Shibadog Turbocharged June 20, 2014 Share June 20, 2014 Guys, in such a situation, NO handbrake, NO reverse gear, NO switch off engine, NO stepping on brakes all the way, NO NO NO!!! All wrong!!! If this happens, please go to NEUTRAL GEAR first, then APPLY FOOTBRAKE. Handbrake = will cause car to drift = dangerous Reverse gear = same as above Switch off engine = lose brake assist and power steering + steering lock (some cars) = cannot control car Holding footbrake while gear engaged = brake fade = no brakes Please learn this. I have had a friend who had 2 stupid layers of thick carpet. He usually don't floor it but going up north he whack until max, then when he saw the toll his accelerator pedal stuck and he could not brake. The more you step on the brake while the engine is pushing, the more it fades, the worse it gets. The engine is totally capable of overcoming the brakes. Luckily he disengage the gear in time before smashing into a queue of cars at the toll. Always remember that the first thing you do is to disengage the GEARS. yup.. problem is... with the proliferation of auto trans, most drivers don't really focus much on the use/role of gearbox :( ↡ Advertisement 2 Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 20, 2014 Share June 20, 2014 Wall-mounted gas pedal: not sure if it will ever get stucked unless spring gave way? Even if spring gave way and pedal cannot return itself, just use your feet to pull back by going your feet behind the pedal. Floor-mounted gas pedal: it's connected via a rod I supposed? Or some sensors now with e-throttle? Prone to get stucked. Once stucked, how to use your feet to pull up? E-Throttle,if the sensor something wrong,the car will still full power,even..you don't step on it. 2 Link to post Share on other sites More sharing options...
Slyison 4th Gear June 20, 2014 Share June 20, 2014 Not sure about newer car with newer technology, my lao pok chia toyota, I won't be able to take out my car key unless I shift the gear to P. If the Korean teksi unker zham brake and shift to P, and take out his key , I am sure engine will be cut off right? Correct me if I am wrong. 2 Link to post Share on other sites More sharing options...
Super7 Turbocharged June 20, 2014 Share June 20, 2014 What will you react in driving a car caught in this unstoppable emergency situation http://www.youtube.com/watch?v=PGSLrgByqOY http://www.youtube.com/watch?v=TO5MU91Thmo Is it possible to pull handbrake hard and play the steering wheel etc to make multiple "handbrake turns" ie keep the car making continuous U-turns almost on the same spot, making many, many donuts until the engine dies down, tyres go botak? Link to post Share on other sites More sharing options...
Super7 Turbocharged June 20, 2014 Share June 20, 2014 put reverse gear wah, you want the gbox to explode izit? :o Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 20, 2014 Share June 20, 2014 Is it possible to pull handbrake hard and play the steering wheel etc to make multiple "handbrake turns" ie keep the car making continuous U-turns almost on the same spot, making many, many donuts until the engine dies down, tyres go botak? 老 大,啊得哥,You came back just after drinking beer session ? I read with nerve cracking. 1 Link to post Share on other sites More sharing options...
Super7 Turbocharged June 20, 2014 Share June 20, 2014 I think it's a fair statement. Probably 99% of drivers will be so stunned they don't know how to react. Myself included I think. If my car suddenly accelerate with no brakes, I don't think I will think of turning off the car in an instant. Turn off may be even worst cause our car will wheel lock. Cannot even steer then. Maybe road cars should also be equiped with a "KILL" button to kill the engine in case of such an emergency? This KILL button can be programmed to disengage the gearbox at the same time it kills the engine if the owner selects this option when he buys the car. Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 20, 2014 Share June 20, 2014 wah, you want the gbox to explode izit? :o The correct way is, put to Neutral and brakes to slow then hand braking, lastly off engine to examine car. Link to post Share on other sites More sharing options...
Super7 Turbocharged June 20, 2014 Share June 20, 2014 老 大,啊得哥, You came back just after drinking beer session ? I read with nerve cracking. I took taxi back, scared of road block.... [sweatdrop] Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 20, 2014 Share June 20, 2014 I took taxi back, scared of road block.... [sweatdrop] Good Boy ! Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 20, 2014 Share June 20, 2014 motorcycle has it - kill switch. Maybe road cars should also be equiped with a "KILL" button to kill the engine in case of such an emergency? This KILL button can be programmed to disengage the gearbox at the same time it kills the engine if the owner selects this option when he buys the car. Link to post Share on other sites More sharing options...
So_nice 6th Gear June 21, 2014 Share June 21, 2014 Yup, say is easy, but when such incident happened, I wonder how many would be clam enough to react in split second to switch to Neutral. Normal people would be stunned for a few seconds, and that few seconds can already cause damage to property, cars etc.. Kanna before in an altis. Just depress brake and move to the side lor. 1 Link to post Share on other sites More sharing options...
Yewheng Twincharged June 21, 2014 Author Share June 21, 2014 (edited) Kanna before in an altis. Just depress brake and move to the side lor.Your speed is slow during that time? If your speed is fast, there maybe chances of brake fade, as the amount of heat generated during acceleration plus braking is very high. Once brake fade, the brake will lose it effectiveness.. I never encounter it before and hope it would not happen to me. Maybe some cars already have the brake override accelerator, meaning once brake is depressed, no amount of acceleration will work anymore. I don't know.. Edited June 21, 2014 by Yewheng 1 Link to post Share on other sites More sharing options...
Herz22 1st Gear June 21, 2014 Share June 21, 2014 This works. 3 Link to post Share on other sites More sharing options...
Cybertech 4th Gear June 21, 2014 Share June 21, 2014 So this Hyundai Taxi same problem ? Cabby accidentally reverses and slams into parked car at carpark 1 Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 21, 2014 Share June 21, 2014 This works. Thanks for sharing such useful driving instruction. Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 21, 2014 Share June 21, 2014 So this Hyundai Taxi same problem ? Cabby accidentally reverses and slams into parked car at carpark The one ram onto NTU staircase is a Toyota Crown, the rest are all Hyundai Sonata's. Very lucky that no one is being hurt in these freak accidents. Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 22, 2014 Share June 22, 2014 In my view the old Toyota Crown & the Nissan Cedric still safer than the korean ones.. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Kia EV6
2022 Kia EV6
Chinese flying taxi maker EHang sells autonomous passenger drone for US$332,000 on Taobao as nation’s low-altitude economy takes off
2018 Kia Cerato K3 / Forte (BD Series) + 2021 Facelift
2022 Hyundai Staria MPV
