  • 1
  • Search this thread
  • Reply to this topic
11 replies to this topic | 10 praises
#1
Posted 28 May 2016 - 06:35 PM
Sleon383
  • THREAD STARTER
  • Sleon383
    Clutched
    Author Image
    35
Hello.. Need some advices.
One day, I off my car engine for a while (maybe around ten minutes) to buy some things, and when I push start the engine, it shows a weak cranking and the dashboard lights up showing the battery and the oil warning light. Try second pressing the start switch and the car engine starts.
This happens twice and the second time is after a fuel pumping.
This car is now 168000km.
What can be wrong? The battery and starter switch is checked OK.
Thanks for the help
#2
Posted 28 May 2016 - 07:14 PM
Melvintan13
  • Melvintan13
    Author Image
    22
 I encountered the same problem as u a month ago. problem was weak fuel pump . u may bring to car workshop to test it out . for my case , change fuel pump and everything well now
#3
Posted 28 May 2016 - 07:31 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    37,739
Check your battery again or the battery terminal contact.
#4
Posted 28 May 2016 - 07:38 PM
Sleon383
  • THREAD STARTER
  • Sleon383
    Clutched
    Author Image
    35
The battery is checked with the tester and working good. It is only three months old.
Noted.. Besides can't start the engine, what other issues you have with a bad fuel pump.
Where u get the problem diagnosed and solved?
#5
Posted 28 May 2016 - 08:17 PM
Thaiyotakamli
  • Premium member
    Thaiyotakamli
    2Fast2Furious
    Author Image
    62,042
Is ur car bmw? [grin]
Angcheek praised this
Dont get confused between my personality & my attitude...
My personality is who I am...
My attitude depends on who you are...
#6
Posted 28 May 2016 - 09:57 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    16,078
Fuel pump wont cause weak cranking. If fuel pump is having problem, cranking can still be strong but car wont get started. Weak cranking could be battery , if not , could also be the starter motor that is going off soon. Especially if you experienced no crank at times , it is a indication that the starter is about to be replaced. The problem is there is no good way to check a starter condition.
#7
Posted 28 May 2016 - 10:43 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    37,739
What is your driving pattern ?
Average 20~30 min drive or 5 min drive each time you start and stop engine ?
#8
Posted 28 May 2016 - 10:48 PM
Melvintan13
  • Melvintan13
    Author Image
    22
Other symptoms are car engine die off at stop junctions with battery signal light on and engine light on. Battery and alternatir tested perfectly fine . It takes a experienced mechanic to test out the problems .non trusted ones will tell u change battery change alternator and change all sort of things .
If u have trusted workshop,u may wish to go back to them . E workshop i use is in yishun
#9
Posted 28 May 2016 - 11:47 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    54,232
Aiyo... Got warning light it's better to use a diagnostic tool to find out the fault codes. From there Google the fault code according to your car make and determine where the fault lies. Do not use guess work. Go to a workshop who has a diagnostic tool and fix the fault.
Imo it's good to invest in an obdii diagnostic tool. Those Bluetooth enabled plug in tool that connects to you phone/tablet do not cost much if you buy online. Better dan you come here ask. Ppl do not even ask for your car make & model. If you have warning lights on your dash get a diagnostic tool to fault find.
Stop going to those monkey workshops who do not even have a diagnostic tool and they any old how change parts on your car. Such dinosaur workshops need to upgrade as cars now are fitted with a lot of sensors and computers.
Edited by Watwheels, 28 May 2016 - 11:52 PM.
Feel so rich. Or just an illusion?
#10
Posted 29 May 2016 - 09:47 AM
Sleon383
  • THREAD STARTER
  • Sleon383
    Clutched
    Author Image
    35
The last engine light on is two months back with P0172 ( system too rich). I had it rectify by changing the O2 sensor, air filter and breathers. So far so good. There is no engine light on after starts up.
So far, this happens when I turn on the engine within a short period ( ten minutes). Any body experience this before.
I think can check the pressure to tell if the fuel pump is faulty.
It is not easy to test the motor starter.
As in my first post, the battery and oil warning lights up after the weak cranking and the engine can't starts. But there is no warning light when I crank again to start the engine.
#11
Posted 30 May 2016 - 06:18 PM
Angcheek
  • Premium member
    Angcheek
    2Fast2Furious
    Author Image
    217,975
dont tell me ur car have same experiences .........  :wacko:
樹多總有枯枝,人多總有白痴
#12
Posted 31 May 2016 - 12:24 AM
Thaiyotakamli
  • Premium member
    Thaiyotakamli
    2Fast2Furious
    Author Image
    62,042
So far so good hehe
Sunny praised this
  • 1
Dynamics Mechanic Pte Ltd
MSP Far East Pte Ltd
MSP Far East Pte Ltd  |  Rating   Submit Review
Reviewed by eddymhdishak  |  Neutral Newbie
These guys were amazing! Those reviews here do not lie! I was looking for a simple oil change but cringed at the thought of having to take ever crowded Sin Min xxx workshop so after searching through SGcarmart I found MSP Car Workshop. They couldn't have been nicer and quickly did my oil change while I waited, they explained everything they checked and didn't try to pus... » Read More
Autowerkz Remanufacturing Pte Ltd
Autowerkz Remanufacturing Pte Ltd  |  Rating   Submit Review
Reviewed by SiawSze  |  Neutral Newbie
Service and quality repair work. Affordable and efficient.
Related Motor Directory search on sgCarMart.com : Repair & Servicing
Quick Reply
Tags: weak, cranking, short, engine and 3 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
