Sng28 1st Gear June 24, 2016 Share June 24, 2016 Hello everyone, Can i check if anyone where used Maxden or Riben rubbish chute. I'm in a dilemma on which to choose. My current chute has little roaches invading through the corners....spraying , roach bait, roach gel, all tried....still has few sneaking in invade my home any recommendations or advice are welcomed. ↡ Advertisement Link to post Share on other sites More sharing options...
Jtb 6th Gear June 24, 2016 Share June 24, 2016 Hello everyone, Can i check if anyone where used Maxden or Riben rubbish chute. I'm in a dilemma on which to choose. My current chute has little roaches invading through the corners....spraying , roach bait, roach gel, all tried....still has few sneaking in invade my home any recommendations or advice are welcomed. maxden quality n expensive, normal flat with good grommet seal stainless steel good enough Link to post Share on other sites More sharing options...
New_Atlantis 3rd Gear June 24, 2016 Share June 24, 2016 What floor you on? If you are on a low floor don't bother. They will still climb in from the Windows. I tapped up my chute. Still can find roaches. You have to bug your town councils to flush the sewers and bins often. Link to post Share on other sites More sharing options...
Sng28 1st Gear June 24, 2016 Author Share June 24, 2016 maxden quality n expensive, normal flat with good grommet seal stainless steel good enough maxden quality and expensive meaning good but expensive? lol* i'm hesitant for i'm quoted 520....honestly..for a CHUTE....that's freaking ex mine currently is flat but its coming in thru the 4 sides especially the bottom area...and brand you would recommend bro ? What floor you on? If you are on a low floor don't bother. They will still climb in from the Windows. I tapped up my chute. Still can find roaches. You have to bug your town councils to flush the sewers and bins often. I'm on lower floor 3rd floor to be exact and windows not an issue but its the chute...the small ones are making their way in and i'm deeply concern abt that. Once infestation starts i'm doomed! other than the chute i think the rest are ok. I put lots of roach traps in my house to monitor and so far so good. probably they die of hunger by the amount of times i clean the house Link to post Share on other sites More sharing options...
New_Atlantis 3rd Gear June 26, 2016 Share June 26, 2016 Use those sticky fly paper to pin point the points that they come from. Then work on the problem area. That is the way I found out they climb in from my window. 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic June 26, 2016 Share June 26, 2016 Use those sticky fly paper to pin point the points that they come from. Then work on the problem area. That is the way I found out they climb in from my window.It is quite entertaining to see roaches get stuck on those sticky trap 1 Link to post Share on other sites More sharing options...
13177 Supersonic June 26, 2016 Share June 26, 2016 This is the downside of having a rubbish chute inside the house, although it is convenient to throw your rubbish. Lol. Even changed a new chute, still have little roaches invading through the corners? Link to post Share on other sites More sharing options...
Baal Supersonic June 26, 2016 Share June 26, 2016 It is quite entertaining to see roaches get stuck on those sticky trap Wah lao eh... Freakin sick boy 1 Link to post Share on other sites More sharing options...
Albeniz Turbocharged May 25, 2019 Share May 25, 2019 (edited) Which is the best quality chute to seal out cockroaches especially during fumigation? Assuming money is not a problem. Edited May 25, 2019 by Albeniz Link to post Share on other sites More sharing options...
13177 Supersonic May 25, 2019 Share May 25, 2019 Which is the best quality chute to seal out cockroaches especially during fumigation? Assuming money is not a problem. Masking tape the chute with many layers during fumigation is the best lo. Roaches should not able to come into your house. 1 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 25, 2019 Share May 25, 2019 Masking tape the chute with many layers during fumigation is the best lo. Roaches should not able to come into your house. That is what I did. Now have to bring out the gabbage bags every morning. Have not used the chute in the kitchen for more than 5 years liao. 1 Link to post Share on other sites More sharing options...
13177 Supersonic May 25, 2019 Share May 25, 2019 That is what I did. Now have to bring out the gabbage bags every morning. Have not used the chute in the kitchen for more than 5 years liao. You permanently tape up your chute ah? Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 25, 2019 Share May 25, 2019 You permanently tape up your chute ah? ð Why le?Kitchen cabinets got infested badly by roaches. Spent much time and effort to eradicate them. After sealing the chutes, no more problem. Link to post Share on other sites More sharing options...
13177 Supersonic May 26, 2019 Share May 26, 2019 Kitchen cabinets got infested badly by roaches. Spent much time and effort to eradicate them. After sealing the chutes, no more problem.Roaches from chute infested your cabinets? Looks like this is the problem if the chute is inside your house, since the design of the chute could not 100% proof seal from these pests. Link to post Share on other sites More sharing options...
Kxbc Turbocharged May 26, 2019 Share May 26, 2019 That means your town council not doing its job properly. My tc cleans the chute thoroughly with detergent from top down monthly. Ground floor chute area cleaned daily and refuse removed 3x daily. No roaches at all, even for a family member who has a unit on the 2nd floor. There was a time the contractor missed a monthly cleaning. Immediately can see roaches. Just a call to the tc, next day washed, no more problem. Some tcs and contractors are damn lazy. Don't xxxx cannot one. Link to post Share on other sites More sharing options...
13177 Supersonic May 26, 2019 Share May 26, 2019 (edited) True, think there is no standard SOP that every town council should follow, depends on individual town council how they want to run their estate. Some town council really very lazy. Edited May 26, 2019 by 13177 ↡ Advertisement Link to post Share on other sites More sharing options...
Bird pest removal
Bird pest removal
Termite Attacks
Termite Attacks
New Age Polish --> In Car Pest Fumigation
Rubbish chute fogging and roaches
Pest control in car
Pest control in car
Presenting! The Hoy Hoy Trap-A-Roach
Got summon for parking at hdb dustbin chute area
