RogerNg_185295 6th Gear April 15, 2018 Share April 15, 2018 in the good old days ... for cibic and mits car owner ... we don't chop off muffler ... we "operate" ... the usual suspects popular exhaust workshop claim they got tok kong skill to operate the muffler to a "sweet spot" that will pass lta inspection ... Lta surely will know what these famous shops are up to .Lta is not stupid.i can tell you they have insider info one. ↡ Advertisement Link to post Share on other sites More sharing options...
Razzd 3rd Gear April 15, 2018 Share April 15, 2018 (edited) The noise will attract lta and tp officers There was no perceivable increase in noise at startup & idle. Only when >3,000 RPM it comes alive & increase in decibel output is perhaps 3db at most. In actual fact, I like the sound the "stock" exhaust produces now, as the rear (main) muffler was not touched at all. in the good old days ... for cibic and mits car owner ... we don't chop off muffler ... we "operate" ... the usual suspects popular exhaust workshop claim they got tok kong skill to operate the muffler to a "sweet spot" that will pass lta inspection ... Bro @Wt_know I'm unsure about those days' Civics and Evos, do they have a "center" muffler like what they do now on the G30? I'm unsure about the W213 or the Audis though. Edited April 15, 2018 by Razzd Link to post Share on other sites More sharing options...
inlinesix Supersonic April 15, 2018 Share April 15, 2018 chop off muffler? it’s illegal & sure fail car inspection in spore ... http://www.realoem.com/bmw/enUS/showparts?id=JA52-EUR-02-2016-G30-BMW-530i&diagId=18_1261 I think the part mark as 1. Maybe fabricate a straight through titanium pipe. Link to post Share on other sites More sharing options...
Wt_know Supersonic April 15, 2018 Share April 15, 2018 (edited) must make sure the cut super nice and the joint super OEM look i kena questioned before when my F10 was due for inspection (3 years) i told the officer i scrap the exhaust pipe gao gao and repair with the weilding ... muahahaha actually .... http://www.realoem.com/bmw/enUS/showparts?id=JA52-EUR-02-2016-G30-BMW-530i&diagId=18_1261I think the part mark as 1.Maybe fabricate a straight through titanium pipe. Edited April 15, 2018 by Wt_know Link to post Share on other sites More sharing options...
Zze121 3rd Gear July 4, 2018 Share July 4, 2018 https://youtu.be/LLoEs-03dRw 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged July 4, 2018 Share July 4, 2018 https://youtu.be/LLoEs-03dRw Honestly there are many similar such china programs... what I don't like about these is that they are worse than superficial: Aluminium parts = good; steel = bad thick crash bar = good Recycled foam = bad Most of the youtube comments mostly blast them (in mandarin) about them trying to act expert without truly understanding the design constraints and reasons. 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic July 4, 2018 Share July 4, 2018 Honestly there are many similar such china programs... what I don't like about these is that they are worse than superficial: Aluminium parts = good; steel = bad thick crash bar = good Recycled foam = bad Most of the youtube comments mostly blast them (in mandarin) about them trying to act expert without truly understanding the design constraints and reasons. Since E39, suspension parts has been aluminum. Aluminum is stiffer and lighter than steel. Link to post Share on other sites More sharing options...
Razzd 3rd Gear July 26, 2018 Share July 26, 2018 (edited) Gentlemen, I decided to upgrade my Harman Kardon stock speakers on my 530i to the Bowers & Wilkins tweeters & mid-range. Upgraded 14 drivers; 7 tweeters & 7 mid-range. B&W's mid-range are aluminized kevlar as opposed to HK's plastic cones. I did not upgrade the twin HK subwoofers, for the simple reason that B&W's Rohacell bass drivers require the amplifier to be upgraded. 600W is insufficient to drive the different impedance Rohacell drivers. Unable to upgrade to the Bowers & Wilkins 1,300w Digital amp, coz it requires the entire car to be stripped apart & re-do the entire wiring. Also, the B&W Diamond Tweeters are exorbitantly expensive, > $3K for the twin diamond tweeters + illuminated housing. Summary: Sound improvement is very significant. It's not fully apparent if your source is sub-par: Garbage in, Garbage out. Mids are more forward, which is to my liking. Vocals stand out, especially female vocalists like Adele. Instrument detail & highs are more apparent; unlike the HK speakers which are harsh. You can discern instruments clearer vs the HK speakers. Previously, HK stock speakers require a significant treble boost, now I only boost +2 to the treble with the B&W speakers Most significant improvement is now, you need to de-select the Logic 7-Surround. The 7-Surround improves sound when the speakers are sub-par. With the B&W speakers, you have to turn it OFF, else it sounds too "fake". The other significant improvement is you get a much better sound-stage and definition when seated in the rear as opposed to being sound-focused towards the Driver. With the stock HK speakers, it's driver-centric. With the B&W speakers, the sweet spot extends to your rear passengers (listen with your head to the headrest, don't lean forward). Impressive! In all, a worthwhile upgrade! I'm enjoying the audio bliss every drive! Edited July 26, 2018 by Razzd 5 Link to post Share on other sites More sharing options...
inlinesix Supersonic July 26, 2018 Share July 26, 2018 1. Did you change the amplifier? There is a dedicated B&W amp. 2. What's your source? Link to post Share on other sites More sharing options...
Razzd 3rd Gear July 26, 2018 Share July 26, 2018 1. Did you change the amplifier? There is a dedicated B&W amp. 2. What's your source? David, I did not change my amp. It was entirely Plug & Play. Left to use my stock Harman 600W Digital Amp. Source = Can you imagine.... Spotify Premium. I've yet to test CDs. I already hear the apparent difference playing from Spotify Premium Bluetooth from my iPhone 8S Plus. Don't get me wrong, David. The difference is not night & day if your "source" is crap. Feed it with acoustic/vocal tracks even with deep bass, and it literally sings. If the recording is crap, you will get what it's meant to be. Link to post Share on other sites More sharing options...
inlinesix Supersonic July 26, 2018 Share July 26, 2018 David, I did not change my amp. It was entirely Plug & Play. Left to use my stock Harman 600W Digital Amp. Source = Can you imagine.... Spotify Premium. I've yet to test CDs. I already hear the apparent difference playing from Spotify Premium Bluetooth from my iPhone 8S Plus. Don't get me wrong, David. The difference is not night & day if your "source" is crap. Feed it with acoustic/vocal tracks even with deep bass, and it literally sings. If the recording is crap, you will get what it's meant to be. Buy ipod and play uncompressed music. CD too mafan Link to post Share on other sites More sharing options...
Razzd 3rd Gear July 26, 2018 Share July 26, 2018 (edited) I also upgraded my stock paper air filter -> BMC. Summary:- Significant improvement in response Feels like at least some power gain and definitely improved response, in low to mid range. You can feel the car has more power on tap I couldn't believe how dirty my stock filter has become. 1 yr 3 mo old, clocked <11,000km and see how dirty it is. Buy ipod and play uncompressed music. CD too mafan Thanks bro. Will do. I have a 100% working iPod Classic with 250GB storage. Forgot that it plays Uncompressed! Thanks again, bro! Edited July 26, 2018 by Razzd Link to post Share on other sites More sharing options...
inlinesix Supersonic July 26, 2018 Share July 26, 2018 Thanks bro. Will do. I have a 100% working iPod Classic with 250GB storage. Forgot that it plays Uncompressed! Thanks again, bro! I have been using ipod classic since driving E39 with cassette tape. Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic July 26, 2018 Share July 26, 2018 I also upgraded my stock paper air filter -> BMC. Summary:- Significant improvement in response Feels like at least some power gain and definitely improved response, in low to mid range. You can feel the car has more power on tap I couldn't believe how dirty my stock filter has become. 1 yr 3 mo old, clocked <11,000km and see how dirty it is. Thanks bro. Will do. I have a 100% working iPod Classic with 250GB storage. Forgot that it plays Uncompressed! Thanks again, bro! Wow, ur car is more than a year already? Seems like it's just a few months ago. Link to post Share on other sites More sharing options...
Razzd 3rd Gear July 26, 2018 Share July 26, 2018 (edited) I have been using ipod classic since driving E39 with cassette tape. WOW, awesome, bro. Thanks. Time to dig mine out & charge it! Wow, ur car is more than a year already? Seems like it's just a few months ago. Yes bro.... My 530i is like 1 yr 3 mo old... I got it in APR 2017. How time flies. Only managed to clock < 11,000 km in that time. Coz I've got to drive my truck & run my little Vespa Sprint as well. BMC AIr Filter - Made In Italy Gents, regarding the BMC filter, I was skeptical at first. I know all too well, about the excessive "oil" going into the turbo if oiled excessively. But after reading BMC's study & website on the improve particulate filtration on their filter vs the stock paper filer, I was convinced. And we all know, turbocharged cars need air to breathe. More air + more fuel = more power. Simple physics. Just like changing the downpipe will yield significant improvement in power without even touching the ECU, getting a more efficient air filter allows better air-flow to the turbocharger, and on modern turbocharged cars, it makes all the difference. Like using RON100. With modern ECUs, it will advance the timing to yield a few hp, for free, literally. Edited July 26, 2018 by Razzd Link to post Share on other sites More sharing options...
Wt_know Supersonic July 26, 2018 Share July 26, 2018 (edited) BMC filter is awesome i used it before in my 3-series the sound also nicer and feel more air but after i witness a BMC filter start to disintegrate and risk the “metal” get into the engine ... i never use it liao any filter only give shiok feeling and never could increase the car performance i even did the whole she-bang GruppeM carbon intake previously ... now think of it ... the $$$ can pump at least 6 months petrol ... lol Edited July 26, 2018 by Wt_know 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic July 26, 2018 Share July 26, 2018 The cheapest engine mod is pump RON100. 2 Link to post Share on other sites More sharing options...
Rayoflight 5th Gear July 27, 2018 Share July 27, 2018 Did a test drive with a friend on the new M5 yesterday. Definitely one of the best sports sedan $$$ can buy. It can be comfortable for family yet when the beast is unleashed, all hell breaks loose on the 4.4l v8 twin turbo. Traction control off, everything on sports mode. However, it doesn't feel as raw as a F80 M3.. abit too much comfort. Simply exhilarating. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
My EV journey to the i4
All BMW owner thread
MAZDA 6
MAZDA 6
