tylsteve 3rd Gear April 8, 2018 Share April 8, 2018 The battery was only replaced June last year. There is multiplie clicks and the electronic parking brake light is flashing. When the battery is spoilt, the electronics in the car will go haywire, with warning lights appearing everywhere, even though there is no problem with the other systems. Need to change the battery and also get the workshop to restart the electronics. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Han1911 1st Gear April 8, 2018 Share April 8, 2018 When the battery is spoilt, the electronics in the car will go haywire, with warning lights appearing everywhere, even though there is no problem with the other systems. Need to change the battery and also get the workshop to restart the electronics. Alright. Thanks guys. 1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear April 8, 2018 Share April 8, 2018 Alright. Thanks guys.Hi Han, It is a known problem ... I changed mine at 10th month, 14th month and few weeks ago after 2 yrs 5 months. It has nothing to do with stopstart but the charging circuitry and affects 2.0l also ...one bro with 2.0l had his changed 4 times at 7.5 mths interval. Tanchong changed battery from stock efb battery type meant for stopstart vehicle to expensive agm battery with superior charging/discharging performance meant for hybrid vehicle for 1.2l to alleviate this issue after countless cases. 2.0l bros did not get this agm battery since under the impression without shop start and hence also affected. Please ensure tanchong gives you agm type .... and yes, go back to tanchong if less than 12 mths and 24mth respectively as earlier advised by various bros. Cheers. Richard Link to post Share on other sites More sharing options...
Wai437 1st Gear April 9, 2018 Share April 9, 2018 Hi Wai, Get a used pair which are from ebay uk .... take your time to choose excellent used ones. Less than sgd500 including shipping, gst and installation. Not sure and doubt any adhesive with these broken plastic parts of the headlights will work especially longer term. Cheers. Richard Thanks Richard, shall see how it goes. Had went to several shops at Kaki Bukit and Sin Ming area and mostly told me as my headlamp is 2.0 ones so cost a lot. But will see how it goes. Just an update, managed to get some quotes on repairing. Likelihood will do repair on the catch instead. Apparently they will bond the plastic part with metal so that it would be secure. 3 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear April 9, 2018 Share April 9, 2018 Thanks Richard, shall see how it goes. Had went to several shops at Kaki Bukit and Sin Ming area and mostly told me as my headlamp is 2.0 ones so cost a lot. But will see how it goes. Just an update, managed to get some quotes on repairing. Likelihood will do repair on the catch instead. Apparently they will bond the plastic part with metal so that it would be secure. Hi Wai, Good to know ! Cheers. Richard Link to post Share on other sites More sharing options...
pelican_ Clutched April 9, 2018 Share April 9, 2018 (edited) Dear friends, I reversed into a pillar and cracked one of my rear lights. No other damages. TC quoted me $380 for the tail light unit (one side) but I reckon it is a little on the high side. Appreciate if you could PM me if you know of any reasonable workshops in SIn Ming area for replacement. Have a nice day ahead. Hi warlock, Cracked my rear light and it cost me $200+ to replace whole unit. I visited this shop at Kaki bukit Autobay First floor facing the exit. Shop is called something and battery, forgot the name Edited April 9, 2018 by pelican_ 2 Link to post Share on other sites More sharing options...
tylsteve 3rd Gear April 10, 2018 Share April 10, 2018 Planning to change front wipers. What length or spec to get? What brand or model do you recommend? Is it easy to change by ourselves? Link to post Share on other sites More sharing options...
giraffey99 3rd Gear April 10, 2018 Share April 10, 2018 Planning to change front wipers. What length or spec to get? What brand or model do you recommend? Is it easy to change by ourselves?it is easy to change. Wiper Size: Driver:26" Passenger:16" Rear:12" If you want the best, PIAA. 1 Link to post Share on other sites More sharing options...
DriveCar 2nd Gear April 10, 2018 Share April 10, 2018 Planning to change front wipers. What length or spec to get? What brand or model do you recommend? Is it easy to change by ourselves?If you are on NPMP or planning to sign up, front wipers are included FYI. 1 Link to post Share on other sites More sharing options...
tylsteve 3rd Gear April 10, 2018 Share April 10, 2018 it is easy to change. Wiper Size: Driver:26" Passenger:16" Rear:12" If you want the best, PIAA. Do I get the whole wiper frame or just the rubber strip? Sorry I have not removed it before so not sure how it is constructed. Link to post Share on other sites More sharing options...
Warlock35 1st Gear April 10, 2018 Share April 10, 2018 Hi warlock, Cracked my rear light and it cost me $200+ to replace whole unit. I visited this shop at Kaki bukit Autobay First floor facing the exit. Shop is called something and battery, forgot the name Thanks, I just got it replaced. $288 inclusive of GST at Sin Ming BH Auto. 1 Link to post Share on other sites More sharing options...
erichew Neutral Newbie April 11, 2018 Share April 11, 2018 Hi folks I am considering getting a June 2015 QQ. I have heard some nagging issues about this car that I don’t hear from Altis or Civic. May I know what should I be taking note of before buying this car? What are the nagging issues that you guys faced? Link to post Share on other sites More sharing options...
giraffey99 3rd Gear April 11, 2018 Share April 11, 2018 Do I get the whole wiper frame or just the rubber strip? Sorry I have not removed it before so not sure how it is constructed.getting the frame with blades would be better. 1 Link to post Share on other sites More sharing options...
Pointpoint 1st Gear April 11, 2018 Share April 11, 2018 Think my car papago 360 just died on me. Does anyone know warranty is by tcm? How many years warranty? 1 Link to post Share on other sites More sharing options...
Lucio 1st Gear April 11, 2018 Share April 11, 2018 Sent my car to Bukit Timah for servicing today and noticed few deep "chips" on one of the rims when pumping air at petrol station. Going back tomorrow morning to seek explanation. Bros, pls check before driving off.. 2 Link to post Share on other sites More sharing options...
tylsteve 3rd Gear April 11, 2018 Share April 11, 2018 getting the frame with blades would be better.Thanks for all the advice for the windscreen wiper replacement. Just got a new pair from Autobacs today. Bosch Aerotwin, 650mm and 425mm for the front pair. Changed the whole frame as there was no suitable replacement for just the rubber strip.Anyway now got offer, $34.95 for a pair of the Bosch wipers. Very easy to change by myself also. 2 Link to post Share on other sites More sharing options...
Hd2004 2nd Gear April 12, 2018 Share April 12, 2018 Sent my car to Bukit Timah for servicing today and noticed few deep "chips" on one of the rims when pumping air at petrol station. Going back tomorrow morning to seek explanation. Bros, pls check before driving off.. When there is a tyre rotation scheduled, also needs to do some markings of sort to ensure that they do it. For your case, they shall deny and put the blame on you for not checking. This is Singapore ... we pay big money for lousy services:) 2 Link to post Share on other sites More sharing options...
Weiqiang2501 1st Gear April 12, 2018 Share April 12, 2018 Hi Hi anyone here has a reliable link to purchase the obd splitter 1 to 2. looking at local online retailer. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
2014 Mercedes CLA
2014 Mercedes CLA
2016 Renault Kadjar
2016 Renault Kadjar
