therock Supersonic September 11, 2018 Author Share September 11, 2018 Think dats 2 types of PS in merk,probably more. Mine's gotta PD- to registered a number,the last number I see is 6 before overdrive. Actually my queries on 9g is to Check weather u guys 're comfortable playing with the PS. I only learn the correct way when I change my steering wheel to the flat bottom,the shop guy's show the way. Previously when I ask,everybody tells me to keep pressing + Little than I realised dey might not noes also. Apologise ,I might come on a bit too strong. I don’t understand bro.. ↡ Advertisement Link to post Share on other sites More sharing options...
Vratenza Supersonic September 11, 2018 Share September 11, 2018 How to use Paddle Shift (for benefit of rest of mercedes owners): - Left paddle: single tap to down shift 1 gear. double taps to downshift 2 gears. The gear indicator will change from D to M (manual) and the current gear number will be shown. It stay in this mode till it times out if no further input to manually up or downshift. - Right paddle: single tap to up shift 1 gear. double taps to upshift 2 gears and so on. The gear indicator will change from D to M (manual) and the current gear number will be shown. It stay in this mode till it times out if no further input to manually up or downshift. *Tip: tap and hold the right paddle to revert to full auto mode (D) at any point during the (M) mode. I use this neat feature quite often. Eg. when approaching a tight curve with no traffic around, I will use the left paddle shift to downshift 1-2 gears such that the tachometer hovers around 3K RPM ( My power band drops off after 4K RPM), this will engine brake the car and allow me to go round the curve without braking and once pass the apex, i will step in on my accelerator to power out of the curve. While stepping in on the accelerator, I will press and hold the right paddle to hand over the gears control to the 9G-tronic, that way as the car accelerate from the curve, the AT can automatically up shift optimally without me having to bother when to upshift. 4 Link to post Share on other sites More sharing options...
Khng8 4th Gear September 11, 2018 Share September 11, 2018 Thanks for the tip. Have not used it becos don’t know how. Link to post Share on other sites More sharing options...
car50 Twincharged September 11, 2018 Share September 11, 2018 Bro, think there is an error in your calculation You forgot to minus 20k from 235+76k =291/13.5 = 21.5k dep/year so its 20k depr/year old car vs 21.5k depr/year new car over 10 years, thats about 1.5k more a year or $125 a month more, same as newbie calculation above bro Heman has a great deal, drives a brand new car for $125 more a month, with new warranty and service vouchers and other freebies http://www.mycarforum.com/topic/2708691-mercedes-c-class-2018/page-4?do=findComment&comment=6503894 I will use what I've posted previously to calculate, see if everyone agrees: Assuming paper value of both cars is the same = 20k Your current car annual dep is 220k - 20k/10 = 20k dep/yr New car depreciation is = 21.5k dep/yr, therefore new car cost = 21.5 * 10 + 20k = 235k Your depreciation for that 3.5yrs after trade in = 220k - 144k = 76k Total dep for your new car over 10yrs + Dep of old car over 3.5yrs = (235k + 76k)/ 13.5 = 23k dep/yr So: 20k dep/yr if you drive for 10yrs in your current car VS 23k dep/yr if you trade in your car + the new car price is 235k To me all the service credits shouldn't be computed as part of the "bleeding" cost cause that's one could argue that you "extended" your loans again, since you got them the first time you bought ur current car. I felt that it is the sales tactic to convince you that its worth it. Using this one can calculate what is the break even point to switch, to "bleed" less compare to current car. 8 Link to post Share on other sites More sharing options...
Angcheek Hypersonic September 11, 2018 Share September 11, 2018 How to use Paddle Shift (for benefit of rest of mercedes owners): - Left paddle: single tap to down shift 1 gear. double taps to downshift 2 gears. Ok this is very Cheem mathematics ............. Can you please explain how this is possible ! 3 Link to post Share on other sites More sharing options...
Vratenza Supersonic September 11, 2018 Share September 11, 2018 Follow me... 1+0=1 1+1=2 1+2=3 Ok this is very Cheem mathematics ............. Can you please explain how this is possible ! 1 Link to post Share on other sites More sharing options...
Kinklpet Neutral Newbie September 11, 2018 Share September 11, 2018 How to use Paddle Shift (for benefit of rest of mercedes owners): - Left paddle: single tap to down shift 1 gear. double taps to downshift 2 gears. The gear indicator will change from D to M (manual) and the current gear number will be shown. It stay in this mode till it times out if no further input to manually up or downshift. - Right paddle: single tap to up shift 1 gear. double taps to upshift 2 gears and so on. The gear indicator will change from D to M (manual) and the current gear number will be shown. It stay in this mode till it times out if no further input to manually up or downshift. *Tip: tap and hold the right paddle to revert to full auto mode (D) at any point during the (M) mode. I use this neat feature quite often. Eg. when approaching a tight curve with no traffic around, I will use the left paddle shift to downshift 1-2 gears such that the tachometer hovers around 3K RPM ( My power band drops off after 4K RPM), this will engine brake the car and allow me to go round the curve without braking and once pass the apex, i will step in on my accelerator to power out of the curve. While stepping in on the accelerator, I will press and hold the right paddle to hand over the gears control to the 9G-tronic, that way as the car accelerate from the curve, the AT can automatically up shift optimally without me having to bother when to upshift. Thank u for sharing. Was wondering how to make full use of the paddle shift Link to post Share on other sites More sharing options...
Voodooman Supersonic September 11, 2018 Share September 11, 2018 (edited) http://www.mycarforum.com/topic/2708691-mercedes-c-class-2018/page-4?do=findComment&comment=6503894 I will use what I've posted previously to calculate, see if everyone agrees: Assuming paper value of both cars is the same = 20k Your current car annual dep is 220k - 20k/10 = 20k dep/yr New car depreciation is = 21.5k dep/yr, therefore new car cost = 21.5 * 10 + 20k = 235k Your depreciation for that 3.5yrs after trade in = 220k - 144k = 76k Total dep for your new car over 10yrs + Dep of old car over 3.5yrs = (235k + 76k)/ 13.5 = 23k dep/yr So: 20k dep/yr if you drive for 10yrs in your current car VS 23k dep/yr if you trade in your car â+ the new car price is 235k To me all the service credits shouldn't be computed as part of the "bleeding" cost cause that's one could argue that you "extended" your loans again, since you got them the first time you bought ur current car. I felt that it is the sales tactic to convince you that its worth it. Using this one can calculate what is the break even point to switch, to "bleed" less compare to current car. All else being constant, depreciation per year should theoretically be lower with the drop in COE prices from, in this case, $75k to $32k, which should translate into saving of $4.3k a year, $360 a month and $9 a day. But those keen to change car will argue that if COE is still at $75k, the depreciation per year would have been much higher, perhaps close to $25k per year. So it is really about how itch is your backside and how deep are your pocket. Edited September 11, 2018 by Voodooman Link to post Share on other sites More sharing options...
Heman75 Supercharged September 12, 2018 Share September 12, 2018 (edited) All else being constant, depreciation per year should theoretically be lower with the drop in COE prices from, in this case, $75k to $32k, which should translate into saving of $4.3k a year, $360 a month and $9 a day. But those keen to change car will argue that if COE is still at $75k, the depreciation per year would have been much higher, perhaps close to $25k per year. So it is really about how itch is your backside and how deep are your pocket. Yes . Do it at your comfort level . Another reason why I enter now is because you can see alot of new models coming up with BMW Lexus and Merc. These belongs to cat b . I foresee cat b will up end year with cat A down . I maybe wrong Edited September 12, 2018 by Heman75 Link to post Share on other sites More sharing options...
fesa7044 2nd Gear September 12, 2018 Share September 12, 2018 Thanks for the tip. Have not used it becos donât know how.Dats exactly the problem.At least u come true,most ppl Yaya only ,u ask them,dey will say,juzz flip ++ only,veri easy. Can u use yr own words ? Its veri easy to copy & paste Right paddle: single tap to up shift 1 gear. double taps to upshift 2 gears and so on. The gear indicator will change from D to M (manual) and the current gear number will be shown. It stay in this mode till it times out if no further input to manually up or downshift. My take on dis PD thingy is basically for overtaking or downshift a gear or two earlier than the automatic can compute. To activate the PD,first u have to press - ,am sure u guys ve try & it dun work ,u can't juzz press + to start the PD. Also learn a few things from vratenza dat u press+and hold it 'll reach the OD faster. Anwae u need to reach OD than u can b back to auto. Link to post Share on other sites More sharing options...
Vratenza Supersonic September 12, 2018 Share September 12, 2018 (edited) To be frank, it takes alot of effort to try to understand what you are trying to express. Maybe english is not a language you are comfortable in. The sentence you cut and paste, and which I highlighted in bold, ARE MY OWN WORDS. Thanks for insinuating I am qualified to write an instruction manual. Let me clarify a few of your misinformation. 1. There is no practical situation on the road to need to go one gear higher manually from full auto (D). So why would anyone want to press the + paddle shift to activate the (M) mode? Just down gear immediately already. Edit: I have never even attempted to upshift from (D) mode, so cannot say for sure if (M) can be activate. Will try this evening and update here later. 2. Pressing and holding the + is to change from (M) to (D) mode. Nothing to do with OD (which I assume you meant over drive gear) which is the final gear in the transmission ie. 9th gear in 9Gtronic and 7th Gear in 7G-tronic. So you don't need to reach OD before you can return to (D) -full auto mode. Dats exactly the problem.At least u come true,most ppl Yaya only ,u ask them,dey will say,juzz flip ++ only,veri easy.Can u use yr own words ?Its veri easy to copy & pasteRight paddle: single tap to up shift 1 gear. double taps to upshift 2 gears and so on. The gear indicator will change from D to M (manual) and the current gear number will be shown. It stay in this mode till it times out if no further input to manually up or downshift.My take on dis PD thingy is basically for overtaking or downshift a gear or two earlier than the automatic can compute.To activate the PD,first u have to press - ,am sure u guys ve try & it dun work ,u can't juzz press + to start the PD.Also learn a few things from vratenza dat u press+and hold it 'll reach the OD faster.Anwae u need to reach OD than u can b back to auto. Edited September 12, 2018 by Vratenza 1 1 Link to post Share on other sites More sharing options...
Piyopico Supercharged September 12, 2018 Share September 12, 2018 All else being constant, depreciation per year should theoretically be lower with the drop in COE prices from, in this case, $75k to $32k, which should translate into saving of $4.3k a year, $360 a month and $9 a day. But those keen to change car will argue that if COE is still at $75k, the depreciation per year would have been much higher, perhaps close to $25k per year. So it is really about how itch is your backside and how deep are your pocket. When COE dropped 40k the price dropped 20k. Mystery of the missing 20k? 1.VES - for example car went from 20k discount to neutral band 2. AD profit margin - your AD just makan 20k more which brings me to point 3 3. Overtrade - Ta Dah....... that’s why they can offer 20-30k more 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic September 12, 2018 Share September 12, 2018 When COE dropped 40k the price dropped 20k. Mystery of the missing 20k? 1.VES - for example car went from 20k discount to neutral band 2. AD profit margin - your AD just makan 20k more which brings me to point 3 3. Overtrade - Ta Dah....... that’s why they can offer 20-30k more Link to post Share on other sites More sharing options...
Heman75 Supercharged September 12, 2018 Share September 12, 2018 When COE dropped 40k the price dropped 20k. Mystery of the missing 20k? 1.VES - for example car went from 20k discount to neutral band 2. AD profit margin - your AD just makan 20k more which brings me to point 3 3. Overtrade - Ta Dah....... that’s why they can offer 20-30k more Link to post Share on other sites More sharing options...
Pohtk 3rd Gear September 12, 2018 Share September 12, 2018 Bro, think there is an error in your calculation You forgot to minus 20k from 235+76k =291/13.5 = 21.5k dep/year so its 20k depr/year old car vs 21.5k depr/year new car over 10 years, thats about 1.5k more a year or $125 a month more, same as newbie calculation above bro Heman has a great deal, drives a brand new car for $125 more a month, with new warranty and service vouchers and other freebies Bro thanks for pointing out! Not a bad deal.. for the fresh leather smell! Link to post Share on other sites More sharing options...
Vratenza Supersonic September 12, 2018 Share September 12, 2018 Is it urban legend that if you go to PML and tell them that you are trading in your w205 for the G30 and at the same time considering the E class.......will they go all out to give you a deal you cannot refuse? When COE dropped 40k the price dropped 20k.Mystery of the missing 20k?1.VES - for example car went from 20k discount to neutral band2. AD profit margin - your AD just makan 20k more which brings me to point 33. Overtrade - Ta Dah....... that’s why they can offer 20-30k more Link to post Share on other sites More sharing options...
camrysfe 5th Gear September 12, 2018 Share September 12, 2018 same as red wine.. as long as you like it.. it will be a good wine. so as long as you are comfortable will be good enough .. i still stick by my way of calculation as i only consider the saving or excess based what is left on my ride. as for the service credit is a bonus. if i continue my ride i would have to spend money on servicing which will be saved with new car change. it may not amount to 6k outside but in cnc sure will hit. as for the loan portion , you extended the loan again but you also extend the life so it the same. for car it is for sure you lose money one. the only thing is how much. some ppl claim no change then no need to take out cash but have you thought by the 7th or 10th yr you change you also need to fork out cash.. it is a matter of now or later. the key should be minimized losses to ones acceptable value and enjoy the new car. by the 5th yr or so onwards, it is going to worth only paper value. I think the joy and satisfaction of driving a newer is intangible and not reflected in the calculation process. 1 Link to post Share on other sites More sharing options...
Piyopico Supercharged September 12, 2018 Share September 12, 2018 Let's do the jump. Nowadays it is no longer UDM. Just Sheer Driving Pleasure. Think the G30 is only slightly better drive than the E........... must think first the wide cockpit is nice ... jump ... Why you never jump ah? ↡ Advertisement Link to post Share on other sites More sharing options...
All BMW owner thread
W212 owners, please check-in
Mercedes CLE
Mercedes CLE
RE :Jaguar Owners Servicing
KIA K3 Owners check-in!
