Tycosadako Neutral Newbie January 14, 2018 Share January 14, 2018 Charcoal is good to remove smell. Buy from daiso ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Freeder Hypersonic January 14, 2018 Share January 14, 2018 Best is send the car for aircon svc especially cleaning up the evaporator coil.. Svc for the Air Con ard 160-200 max.. 7 Link to post Share on other sites More sharing options...
DACH Supersonic January 18, 2018 Share January 18, 2018 fr daiso, i normally put a pack in my ride to get rid of unwanted odours. download.jpg How long is its effectiveness? Link to post Share on other sites More sharing options...
zipping Supersonic January 18, 2018 Share January 18, 2018 How long is its effectiveness? abt 1mth, but i use longer than tat....also u need chk e packaging, cos some last as long as 3 mth (w some 'sun-tanning') 1 Link to post Share on other sites More sharing options...
DACH Supersonic January 18, 2018 Share January 18, 2018 abt 1mth, but i use longer than tat....also u need chk e packaging, cos some last as long as 3 mth (w some 'sun-tanning')I bought 2 types.One is the sticky paste like kind in a container. Another is the powered type in the cloth pack. Which one is better? Link to post Share on other sites More sharing options...
zipping Supersonic January 18, 2018 Share January 18, 2018 I bought 2 types. One is the sticky paste like kind in a container. Another is the powered type in the cloth pack. Which one is better? i usually go 4 e pellets type (easy to clean if accidently spill or packaging break)....but by function should b e same. Also i use a small shallow boxy 'plate' to hold e packs which i put under e car seat. often my ride will park under e hot sun...so i nvr like to buy water/paste base in-car stuff. 3 Link to post Share on other sites More sharing options...
Pocy Hypersonic January 19, 2018 Share January 19, 2018 Open window (for fresh air) for a short while each time after starting engine. Link to post Share on other sites More sharing options...
Jq1988 4th Gear January 29, 2018 Share January 29, 2018 Just discovered that old tea bag can be used as well to remove odour. Link to post Share on other sites More sharing options...
friedmian99 Neutral Newbie January 29, 2018 Share January 29, 2018 Just 2 days ago, my daughter spilled iced milo onto car mat in car, and now the car smell like garbage truck all the time despite wiping the stain away. Realised the spilled milo seeped into the bottom of car mat after the smell was detected, maybe that is why. Really feel like vomiting the first few minutes entering the car. Took out the car mat and washed, but the car still smell very badly without the car mat. Would like to seek help from anyone with similar experience. This is not new car smell or normal aircon mildew problem. Many thanks for helping. PM'ed - Got suggestion to test out.. If works, will be useful to share with fellow parents of young children -- heard infant milk spit-ups can also be extremely intense. Link to post Share on other sites More sharing options...
DetailGuru January 30, 2018 Share January 30, 2018 Type in your title into youtube with "ammo" behind it. He's a god. 1 Link to post Share on other sites More sharing options...
Lmws214 Turbocharged March 2, 2018 Share March 2, 2018 I use charcoal or baking powder to remove bad smell. Or at times I would buy pandan leaves too. Try to see which is better for you. Also depends on the type and kind of bad smell. Link to post Share on other sites More sharing options...
Discoburg Supersonic March 24, 2018 Share March 24, 2018 I will use pandan leaves to rid those roaches. I use charcoal or baking powder to remove bad smell. Or at times I would buy pandan leaves too. Try to see which is better for you. Also depends on the type and kind of bad smell. Link to post Share on other sites More sharing options...
DACH Supersonic March 27, 2018 Share March 27, 2018 I use charcoal or baking powder to remove bad smell. Or at times I would buy pandan leaves too. Try to see which is better for you. Also depends on the type and kind of bad smell. How often you change those charcoal packs? Every month? Is it good to put an air re freshener in the car? Link to post Share on other sites More sharing options...
ntuc2018 3rd Gear April 20, 2018 Share April 20, 2018 Sometimes the smell will seep into the leather and dashboard. That is why hard to get rid. Use baking soda and mix with water and can put some lemon. Then use the water to wipe ur leather and dashboard. Link to post Share on other sites More sharing options...
Dany321 Neutral Newbie April 24, 2018 Share April 24, 2018 If the smell is coming from a surface area like carpet, sprinkle some baking soda over the area. Let is sit overnight and then vacuum it the next day. As others mentioned, just leave an opened baking soda package like you would in the refrigerator. Link to post Share on other sites More sharing options...
JeffGan Neutral Newbie May 16, 2018 Share May 16, 2018 J6 Singapore do provide odour removal and sanitizing services. You are able to contact us @ 81816852. https://www.facebook.com/J6Singapore/ Link to post Share on other sites More sharing options...
KeineXX Neutral Newbie October 9, 2018 Share October 9, 2018 If nothing seems to work, then you should invest in a proper steam cleaning. It's helped me anytime I had to remove a bad smell or odor from my car, for example, cigarette smell. Link to post Share on other sites More sharing options...
Benchong05 3rd Gear October 25, 2018 Share October 25, 2018 If nothing seems to work, then you should invest in a proper steam cleaning. It's helped me anytime I had to remove a bad smell or odor from my car, for example, cigarette smell. Agree with that, invest in a good steam cleaner like Karcher and you can basically steam everything from your house floor to your car carpet or upholstery etc. ↡ Advertisement Link to post Share on other sites More sharing options...
Yes, ‘old person smell’ is a thing – but what causes it and can you neutralise it?
Smell of Singapore's Rich
How to remove stubborn stain on windscreen?
Best Air Refreshener To Put In Your Car.
Help to get rid of 3-days Fishy Smell
[Help Please] Strong smell of previous owner's car perfume does not go away
