  • 1
  • Search this thread
  • Reply to this topic
14 replies to this topic | 18 praises
#1
Posted 18 January 2015 - 09:21 PM
Kippei
  • THREAD STARTER
  • Premium member
    Kippei
    3rd Gear
    Author Image
    412
5.5 Years 110k KM.
Should I change out the entire assembly or just the filter?
#2
Posted 18 January 2015 - 10:17 PM
Fuelsaver
  • Premium member
    Fuelsaver
    Author Image
    8,360
filter of cos, unless u facing other related issues.
FS
#3
Posted 19 January 2015 - 01:05 AM
Tommisan
  • Premium member
    Tommisan
    4th Gear
    Author Image
    665
5.5 Years 110k KM.
If the fuel pump is working properly, why change it?
I had once replaced the fuel pump. As the fuel pump was dying, it wasn't able to create enough pressure to get the rev above 4k rpm. I was able to continue on my journey to the workshop for a checkup. I was lucky that the fuel pump continued to work until it had to be replaced.
What does not kill you only makes you stronger.
#4
Posted 22 January 2015 - 02:09 PM
Kippei
  • THREAD STARTER
  • Premium member
    Kippei
    3rd Gear
    Author Image
    412
I suspecting my fuel filter is choked. However i cant measure the fuel pressure.
is $48 filter vs $280 assembly
#5
Posted 22 January 2015 - 02:57 PM
Acemundo
  • Premium member
    Acemundo
    2Fast2Furious
    Author Image
    28,499
instead of second guessing why not ask the mechanic to do the checks.
some symptoms are common across different parts failure, it would have been pure guessing if didn't check which part is malfunctioning.  like recently I keep getting dashboard warning for low coolant level.  at first I though is the coolant tank leak so I brought it to mechanic who advised it was instead the clip which broke.  after 1 day of using, the warning for low coolant came on again.  this time the symptom is still the same, but the part which is spoilt, is dfferent.
#6
Posted 22 January 2015 - 03:52 PM
Kenomi
  • Premium member
    Kenomi
    3rd Gear
    Author Image
    400
Just changed my fuel pump after 6.5yrs. It was not working when i was changing out my fuel filter. Costed me about 70dollars for the pump as the mechanics did not charge me for manpower as we not sure whether he damaged it.
Edited by Kenomi, 22 January 2015 - 03:53 PM.
#7
Posted 22 January 2015 - 03:55 PM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,034
W/shop that has fuel injector pressure tester kit should be able to carry out the pressure test.with ease.
Acemundo praised this
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
#8
Posted 22 January 2015 - 05:48 PM
Sunny
  • Premium member
    Sunny
    2Fast2Furious
    Author Image
    89,900
Kippei, on 18 Jan 2015 - 9:21 PM, said:
5.5 Years 110k KM.
generally change fuel filter around 60k km.
go workshop in 1/4 tank (not full tank)
Byteslurve praised this
#9
Posted 22 January 2015 - 06:00 PM
Unfair
  • Premium member
    Unfair
    6th Gear
    Author Image
    2,542
Actually never seen a need to change a fuel filter.
Unless you get your petrol from unknown sources, its actually quite clean.
Just remember to take a picture of the filter when it comes out to remind me to say "told you so" ! lol
Yewheng praised this
Pepi18022009 (For Fifa14/GTA V)
#10
Posted 01 October 2018 - 10:45 AM
Kenxon
  • Kenxon
    Author Image
    0
Im driving a toyota corolla,
Mechanic advise me to change to original fuel pump.. but i found HKT (japan) Fuel pump cheaper by > 50%.
anyone use HKT fuel pump? can advise if it is giving any problem or higher FC?
Thank you
#11
Posted 20 November 2018 - 02:28 AM
Rober14558
  • Rober14558
    Author Image
    0
This isn’t related (yet) but I couldn’t find any other relevant threads, my husband today has filled up my fiesta 1.5 eco boost with half a tank of unleaded petrol(there was already half a tank of diesel) however unlike when this normally happens he didn’t realise he made a mistake and then drove it 200miles! He then emailed me to say there may be an issue with my car it was misfiring, you don’t say....anyway he has to still drive the 200 miles home, we were told that as there was already half a tank of diesel if we now keep topping it up with more diesel this should be ok? Is this the case ? My husband is driving home and seems to think it’s running fine, should I still get it drained ???
#12
Posted 11 January 2019 - 03:36 PM
ismailmiller
  • ismailmiller
    Author Image
    3
Thank you
I went to check with stockist, toyota corolla original fuel pump only cost $200. Anyone knows any workshop which can replace this at a reasonable cost?
#13
ismailmiller
  • ismailmiller
    Author Image
    3
Thank you
#14
Posted 12 February 2019 - 05:51 PM
AndyHo
  • AndyHo
    Clutched
    Author Image
    45
I paid $220 to change orignal filter at poineer pt.
#15
Posted 30 April 2019 - 11:12 AM
ismailmiller
  • ismailmiller
    Author Image
    3
You mean you paid $220 to replace both the Fuel Pump and original filter including labour cost?
Anyone has a picture of a 2008 Toyota Corolla Altis fuel pump?
  • 1
Dynamics Mechanic Pte Ltd
Tec Auto Services Pte Ltd
Tec Auto Services Pte Ltd  |  Rating   Submit Review
Reviewed by mrhabit  |  Neutral Newbie
Had an accident with my Honda Jazz recently and was lucky to find Tec Auto Services and seek for their help for repair works. Great explanation from Kelvin and certainly not an easy task to fix the dent and paint damages on my car. Quotation was reasonable for what an excellent repair work they have provided. Kudos to the team :) » Read More
Revol Carz Garage
Revol Carz Garage  |  Rating   Submit Review
Reviewed by Lightsabre  |  3rd Gear
Since first try on their servicing 6 months ago, I re-engage them against for my servicing this morning.
Experience the friendly guys welcome me again this morning. Collected the car back in the afternoon and was briefed on what are the changes done.
Was very happy when I saw the bill as I expected the damages to be way higher. Cos' it is a major servi... » Read More
Related Motor Directory search on sgCarMart.com : Repair & Servicing
Quick Reply
Also tagged with these keywords: fuel , pump , filter , change
Tags: fuel, pump, filter, change
