Vratenza Supersonic August 19, 2016 Share August 19, 2016 the original stopper is meant to be progressive in depression force so that when you bottom out it is not so jarring. If the mechanic put this PU stopper, once you bottom means is a damn hard "thuc!" sound and car will vibrate accordingly. But I guess no choice if want to put bigger and wider rims/tyre so that you will not bottom out so often. the shock lifespan will deteriorate very quickly as well. But I guess good business for the workshop. not true.. always me and my wife most of the time.. I'm on wider tyre, 195.. the stock tyre should be 175 only.. anyway look at this, saw some Malaysia mechanic are doing this for wider tyre. basically they insert a PU stopper while removing certain portion of the shock stopper. ↡ Advertisement Link to post Share on other sites More sharing options...
Kurty Supercharged August 19, 2016 Share August 19, 2016 the original stopper is meant to be progressive in depression force so that when you bottom out it is not so jarring. If the mechanic put this PU stopper, once you bottom means is a damn hard "thuc!" sound and car will vibrate accordingly. But I guess no choice if want to put bigger and wider rims/tyre so that you will not bottom out so often. the shock lifespan will deteriorate very quickly as well. But I guess good business for the workshop. must praise you, you are very knowledgeable, so with this method, it helps? cause I can't find the rational despite the seller elaborate very clearly to me.. it only cost rm40 with post.. Link to post Share on other sites More sharing options...
Vratenza Supersonic August 19, 2016 Share August 19, 2016 you lowered your car too? Depends if you are experiencing any issues with your current rim/tyre/suspension setup. If you are not experiencing any tyre rubbing the fenders or frequent bottoming from the slightest of humps, I guess you can give it a miss. Converse is true too. must praise you, you are very knowledgeable, so with this method, it helps? cause I can't find the rational despite the seller elaborate very clearly to me.. it only cost rm40 with post.. 1 Link to post Share on other sites More sharing options...
Kurty Supercharged August 19, 2016 Share August 19, 2016 you lowered your car too? Depends if you are experiencing any issues with your current rim/tyre/suspension setup. If you are not experiencing any tyre rubbing the fenders or frequent bottoming from the slightest of humps, I guess you can give it a miss. Converse is true too. nah.. stock set up, just wider tyre. basically without any passenger in rear, it is ok. once I got 2 passengers at rear, the right wheel will fit the fender. is there any good brand of absorber. currently on kyb excel g, thinking of going this proride heavy duty absorber Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged August 19, 2016 Share August 19, 2016 my take is if you change 1 item by 1 item... it will incur more cost..... suspensions takes a lot of beatings so if now change stopper, maybe next time absorber leak or bushing gone.... etc since renew COE liao.. i will just change 1 shot.. save time also Link to post Share on other sites More sharing options...
Vratenza Supersonic August 19, 2016 Share August 19, 2016 In this case there are other options such as rolling the fender. My experience is mainly with bilsteins. They are good even with stock springs. Firmer ride with much better body control without sacrificing much comfort. nah.. stock set up, just wider tyre. basically without any passenger in rear, it is ok. once I got 2 passengers at rear, the right wheel will fit the fender. is there any good brand of absorber. currently on kyb excel g, thinking of going this proride heavy duty absorber Link to post Share on other sites More sharing options...
nivla94 Neutral Newbie October 26, 2018 Share October 26, 2018 hi everyone. does anyone know the price of shock mount for ncp42 vios 1st gen? my mechanic quoted me around Myr3** a pair. and KYB front absorber myr39* a pair. sorry if asking in the wrong forum. just don't wanna get chop hard. Link to post Share on other sites More sharing options...
inlinesix Supersonic October 26, 2018 Share October 26, 2018 hi everyone. does anyone know the price of shock mount for ncp42 vios 1st gen? my mechanic quoted me around Myr3** a pair. and KYB front absorber myr39* a pair. sorry if asking in the wrong forum. just don't wanna get chop hard. Better check with Toyota stockist. I don't think there are a lot of NCP42 owner here. If there is any, it might be very old information. ↡ Advertisement Link to post Share on other sites More sharing options...
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
Teana repair/parts
Teana repair/parts
Kia Cerato Variant 2 persistent overheating issue
Any recommended workshop with reasonable labour charges?
