Happily1986 5th Gear April 4, 2012 Share April 4, 2012 Don't waste your $$ getting higher than 25mbps, international connection speed is only 15mbps max for most websites. The higher speed only allows u to connect faster to local partner sites, else it is also capped at 15mbps. I upgraded from 15mbps singtel broadband to 25mbps singel fiber optics 1 year back ago and never looked back, ran connectivity test via speedtest.net and found that latency definitely improved typically 2ms vs 30+, download speed improved from 10ish to near 20ish, bonus is that upload speed increased dramatically from 0.5 to 10ish. To sum it up, fiber optic experience lower latency, faster download and even faster upload. Webpages load pretty fast as a result and I have been doing more time on torrents Definitely worth the upgrade especially with free opennet installation. Singtel Speed Guide ↡ Advertisement Link to post Share on other sites More sharing options...
Fireball0088 5th Gear April 4, 2012 Share April 4, 2012 I just got it installed last week with on 50mbps. Previously on ADSL, so was kinda upgrade to fibre optics. So far so good. Speed is fast, stable, torrent climb is so much faster. 10mins finished one movie, few hours finished one whole season. From what I've read, the wireless wifi capability of the 2wire modem (black color) they give is up to a speed 70mbps. So if you subscribed to 200mbps, then it's kinda wasted if your laptop/desktop is not connected direct. That's one reason why I didn't take up the higher speeds. Also, if you're previously on singtel ADSL using home charger to connect to another room for mio tv, that technology will not work. Will have to do a lan cable trunking to other rooms. Yes, I'm pretty satisfied with the plan now. Recommended. what do you mean by "home charger"? home plug? the 2wire modem is using G or N network? Link to post Share on other sites More sharing options...
Fireball0088 5th Gear April 4, 2012 Share April 4, 2012 Singtel Speed Guide in short what Kax2 said is true Link to post Share on other sites More sharing options...
Joseph22 Turbocharged April 4, 2012 Share April 4, 2012 I just got it installed last week with on 50mbps. Previously on ADSL, so was kinda upgrade to fibre optics. So far so good. Speed is fast, stable, torrent climb is so much faster. 10mins finished one movie, few hours finished one whole season. From what I've read, the wireless wifi capability of the 2wire modem (black color) they give is up to a speed 70mbps. So if you subscribed to 200mbps, then it's kinda wasted if your laptop/desktop is not connected direct. That's one reason why I didn't take up the higher speeds. Also, if you're previously on singtel ADSL using home charger to connect to another room for mio tv, that technology will not work. Will have to do a lan cable trunking to other rooms. Yes, I'm pretty satisfied with the plan now. Recommended. you are talking about just Mio TV or are you talking about the internet connection? Mio TV didnt try, but wall plug for internet is working for me. Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 4, 2012 Share April 4, 2012 you are talking about just Mio TV or are you talking about the internet connection? Mio TV didnt try, but wall plug for internet is working for me. what homeplugs are you on? i am thinking of routing cat5e cable via existing trunking or operate a pair of homeplugs. i kinda regret not getting the ASUS NT-56U. but then again paying almost 200 for a router is . i only got my Engenius ESR9850 for $65. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged April 4, 2012 Share April 4, 2012 what homeplugs are you on? i am thinking of routing cat5e cable via existing trunking or operate a pair of homeplugs. i kinda regret not getting the ASUS NT-56U. but then again paying almost 200 for a router is . i only got my Engenius ESR9850 for $65. home plug from Aztech or TP link lor.. they superced our power plug as cat5E cable. Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 4, 2012 Share April 4, 2012 home plug from Aztech or TP link lor.. they superced our power plug as cat5E cable. i am hesitant to use cos i got too many appliances with invertor technology. Link to post Share on other sites More sharing options...
Sgspurs 1st Gear April 9, 2012 Share April 9, 2012 what homeplugs are you on? i am thinking of routing cat5e cable via existing trunking or operate a pair of homeplugs. i kinda regret not getting the ASUS NT-56U. but then again paying almost 200 for a router is . i only got my Engenius ESR9850 for $65. Got it installed last week. Modem in living room. Wireless there can reach 60+ mbps (local) but my study room only hit 2-5 mbps. Suspect due to a wall in between. I need to make a sharp 90 degrees turn before reaching my study area. Should I get 1. The router above and replace the singnet modem in the living room ? 2. Get the above router but put near my study area. Need to pair this and the singnet modem ? 3. Get the booster plug ? Does it work with fibre ?? All advice appreciated ! Thanks. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 9, 2012 Share April 9, 2012 Got it installed last week. Modem in living room. Wireless there can reach 60+ mbps (local) but my study room only hit 2-5 mbps. Suspect due to a wall in between. I need to make a sharp 90 degrees turn before reaching my study area. Should I get 1. The router above and replace the singnet modem in the living room ? 2. Get the above router but put near my study area. Need to pair this and the singnet modem ? 3. Get the booster plug ? Does it work with fibre ?? All advice appreciated ! Thanks. bro what speed did you subscribe to? Link to post Share on other sites More sharing options...
Sgspurs 1st Gear April 9, 2012 Share April 9, 2012 100 mbps Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 9, 2012 Share April 9, 2012 dont think the wireless is because of the wall that give you 2 to 5 mbps. there is something wrong liao. Link to post Share on other sites More sharing options...
Sgspurs 1st Gear April 9, 2012 Share April 9, 2012 dont think the wireless is because of the wall that give you 2 to 5 mbps. there is something wrong liao. Any idea ? But in another room which has a line of sight to the router 5 - 8 metres away can get 30 - 40 mbps. Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 9, 2012 Share April 9, 2012 Any idea ? But in another room which has a line of sight to the router 5 - 8 metres away can get 30 - 40 mbps. do you have a smart phone or a laptop? try to connect from same spot and see whether connectivity is similar and you will know whether it is router or adapter problem. Link to post Share on other sites More sharing options...
Saycheese78 Clutched April 9, 2012 Share April 9, 2012 Able to buy a repeater for this frequency? Link to post Share on other sites More sharing options...
LMFAO 1st Gear April 9, 2012 Share April 9, 2012 Any idea ? But in another room which has a line of sight to the router 5 - 8 metres away can get 30 - 40 mbps. Get a home plug or repeater to resolve the issue... Link to post Share on other sites More sharing options...
Sgspurs 1st Gear April 10, 2012 Share April 10, 2012 Get a home plug or repeater to resolve the issue... I guess so. Shall get the homeplug and update everyone Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 10, 2012 Share April 10, 2012 Able to buy a repeater for this frequency? are you prepared to lay cable for a wired repeater i.e. wired bridge? else a wireless bridge meaning a second router positioned as a wireless repeater will effectively have its throughput halved because it now has to conduct comms for secondary router to primary router on top of usual routing traffic. and as usual, the network throughput will drop to the lowest throughput link so your entire wireless lan throughput has effectively been halved. Link to post Share on other sites More sharing options...
RadX Moderator July 20, 2012 Share July 20, 2012 House gonna be wired up on 14 Aug 2012. Wh fibre in your experience using so far tops? Benefits? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
MyRepublic Vs Whizzcomms
I got charged for Global SMS by Singtel, and they cannot do anything!
yuu Rewards Club app
Broadband provider WhizComms’ server breached by third party; customers’ information stolen
StarHub customers affected by home broadband disruption can register for one-time 20% rebate on monthly fee
M1 fiber broadband down? 21 Dec 2020
