Dscheng 3rd Gear January 11, 2016 Share January 11, 2016 Hi all, Any compact and good subwoofer to intro? Current setup is helix front and back speaker with Rainbow beat amp. The current sound is very good, but somehow rather lack of bass and bom bom feeling. ↡ Advertisement Link to post Share on other sites More sharing options...
Altis72 3rd Gear January 11, 2016 Share January 11, 2016 Just curious will you get another amp to drive your subwoofer? Link to post Share on other sites More sharing options...
Dscheng 3rd Gear January 11, 2016 Author Share January 11, 2016 Just curious will you get another amp to drive your subwoofer? Probably not? My beat 4 should be enough? I am not hardcore audio person. Saw my frd setup not bad, focal speaker, one amp and one small pioneer sub install front passenger below the glovebox. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged January 12, 2016 Share January 12, 2016 i used to use soundstream subwoofer....12" Link to post Share on other sites More sharing options...
Tyrrou Neutral Newbie January 13, 2016 Share January 13, 2016 Ur current amp is 4 channel? U will have used up all available channel for ur 2X front and 2X rear speakers. Unless u r are using ur HU to drive ur rear speakers? U will need another amp to drive ur subwoofer... Probably not? My beat 4 should be enough? I am not hardcore audio person. Saw my frd setup not bad, focal speaker, one amp and one small pioneer sub install front passenger below the glovebox. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear January 13, 2016 Author Share January 13, 2016 (edited) Ur current amp is 4 channel? U will have used up all available channel for ur 2X front and 2X rear speakers. Unless u r are using ur HU to drive ur rear speakers? U will need another amp to drive ur subwoofer... Oh thank you. My HU is Kenwood DNX5350BT, will it sufficient for a sub? Dont wish to spend $$ on another amp again. Erm wait, i saw some active sub come with in built amp. Anyone using Pioneer TX series? Edited January 13, 2016 by Dscheng Link to post Share on other sites More sharing options...
Tyrrou Neutral Newbie January 13, 2016 Share January 13, 2016 Dun think u can run a proper sub without an additional amp. However, active sup will be a different story, it just require another pair of RCA to connect them (HU & Active sub) But the low frequency produce will be very different. Try talking to you installer if this is possible: Drive ur 2X front speaker via ur amp (1 channel + 1 channel) Drive ur rear woofer via ur amp (bridged 2 channel) Drive ur 2X rear speaker directly from ur HU output I might be wrong, do talk to ur installer.... Oh thank you. My HU is Kenwood DNX5350BT, will it sufficient for a sub? Dont wish to spend $$ on another amp again. Erm wait, i saw some active sub come with in built amp. Anyone using Pioneer TX series? Link to post Share on other sites More sharing options...
Tonydeath 4th Gear January 13, 2016 Share January 13, 2016 (edited) Oh thank you. My HU is Kenwood DNX5350BT, will it sufficient for a sub? Dont wish to spend $$ on another amp again. Erm wait, i saw some active sub come with in built amp. Anyone using Pioneer TX series? active sub dont buy I use it (Pioneer active sub) when I first start upgrade my sound system was also having the same thinking like you don't spend too much. Edited January 13, 2016 by Tonydeath Link to post Share on other sites More sharing options...
Altis72 3rd Gear January 13, 2016 Share January 13, 2016 Dun think u can run a proper sub without an additional amp. However, active sup will be a different story, it just require another pair of RCA to connect them (HU & Active sub) But the low frequency produce will be very different. Try talking to you installer if this is possible: Drive ur 2X front speaker via ur amp (1 channel + 1 channel) Drive ur rear woofer via ur amp (bridged 2 channel) Drive ur 2X rear speaker directly from ur HU output I might be wrong, do talk to ur installer.... I think you are right. I am using my 4 channel amp to drive my two front speakers and subwoofer and believe the HU can be used to drive the rear speakers. ps I dun use my stock rear speakers as I prefer the music to be at the front. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear January 17, 2016 Author Share January 17, 2016 Anyone try installer at sim lim tower level 1 near the car park there? Link to post Share on other sites More sharing options...
Dscheng 3rd Gear January 17, 2016 Author Share January 17, 2016 Dun think u can run a proper sub without an additional amp. However, active sup will be a different story, it just require another pair of RCA to connect them (HU & Active sub) But the low frequency produce will be very different. Try talking to you installer if this is possible: Drive ur 2X front speaker via ur amp (1 channel + 1 channel) Drive ur rear woofer via ur amp (bridged 2 channel) Drive ur 2X rear speaker directly from ur HU output I might be wrong, do talk to ur installer.... wow I think your idea is better. Initially I want to connect the active sub into my HU. Coming to think of it, sound system for car is driver oriented. Rear speaker not so important. Link to post Share on other sites More sharing options...
Simplecar 4th Gear January 17, 2016 Share January 17, 2016 wow I think your idea is better. Initially I want to connect the active sub into my HU. Coming to think of it, sound system for car is driver oriented. Rear speaker not so important. The recommended setup is good as the rear speakers are not so important to drivers since they are at the back. For subwoofer, i use a 12" speaker and box setup (make sure the minimum volume is met). You have to decide whether to use sealed or ported (google for the difference) - SPL or deep bass? My amps have been with me for more than 10 years and are still doing well. So, i suggest investing in a good sub amp for the future - they will last a very long time Link to post Share on other sites More sharing options...
lausai88 Hypersonic January 17, 2016 Share January 17, 2016 here is my subwoofer my ex gf always complain car too noisy Link to post Share on other sites More sharing options...
Dscheng 3rd Gear January 18, 2016 Author Share January 18, 2016 Anyone try installer at sim lim tower level 1 near the car park there? Anyone try before??? Link to post Share on other sites More sharing options...
Raychay 5th Gear January 18, 2016 Share January 18, 2016 If you like loud thumping bass, you'll need an additional amp and a subwoofer with enclosure in your trunk. Done that in my younger days. If you don't want additional amps, need the boot space and just want add some bass to the music, an underseat active sub will do. Link to post Share on other sites More sharing options...
Jiex 2nd Gear January 22, 2016 Share January 22, 2016 Dun think u can run a proper sub without an additional amp. However, active sup will be a different story, it just require another pair of RCA to connect them (HU & Active sub) But the low frequency produce will be very different. Try talking to you installer if this is possible: Drive ur 2X front speaker via ur amp (1 channel + 1 channel) Drive ur rear woofer via ur amp (bridged 2 channel) Drive ur 2X rear speaker directly from ur HU output I might be wrong, do talk to ur installer.... Agree on the low frequency part. After i upgraded my woofer to one that produces a even lower frequency...it brought my enjoyment to another level. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear February 1, 2016 Author Share February 1, 2016 (edited) Guys, i added Pioneer sub TX120. It is up to my expectation. Thumb up for Ah meng the freelance installer. !! My I.C.E previously done by reputable installer (A***Ima**), When ah meng do tuning, he discover my right side tweeter is not working. He open up my door panel and saw the wire was connected wrongly ! OMG. After he connected it back, it was heaven to my ear !! Really good service and price from Ah meng ! Strongly recommended ! Edited February 1, 2016 by Dscheng Link to post Share on other sites More sharing options...
Peqasus 1st Gear February 12, 2016 Share February 12, 2016 Using a tx120 as well. Small and boomy ↡ Advertisement Link to post Share on other sites More sharing options...
Car Show 2024
Car Show 2024
Whole car sound proof
Xtremez Audio - Your Choice for Audio Installation & Upgrade
The Doctor , Freelance ICE Tuner
VESS head unit
VESS head unit
Sound Proofing the car
