Ahgong Supercharged December 18, 2015 Share December 18, 2015 when you are dealing with OPC, esp related to number plate, it is a pain, due to the security seal.was told to replace this during inspection. but to replace means i gotta spend $200 to get the seal broken at LTA, replace the plates then go back to LTA to reapply the seal. that is extremely expensive for plate replacement. are there cheaper alternative besides hand painting the numbers with white paint?i heard of stickers. but scared those will peel after awhile.and BTW, how much does those stickers cost?any idea?Any advise is welcomed. ↡ Advertisement Link to post Share on other sites More sharing options...
1fast1 Supersonic December 18, 2015 Share December 18, 2015 (edited) What's wrong with hand painting? Got markings to guide some more. Edited December 18, 2015 by Turboflat4 1 Link to post Share on other sites More sharing options...
Ahgong Supercharged December 18, 2015 Author Share December 18, 2015 What's wrong with hand painting? Got markings to guide some more. i have seen it being done on lorries and pick up before. it is fuggly (to put it non-offensively) Link to post Share on other sites More sharing options...
Steptronic Supercharged December 18, 2015 Share December 18, 2015 Better to talk to one of those makers, they will guide you all the way through! Link to post Share on other sites More sharing options...
Ahgong Supercharged December 18, 2015 Author Share December 18, 2015 Better to talk to one of those makers, they will guide you all the way through! anyone here to recommend? Link to post Share on other sites More sharing options...
Optramagnum 6th Gear December 18, 2015 Share December 18, 2015 Use liquid paper sua.. Wipe the plate clean clean first, then slowly do loh.. Should be quite ok one.. 1 Link to post Share on other sites More sharing options...
Kusje Supersonic December 18, 2015 Share December 18, 2015 How long have you been using these plates? Mine has not faded even after almost 10 years.... Link to post Share on other sites More sharing options...
Ahgong Supercharged December 18, 2015 Author Share December 18, 2015 > 5 years.dunno why the plate numbers will fade liddat leh Link to post Share on other sites More sharing options...
Mason016 Supersonic December 18, 2015 Share December 18, 2015 Rain, bright sun. Or you stay in the west area, hearsay. Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged December 18, 2015 Share December 18, 2015 Paper outline, cover the rear with some newspaper then spray paint. Tad troublesome. 2 Link to post Share on other sites More sharing options...
Quekahwhye Clutched December 18, 2015 Share December 18, 2015 Use paint marker. 1 Link to post Share on other sites More sharing options...
Steptronic Supercharged December 18, 2015 Share December 18, 2015 You can search for "number plates" in the MCF forums. You get lot of them! anyone here to recommend? Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear December 25, 2015 Share December 25, 2015 offset the savings from your COE Link to post Share on other sites More sharing options...
Count-Bracula Twincharged December 25, 2015 Share December 25, 2015 Do what is legal but OPC plate better be carerful . . . . any breakage in the seal and they take it as tampering. Link to post Share on other sites More sharing options...
Simplecar 4th Gear December 26, 2015 Share December 26, 2015 1. clean the plate with soap water. After dry, use alcohol or solvent to clean remanant oil. 2. mask everywhere (body and plate) except the numbers 3. Get a can of white spray paint and spray thinly. Repeat after the previous coat is dry. 4. For the red background, reverse the mask. Link to post Share on other sites More sharing options...
BanCoe Hypersonic December 26, 2015 Share December 26, 2015 1. clean the plate with soap water. After dry, use alcohol or solvent to clean remanant oil. 2. mask everywhere (body and plate) except the numbers 3. Get a can of white spray paint and spray thinly. Repeat after the previous coat is dry. 4. For the red background, reverse the mask. good idea but the red background - better not touch that colour as to get the exact colour is not easy and skali kenna by LTA or inspection centre for different colour again got problems; Looking at TS plate the red looks solid still, actually. Also another problem is that the Weekend car license plate is bolted fixed onto the frame and I think it cannot be opened up because I have seen on them a kind of locked bolt in my friends car .... though i dont know now how,...... so it might be a back breaking thing to do this painting or touch up with white corrector fluid Link to post Share on other sites More sharing options...
Xers007 Supercharged December 27, 2015 Share December 27, 2015 (edited) do whatever DIY ask LTA for black and white 1st, kanna stop just produce the it. frankly speaking paying 200 bucks for that seal is plain ridiculous. Edited December 27, 2015 by Xers007 ↡ Advertisement Link to post Share on other sites More sharing options...
Clear your plates or kena orh gong ah
Get a new car plate number for used car
No Degree Required: How I prove my worth as a vinyl car wrapper amid male chauvinism and prejudice against manual work
Shell x UOB Umbrella Redemption
