Watwheels Supersonic October 27, 2014 Share October 27, 2014 I moved away from that tiny bottle already. Now using an external sprayer. Foam 'quality' same as the pressure washer if not better. 2L can spray whole car. I completed my external battery. Now spray like nobody business. Tested the blower. Not really powerful but can chase the water from the nooks and crannies. Using this ah? Whole bottle of shampoo in a wash. LoL... ↡ Advertisement Link to post Share on other sites More sharing options...
Kklee 6th Gear October 28, 2014 Share October 28, 2014 Using this ah? Whole bottle of shampoo in a wash. LoL... If I can, I will do it. Link to post Share on other sites More sharing options...
Dunksto Neutral Newbie November 3, 2014 Share November 3, 2014 i have this its really useless the flow is like those water cooler tap I remembered seeing the promotion for a small portable car wash spray by autobacs @ $20. I dunno still available or not. Looks like this: http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=58902 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear November 4, 2014 Share November 4, 2014 I overcome that by spraying longer. No AC power and no water hose - what to do ? Link to post Share on other sites More sharing options...
Watwheels Supersonic November 4, 2014 Share November 4, 2014 Ok. I have found some rubber foam tape to seal the edges. The foam tape comes one side adhesive. Haven't test it yet coz I want the tape to settle onto the contours first. I think may have to reinforce with 3M double sided strips. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic November 4, 2014 Share November 4, 2014 (edited) Ok. I have found some rubber foam tape to seal the edges. The foam tape comes one side adhesive. IMG_1381.JPG Haven't test it yet coz I want the tape to settle onto the contours first. I think may have to reinforce with 3M double sided strips. For those who are using Sonax wheel cleaner there's a cheaper substitute. Yes, it also turns purple upon application. It can be bought at any SPC kiosk or from the distributor(who is also the distributor of the car wash kit I'm using) http://www.sgcarmart.com/directory/merchant.php?MID=10319 $13.90/bottle at SPC, $11+/bottle distributor. 500ml. Here I swap the nozzle from a 3M bottle coz the original nozzle doesn't squirt well. Edited November 4, 2014 by Watwheels Link to post Share on other sites More sharing options...
Coolpica 4th Gear November 4, 2014 Share November 4, 2014 Ok. I have found some rubber foam tape to seal the edges. The foam tape comes one side adhesive. IMG_1381.JPG Haven't test it yet coz I want the tape to settle onto the contours first. I think may have to reinforce with 3M double sided strips. Where to buy the rubber foam? 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 15, 2014 Share November 15, 2014 anyone tried using hose spray on those 20cents coins washing bay machine? can work anot? cos planning to buy leh.. 1 Link to post Share on other sites More sharing options...
Duckling Neutral Newbie November 23, 2014 Share November 23, 2014 (edited) anyone tried using hose spray on those 20cents coins washing bay machine? can work anot? cos planning to buy leh.. I've been using it for about 3 years...works very well...but nowadays very lazy hence go petrol station for car wash $8. I got it at a provision shop a cheap metal spray head & 10 meters of high grade hose with a turning cap at the other end (around $10)...cost me about $1.20 - $1.60 of water from those 20 cents coin machine for rinse before & after wash - need those coin machine with threads for the turning cap else won't work & don't forget the rubber washer. The pressure is good though not as strong as those petrol station wash. https://flic.kr/p/qar5nr Edited November 23, 2014 by Duckling 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic November 23, 2014 Share November 23, 2014 Where to buy the rubber foam? Garlin Pte Ltd Just to update. I have minimise the spilling to around 90% using 3M double sided tape(heavy duty) to firmly secure the rubber foam. I have to use clothes pegs to hold the foam down for a couple of days especially the corners. The bottles that I'm using are effective in pushing out more shampoo especially the bigger one that I have bought. Link to post Share on other sites More sharing options...
Carlovz Clutched November 24, 2014 Share November 24, 2014 Thanks for the updates, bro 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 24, 2014 Share November 24, 2014 I've been using it for about 3 years...works very well...but nowadays very lazy hence go petrol station for car wash $8. I got it at a provision shop a cheap metal spray head & 10 meters of high grade hose with a turning cap at the other end (around $10)...cost me about $1.20 - $1.60 of water from those 20 cents coin machine for rinse before & after wash - need those coin machine with threads for the turning cap else won't work & don't forget the rubber washer. The pressure is good though not as strong as those petrol station wash. https://flic.kr/p/qar5nr the rubber washer is for what use? Can explain more abit? I just worry the hose if not secure properly, the water may rush out. 1 Link to post Share on other sites More sharing options...
Duckling Neutral Newbie November 24, 2014 Share November 24, 2014 the rubber washer is for what use? Can explain more abit? I just worry the hose if not secure properly, the water may rush out. The rubber washer (red thing in the picture below) is to prevent water from rushing out due to high pressure. 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 25, 2014 Share November 25, 2014 (edited) The rubber washer (red thing in the picture below) is to prevent water from rushing out due to high pressure. this sure helps. thanks bro for explaining. bu the way the screw on cap is how big? Edited November 25, 2014 by MkMan Link to post Share on other sites More sharing options...
Duckling Neutral Newbie November 25, 2014 Share November 25, 2014 this sure helps. thanks bro for explaining. bu the way the screw on cap is how big? Standard size...most hardware shop should know. Link to post Share on other sites More sharing options...
MelsonChua Clutched February 8, 2015 Share February 8, 2015 I recently bought this after seeing this ad..... So far so good. http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=54548 https://www.youtube.com/watch?v=VKNd11S761E Wah this seems like a pretty gd product! 1 Link to post Share on other sites More sharing options...
flashbang Turbocharged October 13, 2015 Share October 13, 2015 I recently bought this after seeing this ad..... So far so good. http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=54548 https://www.youtube.com/watch?v=VKNd11S761E If anyone is interested, I have one to let go. Bought it recently but decided it doesn't suit me. I'm willing to let go at $60. Link to post Share on other sites More sharing options...
dcb Turbocharged October 14, 2015 Share October 14, 2015 I also have a set to let go. Been not using it for a long time. PM me for the price ↡ Advertisement Link to post Share on other sites More sharing options...
Optimum No Rinse Wash & Shine
Good Car Wash in the East
Car wash at JB
Car wash at JB
New Age Polish -->Land Rover Portfolio
New Age Polish --> Volkswagen Portfolio
Saw a Chinaman teaching his daughter how to wash car...
Recommended places for Car Wash
SPC Minds Wash towards Vivo City/Harbourfront(Pasir Panjang)
