Kurty Supercharged August 18, 2016 Share August 18, 2016 Questions are: Is there any noise when moving or going over undulations? Does the car feel "floaty" when traveling at higher speed? Does your steering feel "loose"? If the answers are all "No", save your money and do nothing. nope, no noise. floaty, nope. I don't travel fast. only 110km at most, I am a safe driver. steering, nope. small and nice grip. haha I just wanna add more comfort, thought since I renew for another 10 years. and I travel daily on road for 100km, safety and comfort comes first. ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Supersonic August 18, 2016 Share August 18, 2016 nope, no noise. floaty, nope. I don't travel fast. only 110km at most, I am a safe driver. steering, nope. small and nice grip. haha I just wanna add more comfort, thought since I renew for another 10 years. and I travel daily on road for 100km, safety and comfort comes first. For rear shocks, does it sink when you took over the car? For shocks, i will change it every 5 yrs leak or no leak. Spring has no lifespan. Maybe after 20 yrs need to change from metal fatigue. Link to post Share on other sites More sharing options...
Ahgong Supercharged August 18, 2016 Share August 18, 2016 sorry, wanna ask about absorbers etc.. as I renew my car for another 10years. 150k mileage.. it served me well and I thought I should reward it. my lower arms and bush are fine. Had a check and replaced engine mounting - changed. bearing just changed.. as for shock absorber - front, used for 10 years. rear, for 5 years. absorber mount, need to change? does spring has a lifespan? funny is my absorber no leak.. still ok, just the rear tyre will hit when I ferry 2 adult at rear.. using wider tyre. don't ask me to bring to workshop.. been to a few and they don't even look.. just tell me to change everything as an answer hmm... this one is really subjective to the comfort level of the driver. how i check whether need to change or not is to go to the front, use my hands and weigh down on the bonnet as low as i can go and let go. if the car bounces like a baby rocker, it is time to change. if it comes up, and stops, within one or two bounces, the suspension and springs are still good. Same goes for the rear. then using your gut feel, if your bare hands can weigh down on the car until it is very low, then your coils/spring could be gone liow. if the resistance is high when you try to weigh down, then the coil/spring is still good. but again, that is my two cents. hope it helps. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic August 18, 2016 Share August 18, 2016 Just to add. please change your shock mounts if you decided to change your shock whether the look OK or not. Shock mounts are wear and tear items which might not have visual indication to change. Learnt the hard way. 2 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 18, 2016 Share August 18, 2016 Just to add. please change your shock mounts if you decided to change your shock whether the look OK or not. Shock mounts are wear and tear items which might not have visual indication to change. Learnt the hard way. agree bro, no need pay additional labor. that mount a fraction of shocks. ive changed mount, bump stop n shock as a set. to add to those who say if shock bounces once or twice after depress n release, it could b misleading, as mine was lidat but actually oredi depressed due to leak, so do observe carefully. initially didnt think much about car abit slanted one side at rear cos thot carpark surface not as levelled. then came a wet patch in wheel well but also happened to be wet weather, then finally changed after drove pass those paving blocks at hdb hub n made lotsa clocking noise. Link to post Share on other sites More sharing options...
Kurty Supercharged August 18, 2016 Share August 18, 2016 hmm... this one is really subjective to the comfort level of the driver. how i check whether need to change or not is to go to the front, use my hands and weigh down on the bonnet as low as i can go and let go. if the car bounces like a baby rocker, it is time to change. if it comes up, and stops, within one or two bounces, the suspension and springs are still good. Same goes for the rear. then using your gut feel, if your bare hands can weigh down on the car until it is very low, then your coils/spring could be gone liow. if the resistance is high when you try to weigh down, then the coil/spring is still good. but again, that is my two cents. hope it helps. I think my rear is gone again.. I did a simple test and the rear bounce easily.. Does spring need to change? Do they had a lifespan? Just to add. please change your shock mounts if you decided to change your shock whether the look OK or not. Shock mounts are wear and tear items which might not have visual indication to change. Learnt the hard way. Mount is front and rear or only the front? I never change in my 10 years.. Link to post Share on other sites More sharing options...
Angcheek Hypersonic August 18, 2016 Share August 18, 2016 Just to add. please change your shock mounts if you decided to change your shock whether the look OK or not. Shock mounts are wear and tear items which might not have visual indication to change. Learnt the hard way. You bounced too much in the car la what you been doing 3 1 Link to post Share on other sites More sharing options...
Keei 2nd Gear August 18, 2016 Share August 18, 2016 (edited) My car feels wobbly at low speed(That is engage drive & releasing the brake without stepping the accelerator). But going thru bumps & high speed, it feels fine. I even pressed on the car & it does not rock like a boat which typically means that the shocks are gone. Confused if the shocks are gone or not. Edited August 18, 2016 by Keei 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic August 18, 2016 Share August 18, 2016 Springs are generally not considered a wear and tear part. Never hear of people changing springs, especially at your mileage. Depending on your car design, just consider the shock mount to be part of shock absorber assembly and change them as a set and you ahould be fine. Rear will have additional shock stopper which comes in play when ur rear suspension bottoms out at times. Which is advisible to change too. Your 10yrs not changing any of the suspension part, by itself, is alreasy a good enough reason to change them. Some people will say that u have been lucky...but i say dun push it.... Suspension is integral part of road holding and safety too. I think my rear is gone again..I did a simple test and the rear bounce easily..Does spring need to change? Do they had a lifespan?Mount is front and rear or only the front?I never change in my 10 years.. 2 Link to post Share on other sites More sharing options...
Vratenza Supersonic August 18, 2016 Share August 18, 2016 I lent my car to @Porker and @Radx for 1 night only...... Already told them to be gentle..... You bounced too much in the car la what you been doing Link to post Share on other sites More sharing options...
Vratenza Supersonic August 18, 2016 Share August 18, 2016 maybe is your engine mount. My car feels wobbly at low speed(That is engage drive & releasing the brake without stepping the accelerator). But going thru bumps & high speed, it feels fine. I even pressed on the car & it does not rock like a boat which typically means that the shocks are gone. Confused if the shocks are gone or not. Link to post Share on other sites More sharing options...
Kurty Supercharged August 19, 2016 Share August 19, 2016 My car feels wobbly at low speed(That is engage drive & releasing the brake without stepping the accelerator). But going thru bumps & high speed, it feels fine. I even pressed on the car & it does not rock like a boat which typically means that the shocks are gone. Confused if the shocks are gone or not. yeah, like the other bro had said, it probably your engine mount. time to change, after changing, you will realise your car is much quieter. Link to post Share on other sites More sharing options...
Kurty Supercharged August 19, 2016 Share August 19, 2016 Springs are generally not considered a wear and tear part. Never hear of people changing springs, especially at your mileage. Depending on your car design, just consider the shock mount to be part of shock absorber assembly and change them as a set and you ahould be fine. Rear will have additional shock stopper which comes in play when ur rear suspension bottoms out at times. Which is advisible to change too. Your 10yrs not changing any of the suspension part, by itself, is alreasy a good enough reason to change them. Some people will say that u have been lucky...but i say dun push it.... Suspension is integral part of road holding and safety too. shock stopper? any picture? I did change during my ownership, the rear. mind me asking, why always the rear is gone? I thought engine is heavy, hence it should be the first to go off. Link to post Share on other sites More sharing options...
Vratenza Supersonic August 19, 2016 Share August 19, 2016 the one on the right is worn. Not too sure why but my experience with all my cars is that the rear seem to wear out faster. My theory is that the rear takes more abuse and it usually has more length of travel compared to the front. The front is just the engine weight, the rear has to handle full load passengers with boot load as well. shock stopper? any picture? I did change during my ownership, the rear. mind me asking, why always the rear is gone? I thought engine is heavy, hence it should be the first to go off. Link to post Share on other sites More sharing options...
Ahgong Supercharged August 19, 2016 Share August 19, 2016 the one on the right is worn. Not too sure why but my experience with all my cars is that the rear seem to wear out faster. My theory is that the rear takes more abuse and it usually has more length of travel compared to the front. The front is just the engine weight, the rear has to handle full load passengers with boot load as well. u carry a lot of passengers is it? that could also be why it wears out faster. higher load being hauled around lah! Link to post Share on other sites More sharing options...
Keei 2nd Gear August 19, 2016 Share August 19, 2016 maybe is your engine mount. Went to workshop & had the engine mount checked. But they say engine mount is ok. Link to post Share on other sites More sharing options...
Kurty Supercharged August 19, 2016 Share August 19, 2016 u carry a lot of passengers is it? that could also be why it wears out faster. higher load being hauled around lah! not true.. always me and my wife most of the time.. I'm on wider tyre, 195.. the stock tyre should be 175 only.. anyway look at this, saw some Malaysia mechanic are doing this for wider tyre. basically they insert a PU stopper while removing certain portion of the shock stopper. Link to post Share on other sites More sharing options...
Vratenza Supersonic August 19, 2016 Share August 19, 2016 my hybrid battery at the back, so kind of explains it. u carry a lot of passengers is it? that could also be why it wears out faster. higher load being hauled around lah! ↡ Advertisement Link to post Share on other sites More sharing options...
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
Teana repair/parts
Teana repair/parts
Kia Cerato Variant 2 persistent overheating issue
Any recommended workshop with reasonable labour charges?
