Auto101 Clutched June 6, 2016 Author Share June 6, 2016 KYB Excel-G Gas Shock Absorber replacements for this Honda Stream. Special promotion discounts for selected models! Call us to enquire now! Link to post Share on other sites More sharing options...
Auto101 Clutched June 10, 2016 Author Share June 10, 2016 Our latest Bosch ACS 651 Aircon Servicing Machine utilized on a Honda Fit! Aircon Servicing package for: Asian & American car makes - $108Most European car makes - $138 Package includes: Refrigerant extraction and recycling Drainage of old oil, Evacuation and leak testing Fresh oil and UV additive charging Accurate filling with refrigerant Cabin Filter replacement A/C Disinfectant Link to post Share on other sites More sharing options...
Auto101 Clutched June 14, 2016 Author Share June 14, 2016 Clutch replacement on a Mitsubishi Lancer CS3. Link to post Share on other sites More sharing options...
Auto101 Clutched June 15, 2016 Author Share June 15, 2016 A Honda Vezel Hybrid in for GLADEN's mid-season speaker package promotion as well as sound proofing of all 4 doors. Link to post Share on other sites More sharing options...
Auto101 Clutched June 17, 2016 Author Share June 17, 2016 BMW F10 in for servicing with MPM Premium Synthetic 5W40 C3! Link to post Share on other sites More sharing options...
Auto101 Clutched June 21, 2016 Author Share June 21, 2016 Our latest Bosch ACS 651 Aircon Servicing Machine utilized on a Kia Forte! Aircon Servicing package for: Asian & American car makes - $108Most European car makes - $138 Package includes:- Refrigerant extraction and recycling- Drainage of old oil, - Evacuation and leak testing - Fresh oil and UV additive charging - Accurate filling with refrigerant - Cabin Filter replacement- A/C Disinfectant Link to post Share on other sites More sharing options...
Auto101 Clutched June 23, 2016 Author Share June 23, 2016 Engine Oil 101 Do you know what's the 'C3' on our MPM Premium Synthetic 5W40 'C3' Stands for? And more importantly, do you know what kind of oil is needed to go into your car?? The 'C3' actually comes from the classifications of engine oils laid down by European Automobile Manufacturers' Association (ACEA). Besides C3, this particular oil also meets the more common A3/B4. Generally, the classifications are categorize into: A/B refers to Gasoline/Diesel engine oils C refers to Catalyst Compatibility oils E refers to Heavy Duty Diesel engine oils There are other classifications such as A5/B5, A1/B1, C1, C2, C4... and etc. Please look out for our future post where we will elaborate more on other specifications. ACEA 'C3' oils are mid-SAPS (Sulphated Ash, Phosphorus and Sulphur) lubricants. They are designed for use in gasoline or light duty diesel engines where after-treatment systems such as Diesel Particulate Filters (DPFs) and Three Way Catalysts (TWC) are used. In layman terms, with less SAPS content in engine oils, it will reduce clogging of your after-treatment exhaust systems and thus these oils will help to increase the lifespan of the DPF and TWC after-treatment systems. Besides ACEA classifications, MPM Premium Synthetic 5W40 C3 engine oil also meets the requirements laid down by BMW Longlife-04 and Mercedes Benz Longlife 229.51 and is suitable for Euro 4 engines according to the ACEA C3 standard. This engine oil meets the following specifications: ACEA A3/B4 / C3 API SN/CF BMW LL-04 Ford WSS-M2C-917A MB-Approval 229.31 / 229.51 Porsche A40 Renault RN 0700 / RN 0710 VW 502.00 / 505.00 / 505.01 So what does the above mean to a normal driver? In the current technologies of engine and after-treatment exhaust system development, its no longer a search for the BEST oil but rather on the CORRECT oil meant for you car engine. Link to post Share on other sites More sharing options...
Auto101 Clutched June 27, 2016 Author Share June 27, 2016 Evaporator (Cooling Coil) replacement and A/C Servicing with the Bosch ACS 651 Aircon machine done on this Chevrolet Cruze! Link to post Share on other sites More sharing options...
Auto101 Clutched July 1, 2016 Author Share July 1, 2016 Possibly the most versatile Dashcam available at the moment. The LK-9370 WD is equipped with all imaginable options, like Wifi, G-sensor, Motion detection and a big 3.5 inch LCD touchscreen. These features make the LK-9370 WD one of the best dashcams in the world. More information available at the link below: http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=101386 Link to post Share on other sites More sharing options...
Auto101 Clutched July 5, 2016 Author Share July 5, 2016 Engine Oil 101 This chapter we will share more in detail about MPM Premium Synthetic 5W30 'ESP' Engine oil and why you should use this oil for some cars that you are driving. 'ESP' stands for Emission System Protection. As the name suggests, this oil is has been specially developed for the latest generation of VAG, BMW and Mercedes Benz engines with or without a particulate filter for diesel engines (DPF) and catalytic converter for petrol engines This engine oil is designed for excellent performance, protection and improve fuel economy. Its able to perform at extreme high and low temperatures and protect against engine wear and sludge. This oil also conforms to the 'C3' specifications which we have discussed in our previous post and obtained various OEM approvals such as - ACEA C3 - BMW LL-04 - MB-Approval 229.51 - Porsche C30 - VW 504.00 / 507.00 Outdated engine oil technology is not designed to limit the amount of oil-derived Suphated Ash, Phosphorous & Sulphur (SAPS) in the exhaust, which could clog the DPF and prevent it from capturing particulate material effectively. Therefore if you are driving a car with advanced exhaust treatment system, this engine oil or oils with the Catalyst Compatibility specifications is a necessity for your car. *Note this oil is not suitable for the 1st generation VW TDI engines with pump injector nozzles without an extended oil-change interval and R5 and V10 TDI engines. Link to post Share on other sites More sharing options...
Auto101 Clutched July 15, 2016 Author Share July 15, 2016 Clutch replacement on a Subaru Impreza GD5! Link to post Share on other sites More sharing options...
Auto101 Clutched July 25, 2016 Author Share July 25, 2016 Bentley Continental SuperSports in for oil change as well as Engine and Cabin air filter replacements. All 13 liters of MPM High Performance "Street" 0W40 engine oil glory! Link to post Share on other sites More sharing options...
Auto101 Clutched July 29, 2016 Author Share July 29, 2016 Air-con recovery and service done on this Mazda CX-7 with our latest Bosch ACS 651 machine! Air-con Servicing packages for: Asian & American car makes - $108Most European car makes - $138 Package includes: Refrigerant extraction and recycling Drainage of old oil, Evacuation and leak testing Fresh A/C compressor oil charging Accurate filling with refrigerant ***FREE*** UV Performance Additive***FREE*** A/C Disinfectant***FREE*** Cabin Filter replacement Link to post Share on other sites More sharing options...
Lemonstan Neutral Newbie August 2, 2016 Share August 2, 2016 Hi. My Nissan NV200 aircon is not working already. Air still a little cold only and sometimes not cold at all. Can it be fixed at your workshop? Please let me know the cost and SMS to me at 9 six six 1 4 one one 8 if possible. Appreciate it. Thanks. :) Link to post Share on other sites More sharing options...
Auto101 Clutched August 2, 2016 Author Share August 2, 2016 Hi. My Nissan NV200 aircon is not working already. Air still a little cold only and sometimes not cold at all. Can it be fixed at your workshop? Please let me know the cost and SMS to me at 9 six six 1 4 one one 8 if possible. Appreciate it. Thanks. :) Hi Bro, U have got a PM Link to post Share on other sites More sharing options...
Auto101 Clutched August 5, 2016 Author Share August 5, 2016 Every car that comes to us for servicing goes through our Real 26 Vehicle Checks system where we thoroughly inspect almost every component of your car, making sure it is road worthy and safe. This Subaru Legacy came in for servicing with a slightly bent drive shaft, and a blown boot. We spotted this fault, and advised the owner to have it replaced. He permitted, and so we did. Here're a few pictures of the old and new drive shaft removed and installed respectively. With every servicing, your records will be data-based and customers will receive a printed report of what has been checked and done together with the servicing. Customers can request for their records to be pulled out whenever a situation requires (e.g. when you are selling your car). We will also send out service reminders via e-mail and SMS on the 5th month after your last date of service. A valued-added service brought to you from us @ Auto 101 (Singapore)! Link to post Share on other sites More sharing options...
Auto101 Clutched August 11, 2016 Author Share August 11, 2016 A/C Compressor replacement done on this Honda Fit. Aircon blows nice and cold right now! Link to post Share on other sites More sharing options...
Auto101 Clutched August 25, 2016 Author Share August 25, 2016 Link to post Share on other sites More sharing options...
Audio Shop Recommendation
Car air-con
Car air-con
Volvo Servicing
Volvo Servicing
RE :Jaguar Owners Servicing
Home Aircon
Home Aircon
Battery Voltage up & down
My EV journey to the i4
