  • Search this thread
  • Reply to this topic
27 replies to this topic | 98 praises
#1
Posted 08 January 2015 - 11:45 AM
Vega
  • THREAD STARTER
  • Vega
    NOS-ed
    Author Image
    10,770
#2
Posted 08 January 2015 - 12:01 PM
Myxilplix
  • Myxilplix
    NOS-ed
    Author Image
    15,718
Nice donkey kick.
A line of paint on a road holds more authority than I ever will.
#3
Posted 08 January 2015 - 12:13 PM
Vid
  • Premium member
    Vid
    2Fast2Furious
    Author Image
    133,475
Slight undercarriage damage. Nothing major.
The only thing that need fixing is the driver [laugh] [laugh]
Knoobie praised this
#4
Posted 08 January 2015 - 12:52 PM
Gitanic
  • Premium member
    Gitanic
    Supercharged
    Author Image
    6,067
wonder if i bend its quad exhaust it still moves. [:p]
#5
Posted 08 January 2015 - 12:59 PM
Vega
  • THREAD STARTER
  • Vega
    NOS-ed
    Author Image
    10,770
wonder the shock absorber will leak or not?
#6
Posted 08 January 2015 - 01:55 PM
JohnSHL
  • Premium member
    JohnSHL
    Author Image
    8,430
lol how did that happen on a straight n dry road?
#7
Posted 08 January 2015 - 02:05 PM
Deckbuild
  • Premium member
    Deckbuild
    Author Image
    8,521
Can see something sticking outbof the front right wheel after the stint.
#8
Posted 08 January 2015 - 03:07 PM
Aaronlkl
  • Premium member
    Aaronlkl
    2Fast2Furious
    Author Image
    64,815
Tyres side wall crack and rims warp.
Toothiewabbit and 2BDriver praised this
"If in doubt, Flat out!"
#9
Posted 08 January 2015 - 07:20 PM
ER-3682
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    12,051
This is a warning to lousy driver who switch off traction control on powerful cars.
Deckbuild and 1 Anonymous member praised this
Mazda 6..2.5.
#10
Posted 08 January 2015 - 09:46 PM
Ichibawa
  • Premium member
    Ichibawa
    6th Gear
    Author Image
    3,419
suspension parts like the ball joint & stabilizer links. The bump stop should prevent the shock absorbers from bottoming. If that did not stop the piston from hitting the bottom valve then the absorbers needs to be change as there would be no damping effect at all once the bottom valve is compromised.
Other than mechanical parts that can be easily replaced with some $$$, the greatest damage will be to the driver's ego.
Staff69 and 1 Anonymous member praised this
#11
Posted 08 January 2015 - 10:32 PM
Vega
  • THREAD STARTER
  • Vega
    NOS-ed
    Author Image
    10,770
This is the M4 owner side of the story.
Hey guys,
It was my car that was involved and a mistake was made. There were no intentions of doing anything out of the norm. In fact, you'll notice in the video that the car was going very slowly in front of the crowd. This was intentional because we've all watched too many YouTube videos of this sort of thing happening and wanted to make sure that nobody would get hurt should anything unexpected happen. Once the car was past the crowd the accelerator was pushed in a straight-line as I have done many times in the past when the rear snapped violently. The car was going ~30mph at that time. The car has been driven for 4700 miles and has been driven with DSC off many times including in the rain and never has the car snapped so violently just from accelerating. I chalk it up to several factors including cold temps (low 40s), cold tires and incorrect psi (more on that later) and of course driver error. More judicious use of the throttle should have been exercised. MDM mode was not used because MDM is too quick to intervene and cuts power prematurely (or maybe not).
Usually when the rear breaks loose, it does so progressively and steering correction will suffice. However, you can see in the video that the front tires are turned slightly to the right indicating opposite lock was put on the steering trying to prevent the car from doing a complete 180 however there wasn't enough real estate to counter how violently it snapped - though admittedty the gravity of the snap required immediate full oppo lock which was misread. I'm not sure why some are saying that no steering input was made because it was - one could argue it should have been sooner but again usually a little wiggle just takes small steering input and power through not a full-on immediate opposite lock as was needed in such a big snap - to me it actually seemed like it was happening in slow-mo although the vid makes it seem like it happened so fast. As the car started to correct it became apparent that there was no way out except over the curb which is where I put on the brakes and tried to straightline the curb as much as possible to avoid hitting the curb at an angle which would cause a lot of damage and potentiality flip/roll the car.
I've driven many high hp rwd cars including vipers, porsches, corvettes, and formula cars and I've graduated from formula racing schools and have years of training in advanced car control and plenty of track time. Heck I remember day one of Formula school, half of the first day was spent on the skid pad learning how to keep a car from spinning if you lose traction. Maybe I need a refresher since it's been awhile and I've been driving AWD Audis for the past few years. Some of those other RWD cars I mentioned will snap fiercely and you have to be on extremely high alert, however my experience with the M4 has been that it tends to not snap so viciously in a straight line - but this time I was wrong. I would caution anyone thinking that it can't happen to them (count me as previously one of those) that anyone can make a mistake. I'm thankful that nobody was injured from such a mistake. Surprisingly, the car seems to be driving just fine with the only damage being the right plastic guard underneath the bumper which can be seen in the video. Surprising I know.
I mentioned earlier that I had incorrect PSI - let me explain. My PSI was low, so I inflated it a bit with a pump with an analog tire guage which of course is very imprecise compared to a digital gauge. I noticed that my right tire pressure was 1.5psi off of my left when viewing the PSI from the BMW onboard digital gauge (you can only do this while driving). However, as my car had been pulling to the right from day 1 of delivery (there's a big thread of many complaining about that on these forums). Miraculously, the car drifted to the right to a lesser extent with the right tire PSI being slightly higher than the left and so I was playing around with the idea of keeping it that way for a short time- however I knew that I needed to put the PSI equally across both tires but I just failed to do that before going to the meet. I have no idea if unequal PSI left to right contributed to the right rear spinning so differently than the left.
Anyways, I know I'll be ridiculed and called an idiot (and rightfully so) but I think many of you also know that I didn't do anything intentionally out of the ordinary or unsafe. I'm not sure I was even trying to show off as acceleration happened when the car was past the crowd and it's not like a powerslide or burnout or anything of that sort occurred.
I also think the M4 is a fine car and I have no complaints about the amount of power or torque or tire width or grip or anything. In fact, the whole reason I got the M4 is because it's not AWD and I like the rear moving around a bit. Mistakes happen and I've learned a lesson - and from now on will keep DSC on when driving around because there's too much at stake to make a mistake while driving - no matter how good or bad of a driver you are. Thanks for hearing me out. It certainly has been a humbling experience.
Opel17 and 1 Anonymous member praised this
#12
Posted 09 January 2015 - 08:37 AM
Turboflat4
  • Premium member
    Turboflat4
    2Fast2Furious
    Author Image
    52,142
Hey guys,
All these excuses and he still hasn't explained why he even turned DSC off on a public road in the first place.
Awesome rebuttal: http://jalopnik.com/...is-b-1677523538
I especially *love* this awesome gauge, really need to get me one of these. [laugh]
Edited by Turboflat4, 09 January 2015 - 08:48 AM.
Aaronlkl, Opel17 and 1 Anonymous member praised this
#13
Posted 09 January 2015 - 09:01 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    54,654
Ohhh... defintely ego got hurt. Failed in front of so many ppl watching. LoL...
Feel so rich. Or just an illusion?
#14
Posted 09 January 2015 - 09:13 AM
Vega
  • THREAD STARTER
  • Vega
    NOS-ed
    Author Image
    10,770
while we are not sure why the driver turned off DSC, the video did show the car wasn't accelerating fast on the straight before it snap.
what could have caused this?
#15
Posted 09 January 2015 - 09:46 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    54,654
On cold countries ppl really have to take note on cold tires as there will be no grip on the tarmac surface. For such a high torque engine a sudden stab on the gas will cause torque steer. So it's a combination of a couple of factors.
Traction control off is becoz what it does is cut wheelspin so when it kicks in during hard acceleration the car will feel jerky to drive. Switching it off will have a smoother acceleration even with wheelspin. Sometimes I also off mine when I feel some jerking when accelerating. When you watch topgear JC and company also off it to stop the traction control from kicking in. For safety concern I still leave it on most of the time.
Edited by Watwheels, 09 January 2015 - 09:48 AM.
#16
Posted 09 January 2015 - 11:20 AM
Turboflat4
  • Premium member
    Turboflat4
    2Fast2Furious
    Author Image
    52,142
Quite obvious he turned off DSC to showboat - by doing a burnout. He just didn't want to admit it.
#17
Posted 09 January 2015 - 11:23 AM
Vid
  • Premium member
    Vid
    2Fast2Furious
    Author Image
    133,475
Hey guys,
I give him a 10/10 for coming up with such a bullsh*t story! Well done! [laugh] [laugh]
#18
Posted 09 January 2015 - 11:24 AM
Turboflat4
  • Premium member
    Turboflat4
    2Fast2Furious
    Author Image
    52,142
Torque steer is insignificant in a RWD vehicle. The analogous effect in a RWD should properly just be called "fishtailing".
TC - there is really no cause to be switching it off on public roads. JC et al switch it off for track use only.
Edited by Turboflat4, 09 January 2015 - 11:27 AM.
#19
Posted 09 January 2015 - 11:56 AM
Zipp
  • Zipp
    Clutched
    Author Image
    27
Shouldn't off DSC for these cars unless one is a professional. On open area I tried DSC off to understand my car on a turn and it spun 360 easily - I couldn't correct it! With DSC on, you can still drift it. Got a lot to learn here too. I did on Evo X and was way more controllable.
Darryn and 1 Anonymous member praised this
#20
Posted 09 January 2015 - 11:59 AM
Turboflat4
  • Premium member
    Turboflat4
    2Fast2Furious
    Author Image
    52,142
*Even* if one is a pro, one still needs *space* to recover. But a pro would know that and not turn off the DSC (or generally drive like a dickhead) in public, especially in a confined space.
Back to General Car Discussion  ·  Cars Top Reply to this topic
SgCarMart Quotz
BMW M Series M4 Coupe
BMW M Series M4 Coupe  |  Rating   Submit Review
Reviewed by qwertul  |  1st Gear
Another Exciting Chapter in M History
Approaching the car is a breathtaking process. The sleek lines that run on either side of the bonnet to the tailgate create a striking and imposing presence. Immediately the car's muscular stance and aggressive face makes you excited to find... » Read More
Related New Cars search on sgCarMart.com : BMW M Series M4 Coupe
Quick Reply
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
