BengGaBoy 2nd Gear December 11, 2014 Share December 11, 2014 Hi folks, Today went to Viacom for inspection and failed. As I'm the 2nd owner, thus, I wasn't aware what did the previous owner did. Anyway, he has changed the front headlight to HID and LEDs for the rear and front-small light. So Viacom failed all the lighting related test section. So do any folks have any workshop who is expert in this area and help me to get my car back to compliance ? I only afraid some workshop assume this and that, end-up, I fail again and have to re-do all over again. Worse, my road tax is expiring soon, so I need to get it done quickly. Many thanks ! Cheers, ↡ Advertisement Link to post Share on other sites More sharing options...
Car_byte 3rd Gear December 11, 2014 Share December 11, 2014 Hi folks, Today went to Viacom for inspection and failed. As I'm the 2nd owner, thus, I wasn't aware what did the previous owner did. Anyway, he has changed the front headlight to HID and LEDs for the rear and front-small light. So Viacom failed all the lighting related test section. So do any folks have any workshop who is expert in this area and help me to get my car back to compliance ? I only afraid some workshop assume this and that, end-up, I fail again and have to re-do all over again. Worse, my road tax is expiring soon, so I need to get it done quickly. Many thanks ! Cheers, You can try autobac ubi as I had similar issue and the guys were able to install equivalent. Good luck Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator December 11, 2014 Share December 11, 2014 Hi folks, Today went to Viacom for inspection and failed. As I'm the 2nd owner, thus, I wasn't aware what did the previous owner did. Anyway, he has changed the front headlight to HID and LEDs for the rear and front-small light. So Viacom failed all the lighting related test section. So do any folks have any workshop who is expert in this area and help me to get my car back to compliance ? I only afraid some workshop assume this and that, end-up, I fail again and have to re-do all over again. Worse, my road tax is expiring soon, so I need to get it done quickly. Many thanks ! Cheers, Nightz Concepts at First Centre. Actually they specialize a lot on lighting mods but you can check if they are able to change it back to stock for you. Look for Dave. Link to post Share on other sites More sharing options...
Achtung 6th Gear December 11, 2014 Share December 11, 2014 Go to Nightz Concepts. They will help sort it out. Hi folks, Today went to Viacom for inspection and failed. As I'm the 2nd owner, thus, I wasn't aware what did the previous owner did. Anyway, he has changed the front headlight to HID and LEDs for the rear and front-small light. So Viacom failed all the lighting related test section. So do any folks have any workshop who is expert in this area and help me to get my car back to compliance ? I only afraid some workshop assume this and that, end-up, I fail again and have to re-do all over again. Worse, my road tax is expiring soon, so I need to get it done quickly. Many thanks ! Cheers, Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator December 11, 2014 Share December 11, 2014 Go to Nightz Concepts. They will help sort it out. Haha. Look at what I posted. Link to post Share on other sites More sharing options...
Achtung 6th Gear December 11, 2014 Share December 11, 2014 hehehe great minds think alike! Haha. Look at what I posted. Link to post Share on other sites More sharing options...
BengGaBoy 2nd Gear December 11, 2014 Author Share December 11, 2014 Many thanks for your kind input. Btw, there are 2 branches of Nightz Concept (Serangoon and Woodlands), any particular site ? Thanks Cheers, Link to post Share on other sites More sharing options...
Mcf777 Turbocharged December 11, 2014 Share December 11, 2014 Many thanks for your kind input. Btw, there are 2 branches of Nightz Concept (Serangoon and Woodlands), any particular site ? Thanks Cheers, Babyblade mentioned First centre. That should be the Serangoon Branch Link to post Share on other sites More sharing options...
BengGaBoy 2nd Gear December 11, 2014 Author Share December 11, 2014 Many thanks Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator December 11, 2014 Share December 11, 2014 Many thanks for your kind input. Btw, there are 2 branches of Nightz Concept (Serangoon and Woodlands), any particular site ? Thanks Cheers, I suggest you give them a call first just to check if they are able to give you what you want. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear December 11, 2014 Share December 11, 2014 changing bulb quite easy job. any workshop should be able to do it. Link to post Share on other sites More sharing options...
Watwheels Supersonic December 12, 2014 Share December 12, 2014 It's not difficult. Just disconnect the bulb and from the ballast, Make sure your fingers do not touch the bulb(the static will damage it) or wear rubber gloves. Find out the size of the original bulbs (eg. H4, H7, H11 etc), buy a set and put it back in. Make sure at the fuse box the correct fuse is replaced from what the previous owner is using. Usually underneath the fuse box cover all the fuse map is displayed there. Lastly remove all the HID ballast. Pole lights usually are twist and pull out or reach in to plug it out. It's usually the most easy, no gloves needed. Rear light you might need a "+" head screwdriver to remove the light assembly to take out the LEDs. You can learn a lot from Youtube. I know I did. LoL... I DIY change the headlight bulbs to legal brighter halogens and pole lights to LEDs. The rest I dun touch and leave it stock. 1 Link to post Share on other sites More sharing options...
ChickenMob 6th Gear December 12, 2014 Share December 12, 2014 It's not difficult. Just disconnect the bulb and from the ballast, Make sure your fingers do not touch the bulb(the static will damage it) or wear rubber gloves. Find out the size of the original bulbs (eg. H4, H7, H11 etc), buy a set and put it back in. Make sure at the fuse box the correct fuse is replaced from what the previous owner is using. Usually underneath the fuse box cover all the fuse map is displayed there. Lastly remove all the HID ballast. Pole lights usually are twist and pull out or reach in to plug it out. It's usually the most easy, no gloves needed. Rear light you might need a "+" head screwdriver to remove the light assembly to take out the LEDs. You can learn a lot from Youtube. I know I did. LoL... I DIY change the headlight bulbs to legal brighter halogens and pole lights to LEDs. The rest I dun touch and leave it stock. but some cars got areas difficult to access directly, need to remove bumper blah blah etc....... but once removed remember to align the rubber lining properly if not water go in jialat liow.... Link to post Share on other sites More sharing options...
Genes 6th Gear December 12, 2014 Share December 12, 2014 Go back to AD, confirm can. Question is whether you want to pay for it anot. Link to post Share on other sites More sharing options...
Watwheels Supersonic December 12, 2014 Share December 12, 2014 (edited) but some cars got areas difficult to access directly, need to remove bumper blah blah etc....... but once removed remember to align the rubber lining properly if not water go in jialat liow.... Yeah. My previous car I also thought must remove front bumper and all dan I noticed I can actually just plug out the plastic wiper fluid tank and I can get access to the bulb. LoL... I know some Renault cars need to remove tire to access the wheel arc well, remove the clips and cover to get to the headlights. *Faint* Light bulb maybe cost $50 but labour cost $100. LoL... Just an example. Edited December 12, 2014 by Watwheels Link to post Share on other sites More sharing options...
Fuelsaver Supercharged December 12, 2014 Share December 12, 2014 It's not difficult. Just disconnect the bulb and from the ballast, Make sure your fingers do not touch the bulb(the static will damage it) or wear rubber gloves. Find out the size of the original bulbs (eg. H4, H7, H11 etc), buy a set and put it back in. Make sure at the fuse box the correct fuse is replaced from what the previous owner is using. Usually underneath the fuse box cover all the fuse map is displayed there. Lastly remove all the HID ballast. Pole lights usually are twist and pull out or reach in to plug it out. It's usually the most easy, no gloves needed. Rear light you might need a "+" head screwdriver to remove the light assembly to take out the LEDs. You can learn a lot from Youtube. I know I did. LoL... I DIY change the headlight bulbs to legal brighter halogens and pole lights to LEDs. The rest I dun touch and leave it stock. it's not difficult if pnp, but ts is aftemkt hid. Link to post Share on other sites More sharing options...
Watwheels Supersonic December 12, 2014 Share December 12, 2014 it's not difficult if pnp, but ts is aftemkt hid. Anything is possible if you are determined and have the heart to do it. Ppl tell me to not do this or do that but I have gone ahead and been there & did it. Like upgrading my front speakers. I bought the speakers, mounting plates, wire harness, bought them online coz I do not want to deal with dealers and installers. Watch youtube videos on how to go about doing it. And I'm enjoying my new speakers. LoL... Link to post Share on other sites More sharing options...
BengGaBoy 2nd Gear December 12, 2014 Author Share December 12, 2014 Hi folks, Just an update, managed to go to Nightz Concept @ First Centre and get all my light back to compliance :) Finally passed my inspection and renewed my road tax liao :) Damage is around S$50 to replace front light (big and small), disable fog light (since no replacement available in store), license plate light and reverse light. The HID ballast basically still there, it's just disconnect and replace the lamp with compliance type. Thanks for help bros. Cheers, ↡ Advertisement Link to post Share on other sites More sharing options...
Buying Ceiling fan and lighting from JB
Car-themed cafe shut down by the authorities after just two months of operation
