attitude777 1st Gear December 31, 2016 Share December 31, 2016 Headlights are a little fogged. Was quoted 250 to sand/repolish the cover.Alternatively i looked at new headlight sets but headlights are functioning.I turned to taobao,and found many random useful parts, but no head light covers.Are there even such things for sale? :) ↡ Advertisement Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 31, 2016 Share December 31, 2016 Headlights are a little fogged. Was quoted 250 to sand/repolish the cover. Alternatively i looked at new headlight sets but headlights are functioning. I turned to taobao,and found many random useful parts, but no head light covers. Are there even such things for sale? :) Most of the headlights are one integrated unit, there is no cover unless the headlight design of your car is different. $250 sounds too expensive, yiu may want to ask ine or two more shop for quote. car polishing shop should be able to do the job? 1 Link to post Share on other sites More sharing options...
attitude777 1st Gear December 31, 2016 Author Share December 31, 2016 Most of the headlights are one integrated unit, there is no cover unless the headlight design of your car is different. $250 sounds too expensive, yiu may want to ask ine or two more shop for quote. car polishing shop should be able to do the job?Thanks. Car polishing service can also restore the headlights? The surface of the headlights feels a little grainy too. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 31, 2016 Share December 31, 2016 Go to autobacs, find a headlight polisher and diy. Link to post Share on other sites More sharing options...
GLZT 6th Gear December 31, 2016 Share December 31, 2016 Go to autobacs, find a headlight polisher and diy.Depends on the foggy part is inside or outside. Inside have to remove the cover and do. Link to post Share on other sites More sharing options...
attitude777 1st Gear December 31, 2016 Author Share December 31, 2016 Depends on the foggy part is inside or outside. Inside have to remove the cover and do.I realised it is not that difficult to remove. Ok. Will try autobac headlights solution and polish in and out. Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 31, 2016 Share December 31, 2016 I realised it is not that difficult to remove. Ok. Will try autobac headlights solution and polish in and out. Hi, those polishing contains abrasives that will damage the car paintwork. Before you start work , make sure you tape up the paint surrounding the lights to avoid damaging your paintwork. Link to post Share on other sites More sharing options...
Kangadrool Supersonic December 31, 2016 Share December 31, 2016 Best is to leave it as it is... unless you are changing it. The cataracts are there to remind you that your ride is ageing and need replacement. Good motivation for you to work harder for the next ride. 2 Link to post Share on other sites More sharing options...
RadX Moderator December 31, 2016 Share December 31, 2016 Best is to leave it as it is... unless you are changing it. The cataracts are there to remind you that your ride is ageing and need replacement. Good motivation for you to work harder for the next ride. after his Sec 2 lah....hor @attitude777 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 31, 2016 Share December 31, 2016 This one is quite safe to polish headlights. Link to post Share on other sites More sharing options...
attitude777 1st Gear December 31, 2016 Author Share December 31, 2016 after his Sec 2 lah....hor @attitude777 Link to post Share on other sites More sharing options...
inlinesix Supersonic December 31, 2016 Share December 31, 2016 Rem that headlight needs water tight seal. Link to post Share on other sites More sharing options...
13177 Supersonic January 5, 2017 Share January 5, 2017 Headlight polishing not really have use de, the headlight still looks foggy and improved slightly a bit only. Link to post Share on other sites More sharing options...
yokechye 4th Gear January 22, 2017 Share January 22, 2017 (edited) Use toothpaste to try first Edited January 22, 2017 by yokechye ↡ Advertisement Link to post Share on other sites More sharing options...
Selling Car through CARRO
Seat Covers
Seat Covers
Car seat covers
Car seat covers
Are LED lights subject to brightness checks?
2009 hyundai avante HD
Know any place that sell Hanes Beefy-T plain tee shirt?
