The_Bear Turbocharged October 3, 2014 Share October 3, 2014 your colleague or friend? Wahahahaha....NO 😁 ↡ Advertisement Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged October 3, 2014 Share October 3, 2014 Wahahahaha....NO 😁or that's you? Link to post Share on other sites More sharing options...
The_Bear Turbocharged October 3, 2014 Share October 3, 2014 or that's you? no Link to post Share on other sites More sharing options...
Mrlancergtx 5th Gear October 3, 2014 Share October 3, 2014 That one not drive. That one is as passenger sleep inside [laugh] He will be driven in that hearse...thats the right way to put it Link to post Share on other sites More sharing options...
Brobear 2nd Gear October 3, 2014 Share October 3, 2014 (edited) Another idiot driver! Doesn't mean u signalled means u can switch lanes immediately. U have to check first! before filtering over. Some more anyhow stop at the slip road. Idiot!! Edited October 3, 2014 by Brobear 1 Link to post Share on other sites More sharing options...
Sabian Turbocharged October 3, 2014 Share October 3, 2014 Many times, when moving from a filter lane onto the expressway, you can see many koteks moving at a speed significantly slower than the lane they are filtering into, causing drivers in that lane to slow down. The Braddell filter to CTE heading north is a good example. Link to post Share on other sites More sharing options...
Atrecord Supersonic October 3, 2014 Share October 3, 2014 Common sense unless I am wrong. Well, i think you're wrong here. In your example: 1) the left car is not joining a main road from a side road. First rule: main road has right of way, period. 2) the left car is already in front of the right car, so right car should let left car in. Try to apply these 2 to the incident as seen in the video. You will realize the volvo was in the wrong. Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 3, 2014 Share October 3, 2014 I'm not condoning volvo's driver behaviour, but.. Filtering is about cooperation. Imo, the joining or accelerating lane is for the car to fit in either in front or behind depending on the relative speed of vehicles and how long the distance is the joining lane. If the volvo is half a car in front, the lorry behind should slow down and let him in. And I've just been persistently flashed and high beam when I changed lane by the same kind of lorry, bcuz he doesn't want to slow down. He's not happy. Should I start another fight ? guess we on the same wave length... not gonna to command what GL look wowo owner has or whatever, I see an opportunity that I can speed up and goes in front of cam lorry and filter out safely, i will do so rather than kanna stuck in the filter lane. Cam lorry should be gracious enough to let him cuts in. Link to post Share on other sites More sharing options...
Neutralsg 5th Gear October 3, 2014 Share October 3, 2014 Witty you are Vid. Like your sense of humour That one not drive. That one is as passenger sleep inside 1 Link to post Share on other sites More sharing options...
Neutralsg 5th Gear October 3, 2014 Share October 3, 2014 (edited) Yesterday after signalling, I attempted to filter to the next lane but a van driver from behind rushed in and die die don't want to give way. Therefore, I let him go in front to avoid an accident while a gracious driver allowed me to filter safely. This afternoon, a comfort cab driver came from the side and after cutting over a chevron marker die die squeeze me away from my lane to give way to him and again, I gave in to avoid an accident. While these encounters seem more prevalent than the past, there are still hope because many others do gave way when you give ample notice compared to these small group of drivers I sometimes encounter despite the signalling, hand waving etc... Another idiot driver! Doesn't mean u signalled means u can switch lanes immediately. U have to check first! before filtering over. Some more anyhow stop at the slip road. Idiot!! Edited October 3, 2014 by Neutralsg Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged October 3, 2014 Share October 3, 2014 nopulling your leg.. Link to post Share on other sites More sharing options...
The_Bear Turbocharged October 3, 2014 Share October 3, 2014 pulling your leg.. Yes, please 😁 Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 3, 2014 Share October 3, 2014 pulling your leg.. which leg ↡ Advertisement Link to post Share on other sites More sharing options...
Lai leh lai leh CSCBB chu lai liao.
Why is PSY - Gangnam so famous?
Caltex attendant pump wrongly. Ex boss helped
Cannot anyhow stick SPF decal liao!
Famous Quotes From Our Politicians!
Ho Ching 要买 GTR? (Ho Ching wanna buy GTR?)
Heng no more in running for PM
More mergers of Pri and Sec Schools
