Starushz Clutched June 25, 2015 Share June 25, 2015 Anyone knows which workshop does this service and how much does it cost? The screeching is damn irritating. ↡ Advertisement Link to post Share on other sites More sharing options...
RH1667 Hypersonic June 25, 2015 Share June 25, 2015 ya, please let me know so that we can ALL avoid this workshop! 19 Link to post Share on other sites More sharing options...
Mercury1 Turbocharged June 25, 2015 Share June 25, 2015 Why not remove the disc brake and that would resolve the screeching noise Anyone knows which workshop does this service and how much does it cost? The screeching is damn irritating. 2 Link to post Share on other sites More sharing options...
Mkl22 Twincharged June 25, 2015 Share June 25, 2015 most good workshops can do this. . putting brake grease on the BACK of the pads and the spring clips is a common practice all around the world. i have DIY it myself numerous times. i use copper grease or NAPA sil glyde. maybe you can get the workshop to chamfer the edges of the pads to reduce the noise too. 1 Link to post Share on other sites More sharing options...
Soya Supersonic June 25, 2015 Share June 25, 2015 (edited) ya, please let me know so that we can ALL avoid this workshop! Wahaha....tink TS meant anti squeal paste. He shld let us know which WS he replaced his pads so we can avoid coz that's quite SOP. Edited June 25, 2015 by Soya Link to post Share on other sites More sharing options...
Starushz Clutched June 25, 2015 Author Share June 25, 2015 Actually not all workshop do that. Sub standard mechanics. .the grease can also be washed away by those car wash pressure pump...any idea how much it cost? Link to post Share on other sites More sharing options...
Starushz Clutched June 25, 2015 Author Share June 25, 2015 most good workshops can do this. . putting brake grease on the BACK of the pads and the spring clips is a common practice all around the world. i have DIY it myself numerous times. i use copper grease or NAPA sil glyde. maybe you can get the workshop to chamfer the edges of the pads to reduce the noise too. To diy u must jack up and remove the wheels right? Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 25, 2015 Share June 25, 2015 Its the compound used in pad. Just change to original pad and sound will go away. Unless its a faint sound or else copper grease not gonna work. Link to post Share on other sites More sharing options...
Othello Supersonic June 25, 2015 Share June 25, 2015 Likewise, any one still putting a bit of engine oil on spark plug threads ? Or battery grease ? Link to post Share on other sites More sharing options...
Kb27 Supersonic June 25, 2015 Share June 25, 2015 (edited) Likewise, any one still putting a bit of engine oil on spark plug threads ? Or battery grease ? Good practice to put engine oil or anti-seize on plug thread. Otherwise, it may get stuck or corroded and jammed there, then big hassle, taking it out. Edited June 25, 2015 by Kb27 Link to post Share on other sites More sharing options...
Mkl22 Twincharged June 25, 2015 Share June 25, 2015 Likewise, any one still putting a bit of engine oil on spark plug threads ? Or battery grease ? still do it when i DIY the plugs. did it for my battery terminals and wheel lug nuts too. Link to post Share on other sites More sharing options...
Mustank Hypersonic June 25, 2015 Share June 25, 2015 title sounds dangerously misleading Link to post Share on other sites More sharing options...
Kippei 3rd Gear June 25, 2015 Share June 25, 2015 Brake pad need to grease on the contact parts but not on the fricition surface. Usually brake grease is hi temp and water proof Link to post Share on other sites More sharing options...
nazerath Turbocharged June 25, 2015 Share June 25, 2015 Likewise, any one still putting a bit of engine oil on spark plug threads ? Or battery grease ? Me ! Recently the workshop that I did my brakes actually left a grease thumbprint on my new pad. Sian still do it when i DIY the plugs. did it for my battery terminals and wheel lug nuts too. Lug nuts I don't put, what grease you use for those? 5 Link to post Share on other sites More sharing options...
Kippei 3rd Gear June 25, 2015 Share June 25, 2015 Good practice to put engine oil or anti-seize on plug thread. Otherwise, it may get stuck or corroded and jammed there, then big hassle, taking it out. Nickel plated still need to put? Link to post Share on other sites More sharing options...
Mkl22 Twincharged June 25, 2015 Share June 25, 2015 Me ! Recently the workshop that I did my brakes actually left a grease thumbprint on my new pad. Sian Lug nuts I don't put, what grease you use for those? lug nuts, NAPA sil-glyde Link to post Share on other sites More sharing options...
Ichibawa 5th Gear June 26, 2015 Share June 26, 2015 To solve brake squeal its either to change a less metallic brake pads, skim your brake disc if there are too many deep grooves or check if the mech who did the installation threw away the shims while at it. Link to post Share on other sites More sharing options...
Kb27 Supersonic June 26, 2015 Share June 26, 2015 Nickel plated still need to put? Plating can come off. It's just good practice when 2 metal surfaces touches each other, under high heat and tension. I've also seen corroded plugs. ↡ Advertisement Link to post Share on other sites More sharing options...
2024 Renault 5 E Tech
2016 Renault Kadjar
2016 Renault Kadjar
2024 5th Generation Renault Scenic
Brake Pads
Brake Pads
2024 6th Generation Renault Espace
Renault Kangoo
Renault Kangoo
