Bluepica 4th Gear April 20, 2015 Share April 20, 2015 Mechanic says my ride aircon compressor giving out noise liao... its already 7yrs old ride. Any avante driver here change their aircon compressor before? How much does it cost and which aircon servicing shop should I go ? Need to change or just change oil? since only 3 more years to drive... ↡ Advertisement Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear April 20, 2015 Share April 20, 2015 Mechanic says my ride aircon compressor giving out noise liao... its already 7yrs old ride. Any avante driver here change their aircon compressor before? How much does it cost and which aircon servicing shop should I go ? Need to change or just change oil? since only 3 more years to drive... sometimes, you may not need to replace the entire compressor. it could be due to a worn magnetic clutch or something else. go get a second or even third opinion from an automotive aircon specialist. Mark-Cool (Ah Huat only), Tomika, L & Kim etc. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 20, 2015 Share April 20, 2015 Noise could be bearing worn out. Go to those air-con specialist like what a bro mentioned. Link to post Share on other sites More sharing options...
Bluepica 4th Gear April 21, 2015 Author Share April 21, 2015 ok! hope no need to change compressor Link to post Share on other sites More sharing options...
SGCMyippy Neutral Newbie November 8, 2015 Share November 8, 2015 Hi, does anyone recently having problem with the aircon compressor? I was told it cost $800 plus for the change. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear November 10, 2015 Share November 10, 2015 Hi, does anyone recently having problem with the aircon compressor? I was told it cost $800 plus for the change. which car model? $800+ for parts and labour? you might want to get a second or third opinion from those workshops i mentioned above. Link to post Share on other sites More sharing options...
Little_prince Supersonic November 10, 2015 Share November 10, 2015 go jb change. probably 800 rm nia Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear November 10, 2015 Share November 10, 2015 (edited) for those who want to venture up north for aircon repair, you may use the followings as reference: 1. TopOne (with a Clarion singboard), opposite Perling famous nasi lemak shop justion. go straight, middle of end lot. apart from air-con business, TopOne is also doing audio & accessories business. 197, Jln Simbang, Taman Perling. Tel: 019-7849313 2. Fresh Air at Jln Yahya Awal, located somewhere between the 2 Esso stations there (the one on the right used to be Mobil). It's sort of an all-in-one place for car repair as it's next to a tyre shop and there's a workshop behind too. all within the same compound. they are an approved center for aircon courses and exams. prices slightly high but acceptable, with proper vacuum machines to do the job. 3. Fresh Cool at Jln Tangki Air, that short dead-end road where there's an old Shell station at the junction, and somewhere opposite Bomba Larkin along Jln Tun Abdul Razak Susur 4 (famous for ah kuas! ). reasonable price but no vacuum machine for refrigerant. they can repair aircons of most types of cars and do compressor conversion job with the proper piping. Edited November 10, 2015 by Spinelli_ck 1 Link to post Share on other sites More sharing options...
Forte3737 5th Gear November 10, 2015 Share November 10, 2015 for those who want to venture up north for aircon repair, you may use the followings as reference: 1. TopOne (with a Clarion singboard), opposite Perling famous nasi lemak shop justion. go straight, middle of end lot. apart from air-con business, TopOne is also doing audio & accessories business. 197, Jln Simbang, Taman Perling. Tel: 019-7849313 2. Fresh Air at Jln Yahya Awal, located somewhere between the 2 Esso stations there (the one on the right used to be Mobil). It's sort of an all-in-one place for car repair as it's next to a tyre shop and there's a workshop behind too. all within the same compound. they are an approved center for aircon courses and exams. prices slightly high but acceptable, with proper vacuum machines to do the job. 3. Fresh Cool at Jln Tangki Air, that short dead-end road where there's an old Shell station at the junction, and somewhere opposite Bomba Larkin along Jln Tun Abdul Razak Susur 4 (famous for ah kuas! ). reasonable price but no vacuum machine for refrigerant. they can repair aircons of most types of cars and do compressor conversion job with the proper piping. Too risky. What if they screw up? Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear November 10, 2015 Share November 10, 2015 Too risky. What if they screw up? up to individuals. even local ADs or workshops do screw up sometimes. Link to post Share on other sites More sharing options...
M3oso 1st Gear November 10, 2015 Share November 10, 2015 My 9th years Mazda3's aircon compressor also giving tick-tick (close to tuck-tuck) sound, was on and off when the compressor kicks-in, I also thought it was bearing issue. I then went to Mark-cool, look for Ah Huat, he said it was the compressor running low with the aircon oil, he then performed a 15 mins job, using their machine to suck out gas, pump in aircon oil and gas. The tick-tick (or tuck-tuck) sound was gone since then. Total cost: $32.10. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged November 10, 2015 Share November 10, 2015 Hi, does anyone recently having problem with the aircon compressor? I was told it cost $800 plus for the change. i done for my old tucson at 500+ but i dont really recommend "my" aircon guy, though i had positive feedback initially. u can go to race course road to get from a/c parts shop - about 300 for compressor. Link to post Share on other sites More sharing options...
SGCMyippy Neutral Newbie November 12, 2015 Share November 12, 2015 Awesome.. mine car was a hyundai avante thou. The aircon shop at race course road sell genuine parts? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged November 12, 2015 Share November 12, 2015 Original korean brand ac compressor Link to post Share on other sites More sharing options...
SDK 1st Gear February 10, 2016 Share February 10, 2016 I had mine replaced to a new one for $400 including labour charge at Autobay @ Kaki Bukit. Link to post Share on other sites More sharing options...
Sash1401 4th Gear April 18, 2017 Share April 18, 2017 I had mine replaced to a new one for $400 including labour charge at Autobay @ Kaki Bukit. bro, can I noe which ws u went for the replacement of the air con compressor? Link to post Share on other sites More sharing options...
Kippei 3rd Gear April 18, 2017 Share April 18, 2017 bro, can I noe which ws u went for the replacement of the air con compressor? go sggarage. They will diagnose whether to change compressor or not Link to post Share on other sites More sharing options...
Sash1401 4th Gear April 21, 2017 Share April 21, 2017 go sggarage. They will diagnose whether to change compressor yishun branch or amk branch bro? ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
