  • Search this thread
  • Reply to this topic
200 replies to this topic | 420 praises
#1
Posted 14 July 2015 - 02:38 PM
Stratovarius
  • THREAD STARTER
  • Premium member
    Stratovarius
    6th Gear
    Author Image
    4,552
Currently using the router provided by SH. Coverage is not very good and unable to receive any signal in MBR. Planning to get an android TV in MBR so gonna do something about the router. Router is in the living rm so any recommendation for router that is able to cover MBR? Saw quite a few Asus in Challenger. I'm not really keen on wifi extender though.
#2
Posted 14 July 2015 - 02:43 PM
Ender
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    69,918
Solid concrete wall attenuate the signal by a huge amount. That being said, my Asus AC68 router is able to give 2 to 3 bar signal on my tablet from the living room to the kitchen toilet, with one concrete wall in between.
Edited by Ender, 14 July 2015 - 02:43 PM.
You don’t stop running because you get old, you get old because you stop running.
#3
Posted 14 July 2015 - 02:45 PM
Vid
  • Premium member
    Vid
    2Fast2Furious
    Author Image
    132,779
Better buy a LAN cable from router to bedroom. Confirm good signal.
Holdenutessv and lausai88 praised this
#4
Posted 14 July 2015 - 02:52 PM
Evillusion
  • Premium member
    Evillusion
    2Fast2Furious
    Author Image
    51,755
wah....best suggestion......no drop in signal strength somemore....😂😂😂😂
Holdenutessv praised this
Together We stand Alone
#5
Posted 14 July 2015 - 02:54 PM
Alpha78
  • Premium member
    Alpha78
    6th Gear
    Author Image
    4,748
Buying a better router can sometimes be a futile exercise. If the walls are thick enough, the signal drop will be significant, which even the best routers cannot overcome.
For wireless repeaters, buy a dualband one, so that you can use one band to link to the master router, and the other band for your clients to connect. This way, there will not be the bandwidth halved problem when using single band repeaters.
I'm using this model at home, you can find at it Challenger, very good value for money.
http://www.dlink.com...s-access-point/
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
#6
Posted 14 July 2015 - 02:58 PM
Mason016
  • Mason016
    2Fast2Furious
    Author Image
    31,228
aside from wires running along the floor, ceiling hahaha [laugh]
#7
Posted 14 July 2015 - 03:00 PM
Holdenutessv
  • Premium member
    Holdenutessv
    NOS-ed
    Author Image
    10,916
Inexpensive and a good solution. [laugh]
Edited by Holdenutessv, 14 July 2015 - 03:00 PM.
Error 404: Signature Not Found
#8
Kusje
  • Kusje
    2Fast2Furious
    Author Image
    32,356
You live in one of the newer HDBs?
Your house might already have LAN cables installed in the wall socket... Just need to do some modification.
Actually, most of the newer condos also should have it.
That is all.
#9
Posted 14 July 2015 - 03:04 PM
Vid
  • Premium member
    Vid
    2Fast2Furious
    Author Image
    132,779
It is the best solution. If TS wants to stream movies on his Android TV, he needs a good connection. Wifi just cannot make it.
#10
Posted 14 July 2015 - 03:05 PM
Evillusion
  • Premium member
    Evillusion
    2Fast2Furious
    Author Image
    51,755
can hack floor.....hide the ugly wires......hahaha.😂😂😂😂! I thought there was already another thread about using repeaters?
#11
Mustank
  • Mustank
    2Fast2Furious
    Author Image
    107,905
inside I think is cat6 wire
woohoo!!!! eternet power!!!!
TS: to check, open up the telephone port in the room,
2 screws only
 then see the wire connecting to the telephone port
if you see 8 small different colour wires inside one thicker wire
looks like this
you can shout huat ah!!!! [laugh]
you just strike cat 6 wire jackpot
you can cable up the whole house and enjoy your farm liao [sly]
if really got 8 wires like this one
you just need to buy the female keystone from amazon (US$2)
and a punchdown tool (US$12)
I strongly recommend:
1) Best alternative: run eternet cables (now is cat 6 most cost effective)
but you need to check whether your telephone ports in the rooms are actually eternet wires (I am using cat 6 and eternet wire interchanagebly. cat 6 is the current cost effective standard for eternet wire)
2) 2nd choice: run eternet wires from router to room direct
but dammn ugly
3) powerplug solutions
4) range extenders (worse solution)
Edited by Mustank, 14 July 2015 - 03:14 PM.
Ender praised this
#12
Posted 14 July 2015 - 03:08 PM
KilluaX
  • KilluaX
    1st Gear
    Author Image
    64
Power plug is another option.
http://www.tp-link.c...rline/TL-PA211/
#13
Posted 14 July 2015 - 03:17 PM
Mustank
  • Mustank
    2Fast2Furious
    Author Image
    107,905
I am using this for one of my rooms because no way can lay wire to that room
but good enough to support 3 units of 1080p IP cctv
#14
Posted 14 July 2015 - 03:24 PM
Mustank
  • Mustank
    2Fast2Furious
    Author Image
    107,905
I bought a new ac router even though I have bgn router
knn, only increase range by a mere 20%, waste my money
#15
Posted 14 July 2015 - 03:28 PM
Alpha78
  • Premium member
    Alpha78
    6th Gear
    Author Image
    4,748
Bro, recommend homeplugs with caution. Sometimes they don't give good throughput if the wire quality is bad. I had one pair which worked in my old place, but give crap performance at my current place.
Then I tried buying another pair to add on. Worse, it interfered with the existing pair, and both gave very crap throughput. Luckily I managed to exchange the new pair for another wireless product.
#16
Vid
  • Premium member
    Vid
    2Fast2Furious
    Author Image
    132,779
That's why I said lay LAN cables. Not enough ports on router can just buy a cheap switch. Don't waste time on those technology.
#17
Posted 14 July 2015 - 03:33 PM
Mustank
  • Mustank
    2Fast2Furious
    Author Image
    107,905
heh heh I using tplink mini 500 or something like that
the lan lan alternative to lan cable
but heng, can use
the most run lan cable outside the house window [laugh]
#18
Posted 14 July 2015 - 03:36 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    54,247
Ask you guys, where to get phone-Ethernet adapter like this...
I know Amazon is selling but locally does anyone sell? Like Element14?
Feel so rich. Or just an illusion?
#19
Posted 14 July 2015 - 03:39 PM
Ender
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    69,918
Got to engage spiderman to lay the outside cable.  [laugh]
Can try carpet the house, and lay the cable underneath it.
Does this work? the number of small cables is different for the phone and ethernet.
#20
Posted 14 July 2015 - 03:41 PM
Mustank
  • Mustank
    2Fast2Furious
    Author Image
    107,905
bro telephone keystone looks like this
only connect 4 out of 8 of the LAN cable
so even if you use the adaptor also no use one
you need to change the telephone keystone to LAN keystone
can one
use tek koh to do, 2 man job
Quick Reply
Tags: home, wifi, router, better and 1 more...
