Rachdanom 2nd Gear June 15, 2016 Share June 15, 2016 There are so many and when I decided on one from Giant it did not last even one day. $13 gone. It broke at the base. It looked like attached photo.Just need specific model that works..thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
macrosszero Turbocharged June 15, 2016 Share June 15, 2016 RAM mounts are pricey but work well. 1 Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic June 15, 2016 Share June 15, 2016 I given up on semi-expensive ones. My taobao-savvy colleague gotten me one for $1.50 6 months ago and am still using it Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 15, 2016 Share June 15, 2016 I use airframe, but sometimes camera lens will fog. Link to post Share on other sites More sharing options...
Watwheels Supersonic June 15, 2016 Share June 15, 2016 (edited) I got mine from amazon https://www.amazon.com/gp/product/B004M8ST36/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 I bought it since Dec 2014. The suction didn't turn brown under the scorching sun like something I used earlier. Spring action at the bottom portion. And I was sold by this description... "Large sized 80mm diameter suction performs well in hot climate". The larger dan regular size suction performs very well especially your device is heavy. Quality is good for its price. It comes with an extra set of claws. The one in the pic is a mix of both short and long claws. It fits my iphone6 and 7" tablet. It's the best one I have used so far. Edited June 15, 2016 by Watwheels Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear June 15, 2016 Share June 15, 2016 (edited) I have tried a few hand phone mounts and this is by far the best: http://www.spigen.com/products/magnetic-air-vent-mount Very well-built and good quality. simple and sleek. Not obtrusive and bulky. Phone is very stable and attaches firmly to the base with no irritating vibrations. The thin metal plate can be sandwiched between the phone and case without using doublesided tape Only downside is the air con vent will be partially blocked and the phone maybe hard to reach if your air con vent is at obscure location. Edited June 15, 2016 by Jamesgetz Link to post Share on other sites More sharing options...
kennyg1969 Clutched June 15, 2016 Share June 15, 2016 Got this mount for S$40. Fits 6" phone like my Huawei mate 8. One handed operation Link to post Share on other sites More sharing options...
I_RIDE_DEEP 2nd Gear June 15, 2016 Share June 15, 2016 Got this mount for S$40. Fits 6" phone like my Huawei mate 8. One handed operation Bro. Can you share a picture of how you run the USB charging cable? My charging cable is very messy leh..it runs from the centre cigarette lighter -> across my steering wheel -> to the right side of windscreen. I am considering fixing an additional cigarette lighter under my right side of windscreen but am not sure where to do it. Link to post Share on other sites More sharing options...
Benarsenal Turbocharged June 15, 2016 Share June 15, 2016 (edited) I prefer those that you clip onto the aircon vents. More secure and better location (not so high up, less obstruction). I got one from Autobacs. They have a few available. Edited June 15, 2016 by Benarsenal 1 Link to post Share on other sites More sharing options...
Ericongy 3rd Gear June 16, 2016 Share June 16, 2016 Got this mount for S$40. Fits 6" phone like my Huawei mate 8. One handed operation looks like the mount created another blind spot... 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 16, 2016 Share June 16, 2016 I prefer those that you clip onto the aircon vents. More secure and better location (not so high up, less obstruction). I got one from Autobacs. They have a few available. You must have a very cool phone. 2 Link to post Share on other sites More sharing options...
Optramagnum 6th Gear June 16, 2016 Share June 16, 2016 (edited) I'm using a magnetic suction holder.. Easy mounting and taking out your hp.. But need to paste a metal plate inside your hp casing.. And because of the weight, need to adjust the height until the Hp is resting on the dashboard when it's mounted. Edited June 16, 2016 by Optramagnum 1 Link to post Share on other sites More sharing options...
Icarus 1st Gear June 17, 2016 Share June 17, 2016 I have tried quite a few phone holders over the years. Nothing beats the Kenu Airframe for smartphones. Got it from Apple Online Store... Only drawback is that u will lose the use of 1 aircon vent and not suitable for 'rounded' vents. 1 Link to post Share on other sites More sharing options...
Strat 6th Gear June 17, 2016 Share June 17, 2016 using this on my car now. Need not to worry about suction cup dropping off from the windscreen or leaving a mark when removed: 1 Link to post Share on other sites More sharing options...
jg2000 4th Gear June 17, 2016 Share June 17, 2016 (edited) Bro. Can you share a picture of how you run the USB charging cable? My charging cable is very messy leh..it runs from the centre cigarette lighter -> across my steering wheel -> to the right side of windscreen. I am considering fixing an additional cigarette lighter under my right side of windscreen but am not sure where to do it. Without using special tools and opening up any panels, there are some ways of hiding cables behind car panels, rubber seals etc. Usually can squeeze the cables in without problem. See below video for some tips. You might also need to buy a USB extension cord as normal cables may not be long enough for the longer route taken. https://www.youtube.com/watch?v=xwD8Ilk-MHU Edited June 17, 2016 by jg2000 2 Link to post Share on other sites More sharing options...
Scoots 3rd Gear June 18, 2016 Share June 18, 2016 (edited) Got this mount for S$40. Fits 6" phone like my Huawei mate 8. One handed operation Any issues with the suction failing and assembly dropping? Thinking of getting the same for my note5 Edited June 18, 2016 by Scoots 1 Link to post Share on other sites More sharing options...
Benarsenal Turbocharged June 18, 2016 Share June 18, 2016 You must have a very cool phone. Yes. Very cool indeed. 2 Link to post Share on other sites More sharing options...
Shibadog Turbocharged June 18, 2016 Share June 18, 2016 using this on my car now. Need not to worry about suction cup dropping off from the windscreen or leaving a mark when removed: CD slot? I am using one too. Vibrates abit but livable. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
New Subaru XV
New Subaru XV
UMIDIGI mobile phone
2015 Forester 2.0
2015 Forester 2.0
Top 5 questions to ask every used car dealer
Advice on exhaust.
Advice on exhaust.
Selling Car through CARRO
Get a new car plate number for used car
