnose with their computer, and pay for their labour charges than try self medication and change this and that till u get it resolve, or monkey mechanic who just do guesswork also Link to post Share on other sites More sharing options...
Tohto Hypersonic July 2, 2014 Share July 2, 2014 Thanks for all suggestions.. You created a account and spamming different thread with un-related post ↡ Advertisement Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Nissan QashQai 2014 Part 2
Advice on exhaust.
Advice on exhaust.
