Lotr 6th Gear March 20, 2016 Share March 20, 2016 Hi car owners with direct injection engine (GDI/Gasoline Direct Injection), would like to understand more about cleaning of carbon deposits on the intake valves. Anyone has experience to share about such cleaning service - chemical or mechanical - is available locally? Or has anyone tried to diy? More info on the need for cleaning can be found here: http://www.aa1car.com/library/intake_valve_deposits_gdi_engines.htm ↡ Advertisement Link to post Share on other sites More sharing options...
t0y0ta Supercharged March 20, 2016 Share March 20, 2016 (edited) Hi car owners with direct injection engine (GDI/Gasoline Direct Injection), would like to understand more about cleaning of carbon deposits on the intake valves. Anyone has experience to share about such cleaning service - chemical or mechanical - is available locally? Or has anyone tried to diy? More info on the need for cleaning can be found here: http://www.aa1car.com/library/intake_valve_deposits_gdi_engines.htm Applicable if your car only uses direct injection into combustion chamber. Many models (Toyota/Lexus D4-S & newer VW engines) use both intake port and direct injection, so won't have this problems. Some kena worse than others, for example the Audi S4/S5 engines. I hear the only way to truly solve is to do engine overhaul. They will strip out the cylinder heads and clean out the carbon deposits manually before re-assemblying. Edited March 20, 2016 by t0y0ta 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic March 20, 2016 Share March 20, 2016 Walnut blast. It is available in Singapore. Link to post Share on other sites More sharing options...
Quantum 5th Gear March 20, 2016 Share March 20, 2016 (edited) Hi car owners with direct injection engine (GDI/Gasoline Direct Injection), would like to understand more about cleaning of carbon deposits on the intake valves. Anyone has experience to share about such cleaning service - chemical or mechanical - is available locally? Or has anyone tried to diy? More info on the need for cleaning can be found here: http://www.aa1car.com/library/intake_valve_deposits_gdi_engines.htm No way to clean the carbon, only solution is do not buy GDI car in future, because it's technology not mature yet Edited March 20, 2016 by Quantum Link to post Share on other sites More sharing options...
Mkl22 Twincharged March 20, 2016 Share March 20, 2016 Can be cleaned via carb or fuel injection cleaners when you open up the intake manifold. The mechanic will turn the crankshaft to make sure the valves are closed and then spray cleaner into the valves and agitate to remove the carbon. He will then used compressed air to blow it out with a cloth to absorb. Had my DI engine cleaned this way and could see the valves were clean now. Link to post Share on other sites More sharing options...
Lotr 6th Gear March 20, 2016 Author Share March 20, 2016 (edited) Can be cleaned via carb or fuel injection cleaners when you open up the intake manifold. The mechanic will turn the crankshaft to make sure the valves are closed and then spray cleaner into the valves and agitate to remove the carbon. He will then used compressed air to blow it out with a cloth to absorb. Had my DI engine cleaned this way and could see the valves were clean now. sounds like big job, mind sharing the contact and estimated time needed for the job? also, any particular issue that called for the cleaning to be done? thanks My mileage is about 80k km now and engine is sometimes feels sluggish. Wonder if intake valves could be the problem. Edited March 20, 2016 by Lotr Link to post Share on other sites More sharing options...
Mkl22 Twincharged March 20, 2016 Share March 20, 2016 (edited) sounds like big job, mind sharing the contact and estimated time needed for the job? thanksChin auto. $200 for toyota markx. About 1.5-2hour job. Edited March 20, 2016 by Mkl22 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic March 20, 2016 Share March 20, 2016 No way to clean the carbon, only solution is do not buy GDI car in future, because it's technology not mature yet Walnut blast. 1 Link to post Share on other sites More sharing options...
Lotr 6th Gear March 20, 2016 Author Share March 20, 2016 Walnut blast. Any contacts and experience to share? thanks Link to post Share on other sites More sharing options...
inlinesix Supersonic March 20, 2016 Share March 20, 2016 Any contacts and experience to share? thanks Codewerx Link to post Share on other sites More sharing options...
Fuelsaver Supercharged March 21, 2016 Share March 21, 2016 Applicable if your car only uses direct injection into combustion chamber. Many models (Toyota/Lexus D4-S & newer VW engines) use both intake port and direct injection, so won't have this problems. Some kena worse than others, for example the Audi S4/S5 engines. I hear the only way to truly solve is to do engine overhaul. They will strip out the cylinder heads and clean out the carbon deposits manually before re-assemblying. i saw many audi n vw rides exhaust finishers coated with quite thick carbon. any relation? Link to post Share on other sites More sharing options...
Aukang 6th Gear March 23, 2016 Share March 23, 2016 http://fuelsandlubes.com/valvoline-introduces-fuel-cleaning-system-for-gdi-engines/ Seems interesting... Link to post Share on other sites More sharing options...
Liquidh 1st Gear December 19, 2018 Share December 19, 2018 (edited) DELETED Walnut blast. It is available in Singapore. Edited December 19, 2018 by Liquidh Link to post Share on other sites More sharing options...
Yewheng Twincharged December 19, 2018 Share December 19, 2018 No way to clean the carbon, only solution is do not buy GDI car in future, because it's technology not mature yet That is why there is this thing called oil catch can. Link to post Share on other sites More sharing options...
inlinesix Supersonic December 19, 2018 Share December 19, 2018 That is why there is this thing called oil catch can. Just do walnut blast at 100k km. Oil catch can still need to clear the can. Link to post Share on other sites More sharing options...
Contipro 5th Gear June 2, 2019 Share June 2, 2019 common issue direct injection engine + EGR https://youtu.be/BYvsW2d9wVU Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear June 2, 2019 Share June 2, 2019 city driving creates lotsa carbon in the engine system. My hiadee says every month he go pump caltex once n he say hor(not I say hor) it seems to clean the carbon bcos his car become smooth smooth like KY Gel after using caltex. Dunno is it true or talk rooster. Link to post Share on other sites More sharing options...
Watwheels Supersonic June 3, 2019 Share June 3, 2019 (edited) That's why now engines run on both MPI multi-port fuel injection and direct fuel injection. MPI runs during engine idling which the air fuel mixture can clean the valves and then transit to DFI running with load. No good thing is the extra fuel injectors mounted at the air intake manifold...extra cost. As for EGR or exhaust gas return system the diesel engines will have more carbon deposits clogging issues on the EGR valve and air intake valves. Petrol engines that has EGR system seem less likely to have an issue. There are EGR delete kits available on sale in online shops but mostly for diesel engines. Another potentially messing up the air intake valves is the PCV return or positive crankcase valve. Its function to divert engine oil/fuel vapours and blow-by back to the air intake pipe. Either use an oil catch can/tank to collect the sticky gunk or redirect it to the oil pan. The amount is not large but it causes the air instake valves to become sticky and collect the carbon deposits from the EGR. There are a few ways to clean the air intake valves if there lots of carbon deposits sitting on it. One of them is the biodegradable sand blasting ppl here mentioned earlier which requires some manpower to remove the air intake manifold in order to reach the intake valves to do the blasting to clear the carbon deposits. Other is using hydrogen gas to run the engine and clear it of any carbon deposits in the engine not just the valves. Less labour intensive as dont have to dismantle any engine parts. How thorough is the cleaning, I dont know. The last is to remove the engine head and take out the valves to clean them thoroughly. This involves more labour and time of course. Edited June 3, 2019 by Watwheels ↡ Advertisement Link to post Share on other sites More sharing options...
Car carpet cleaning
Car carpet cleaning
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
