BabaJoe Neutral Newbie February 6, 2018 Share February 6, 2018 You can get the pioneer interface from your audio installer.. They should have it. Else you will probably get them from amazon or ebay. Just take note, these interface doesn't come cheapThank you. I was quoted around 200 for the interface with installation. As for the USB, ideally, connected to the HU, if not, as per supply is also good. At the moment, its just a useless port. ↡ Advertisement Link to post Share on other sites More sharing options...
Elepoo 2nd Gear February 6, 2018 Share February 6, 2018 (edited) As mentioned in my earlier post, try getting from online for cheaper source. Eventually u still need to pay another fee for installation unless you DIY yourself. For the USB port, you might need to also Modify the connection between the USB to your Pioneer HU’s , or simply tab power source to yie USB port from the lighter port Edited February 6, 2018 by Elepoo Link to post Share on other sites More sharing options...
Zedex Clutched February 17, 2018 Share February 17, 2018 What petrol you all pump for 2WD? Anyone experiencing diff experience if pump another brand or quality? Link to post Share on other sites More sharing options...
Tanuki16 1st Gear February 18, 2018 Share February 18, 2018 Is there anything cm can do about the high rev thingy?I also experienced this high rev issue. Whenever I going downslope and slowing down, the rev will shoot up.As I am driving the 4wd ver, I manually shift up. Not sure if this is bad for the engine... Link to post Share on other sites More sharing options...
Number19 Neutral Newbie February 19, 2018 Share February 19, 2018 I'm driving the 2WD and find the car under power. I heard some drving 2WD can hit 15km/l but I can never hit that. On the average I only get around 12km/l. Is there something that I'm doing wrong?I’m driving the 2wd, my fc is 15+KM per litre as measured manually. The car measures it as 16 plus. Pumping spc95. Check your tyre pressure perhaps? I like to set mine to 230kpa. Engine oil was as per CM’s at the first oil change. My mileage is now 3k clicks. What petrol you all pump for 2WD? Anyone experiencing diff experience if pump another brand or quality?Changed from shell to spc. No discernible difference so I’ll just go with whichever credit card promo is better.. Link to post Share on other sites More sharing options...
skp 1st Gear February 20, 2018 Share February 20, 2018 Depends on driving habit and road conditions. If u want it to change gear up faster, need to let the car hv more momentum during move off. On straight road, accelerate slightly harder during move off and gradually release when it changes to second and third gear. If you're on up slope then no choice, it will drag on low gears. Yes tyre pressure makes a lot of difference. Read the manual, it has recommended pressure for different load. I frequently drive my family around, so use the 230kPa(33psi) setting. If you're always travelling alone or 2pax max, pressure can go higher. The tyres will lose pressure over time, so I top up around 2mths. Link to post Share on other sites More sharing options...
Elepoo 2nd Gear February 20, 2018 Share February 20, 2018 Just gone for 10k servicBig today. Informed the SE on the high rev issue. What did CM: Refresh my ECU, performed engine/gearbox flushing thingy which costed me $90 plus dollar. Now need to monitor the situation. Link to post Share on other sites More sharing options...
Cocoleak Clutched February 20, 2018 Share February 20, 2018 Just gone for 10k servicBig today. Informed the SE on the high rev issue. What did CM: Refresh my ECU, performed engine/gearbox flushing thingy which costed me $90 plus dollar. Now need to monitor the situation. Do keep us updated! So far I can manage about 15km/L but most time is 14+ Link to post Share on other sites More sharing options...
Lava 5th Gear February 20, 2018 Share February 20, 2018 (edited) Just gone for 10k servicBig today. Informed the SE on the high rev issue. What did CM: Refresh my ECU, performed engine/gearbox flushing thingy which costed me $90 plus dollar. Now need to monitor the situation. why do u need to pay? I tot now a days car has come along with warranty and servicing package? Edited February 20, 2018 by Lava Link to post Share on other sites More sharing options...
skp 1st Gear February 20, 2018 Share February 20, 2018 So far I think the rev is normal for me. 14+ km/l. The only diff from previously owned cars is that this one's sound insulation is quite poorly done. So the engine sound is more obvious. The flushing thing is outside service package, not necessary. So need to pay if u want it. Link to post Share on other sites More sharing options...
Elepoo 2nd Gear February 21, 2018 Share February 21, 2018 These items not in their standard maintenance package lah... Warranty is only applicable if your parts really become faulty or malfunction due to own causes. Link to post Share on other sites More sharing options...
Lava 5th Gear February 21, 2018 Share February 21, 2018 These items not in their standard maintenance package lah... Warranty is only applicable if your parts really become faulty or malfunction due to own causes. if the rev is high mean some components maybe faulty or not properly tune. can lodge a complaint and get the service consultant to check if the car is still under warranty? 1 Link to post Share on other sites More sharing options...
Elepoo 2nd Gear February 21, 2018 Share February 21, 2018 Informed the SE Liao, and that’s why they troubleshoot by checking and resetting the ECU...the flushing is additional that required to pay. Mechanic checked and see no faults, but ask me to monitor. So I believe they did their part Liao...I dun really expect them to down the gearbox or engine to perform a thorough check..... So far so good, I didn’t experience any high rev at Low gear after 1 day of driving...will still monitor further Link to post Share on other sites More sharing options...
slpeh 1st Gear February 21, 2018 Share February 21, 2018 Informed the SE Liao, and thatâs why they troubleshoot by checking and resetting the ECU...the flushing is additional that required to pay. Mechanic checked and see no faults, but ask me to monitor. So I believe they did their part Liao...I dun really expect them to down the gearbox or engine to perform a thorough check..... So far so good, I didnât experience any high rev at Low gear after 1 day of driving...will still monitor further Hi.. will like to know how is consider high rev? Mine at low gear is abt 2.5-3 rpm then it change to next gear. Is it normal for mine? Link to post Share on other sites More sharing options...
Elepoo 2nd Gear February 21, 2018 Share February 21, 2018 My high rev is 4 and above..once hit 6 then change gear Link to post Share on other sites More sharing options...
skp 1st Gear February 22, 2018 Share February 22, 2018 March cat A pqp @ 39k. Guess alot coe car owners going to renew 10yrs... Link to post Share on other sites More sharing options...
Tckrto 2nd Gear February 22, 2018 Share February 22, 2018 My high rev is 4 and above..once hit 6 then change gearYours is allgrip? Link to post Share on other sites More sharing options...
Elepoo 2nd Gear February 22, 2018 Share February 22, 2018 Nope..2WD. ↡ Advertisement Link to post Share on other sites More sharing options...
Swift Owners
Swift Owners
2016 Mercedes E-class (W213)
2016 Hyundai Elantra / Avante
2016 Renault Kadjar
2016 Renault Kadjar
2016 Audi A4 sedan & avant
2nd Generation Volkswagen Tiguan (2016)
