Google 2nd Gear August 16, 2016 Share August 16, 2016 I was told for NV200, Renault engine have problem, there are a few case of injector problem. Not cheap to replaced. For those always on road, best to get front engine than seat base because in case of front accident impact, your leg might be at risk for under the seat engine as nothing in front to absorb the impact. For diesel engine vehicle, the air filter is the next important thing that many neglect. Black smoke is common for poor combustion due to dirty air filter. After driving diesel liteace for 12yrs, I find it getting nosier by the day. My next van will be NV200, but will be petrol, auto version. Yearly inspection will be a breeze than the diesel load test. ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 16, 2016 Share August 16, 2016 Yup have seen the location of the filter . A real screwed up design by the French. One reason I'm not buying another Renault. You would have thought they you have made enough mistakes by now.Yep, the location of the oil filter is a joke. Have to hoist up and down and up and down. Can't they just design it like the Japanese? To be frank when we bought the NV200 I didn't know it was using Renault engine until I bought the oil filter from the stockist. I was told for NV200, Renault engine have problem, there are a few case of injector problem. Not cheap to replaced. For those always on road, best to get front engine than seat base because in case of front accident impact, your leg might be at risk for under the seat engine as nothing in front to absorb the impact. For diesel engine vehicle, the air filter is the next important thing that many neglect. Black smoke is common for poor combustion due to dirty air filter. After driving diesel liteace for 12yrs, I find it getting nosier by the day. My next van will be NV200, but will be petrol, auto version. Yearly inspection will be a breeze than the diesel load test. Actually I find the emission test a joke. Have seen some really old lorries passing the test when it's emitting black smoke. Link to post Share on other sites More sharing options...
Kb27 Supersonic August 16, 2016 Share August 16, 2016 Yup have seen the location of the filter . A real screwed up design by the French. One reason I'm not buying another Renault. You would have thought they you have made enough mistakes by now. Changing a light bulb in a Megane Link to post Share on other sites More sharing options...
Mkl22 Twincharged August 16, 2016 Share August 16, 2016 Changing a light bulb in a Megane you remember the battery change you did for me where you had to hammer in the connector to the battery post? another unique french design. it got loose in 2 months and gave me a shock cause the van couldnt start. 1 Link to post Share on other sites More sharing options...
Xanavi 4th Gear August 16, 2016 Share August 16, 2016 I was told for NV200, Renault engine have problem, there are a few case of injector problem. Not cheap to replaced. For those always on road, best to get front engine than seat base because in case of front accident impact, your leg might be at risk for under the seat engine as nothing in front to absorb the impact. For diesel engine vehicle, the air filter is the next important thing that many neglect. Black smoke is common for poor combustion due to dirty air filter. After driving diesel liteace for 12yrs, I find it getting nosier by the day. My next van will be NV200, but will be petrol, auto version. Yearly inspection will be a breeze than the diesel load test. Air filter leads to black smoke? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 16, 2016 Share August 16, 2016 A dirty air filter does lead to black smoke. 1 Link to post Share on other sites More sharing options...
Xanavi 4th Gear August 16, 2016 Share August 16, 2016 (edited) A dirty air filter does lead to black smoke.Is it? Didn't know that. Thot the real culprit is the oil filter Edited August 16, 2016 by Xanavi Link to post Share on other sites More sharing options...
Kb27 Supersonic August 16, 2016 Share August 16, 2016 Is it? Didn't know that. Thot the real culprit is the oil filter Black smoke is unburnt fuel, thus a severely clogged air filter can produce black smoke. When you're revving the engine hard, fuel is pumped in, but not enough air, then you get black smoke. In a diesel engine, air is free flow, so the only blockage will be the air filter. Unlike a petrol engine, where the throttle body controls the amount of air coming in. Link to post Share on other sites More sharing options...
Xanavi 4th Gear August 16, 2016 Share August 16, 2016 Black smoke is unburnt fuel, thus a severely clogged air filter can produce black smoke. When you're revving the engine hard, fuel is pumped in, but not enough air, then you get black smoke. In a diesel engine, air is free flow, so the only blockage will be the air filter. Unlike a petrol engine, where the throttle body controls the amount of air coming in. Bo wonder I no black smoke before. Because I always suka suke take out and blow with compressed air. And change every servicing. Link to post Share on other sites More sharing options...
Beregond Supersonic August 16, 2016 Share August 16, 2016 Bo wonder I no black smoke before. Because I always suka suke take out and blow with compressed air. And change every servicing. choke air filter will cause black smoke, but very low % same as fuel and oil filter. most of the black smoke which u see from diesel vehicle is left over carbon in the exhaust. esp those with turbo, cause most driver when they shift gear , they dun rev the rpm high enough result in carbon struck in exhaust. before inspection if u know wat to to, just push water hose into exhaust and clear the carbon out. or just buy some anti smoke and find some ulu road and ram till all the carbon clear. some old vehicle die die cannot pass 1, have to find workshop to fix the fuel pump/ injector 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic August 17, 2016 Share August 17, 2016 Heng j still driving euro 2 old pigkarp Before inspection, wash the a**hole abit Link to post Share on other sites More sharing options...
Xanavi 4th Gear August 17, 2016 Share August 17, 2016 Heng j still driving euro 2 old pigkarp Before inspection, wash the a**hole abit Normally I go somewhere to red line for a while 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic August 17, 2016 Share August 17, 2016 Normally I go somewhere to red line for a whileHahaha me too! Changing a light bulb in a Megane Now surely this is a most apt pic Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 17, 2016 Share August 17, 2016 Newer vehicles not suitable to push water hose into exhaust due to the DPF. Link to post Share on other sites More sharing options...
Piyopico Supercharged August 17, 2016 Author Share August 17, 2016 Newer vehicles not suitable to push water hose into exhaust due to the DPF. Wow. Push water hose into exhaust to clear black smoke before inspection. I learn something new here everyday. If I get a diesel van, I might just try this. Hope it works on vans above 10 years old. Link to post Share on other sites More sharing options...
Kb27 Supersonic August 17, 2016 Share August 17, 2016 Wow. Push water hose into exhaust to clear black smoke before inspection. I learn something new here everyday. If I get a diesel van, I might just try this. Hope it works on vans above 10 years old. Link to post Share on other sites More sharing options...
mingx Neutral Newbie April 7, 2017 Share April 7, 2017 Hi all, sorry to hijack this topic as i cant start a new topic. Just to check with you guys, can a G plate commercial vehicle have chair at the back to let people sit? Cos i asked around and i get is G plate cannot have people sitting behind. However i did saw some van from government agency with a G plate but have chairs fix in the back to transport people.. Link to post Share on other sites More sharing options...
Mustank Hypersonic April 7, 2017 Share April 7, 2017 (edited) Hi all, sorry to hijack this topic as i cant start a new topic. Just to check with you guys, can a G plate commercial vehicle have chair at the back to let people sit? Cos i asked around and i get is G plate cannot have people sitting behind. However i did saw some van from government agency with a G plate but have chairs fix in the back to transport people.. A1) cannot install seat. But I know some vans perpetually transporting the same sofa. I wonder why A2) can have workers to sit behind. Please note: workers are a subset of people A3) see below Edited April 7, 2017 by Mustank ↡ Advertisement Link to post Share on other sites More sharing options...
Audio Shop Recommendation
Any recommendation for ear digging?
Durian Sellers - recommendations and to avoid
Heavy and rain proof curtains/blinder recommendations?
Recommendation for locksmith
