Deckbuild 6th Gear March 10, 2017 Share March 10, 2017 Hi, anyone can help on this? My McGard Lug nut key broke, anywhere I can get the lug nut removed? I know there's lug nut removal tool but no idea where to get it. ↡ Advertisement Link to post Share on other sites More sharing options...
Nzy Twincharged March 10, 2017 Share March 10, 2017 Hi, anyone can help on this? My McGard Lug nut key broke, anywhere I can get the lug nut removed? I know there's lug nut removal tool but no idea where to get it. Just go to any workshop. They can remove it easily. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 10, 2017 Author Share March 10, 2017 Just go to any workshop. They can remove it easily. I did but they can't, you have workshop to recommend? Thanks! Link to post Share on other sites More sharing options...
Nzy Twincharged March 10, 2017 Share March 10, 2017 I did but they can't, you have workshop to recommend? Thanks! The last time I went to eng wah tyre and battery. At Tpy. But the lug nut will be permanently damaged. Took less than a minute. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 10, 2017 Author Share March 10, 2017 The last time I went to eng wah tyre and battery. At Tpy. But the lug nut will be permanently damaged. Took less than a minute. Thanks bro, Ill got look for them, just wanna get it out and change to normal lug nut Link to post Share on other sites More sharing options...
Wattokkingu 3rd Gear March 10, 2017 Share March 10, 2017 Check if the tyre shop has a drill or if they can borrow one. Need to drill the lug nut, have to be very careful not to drill too much. Link to post Share on other sites More sharing options...
Nzy Twincharged March 11, 2017 Share March 11, 2017 Check if the tyre shop has a drill or if they can borrow one. Need to drill the lug nut, have to be very careful not to drill too much. Yeah. That is one method. The other methods I saw was welding another normal lug nut to the lock nut or hammer one into the lock nut. Link to post Share on other sites More sharing options...
Deadsoulz 1st Gear December 9, 2021 Share December 9, 2021 @Nzy Hi, do you mind sharing how much Eng Wah charge for removing the mcgard lock nut, I understand that the nut will be damage. I know this is a very old thread. But I am facing same problem :) Thanks in advance 1 Link to post Share on other sites More sharing options...
Deadsoulz 1st Gear December 10, 2021 Share December 10, 2021 14 hours ago, Deadsoulz said: @Nzy Hi, do you mind sharing how much Eng Wah charge for removing the mcgard lock nut, I understand that the nut will be damage. I know this is a very old thread. But I am facing same problem 🙂 Thanks in advance Update : Visited eng wah, the boss unable to help after checking his adaptor he has 😞 Link to post Share on other sites More sharing options...
Beregond Supersonic December 10, 2021 Share December 10, 2021 17 minutes ago, Deadsoulz said: Update : Visited eng wah, the boss unable to help after checking his adaptor he has 😞 if u driving conti, and those nuts come with the cars, i advice u to go back AD. unless u want to destroy the rims. Link to post Share on other sites More sharing options...
Deadsoulz 1st Gear December 12, 2021 Share December 12, 2021 Not original nuts. Its aftermarket mcgard nuts installed on my elantra. Anyway, I am ordering the lock key direct from Mcgard after they identify the lock key. Link to post Share on other sites More sharing options...
Ekiden Clutched January 5, 2023 Share January 5, 2023 @Deadsoulz how much did you get for the replacment? Link to post Share on other sites More sharing options...
Deadsoulz 1st Gear January 5, 2023 Share January 5, 2023 @Ekiden $100 for one lock key. Its a local shop that have all the different mcgard patterns. Link to post Share on other sites More sharing options...
Ekiden Clutched January 6, 2023 Share January 6, 2023 (edited) @Deadsoulz Hey.. Thanks for your reply hmm $100 is quite on the high side and i suppose is only the lock key without the nuts. may i know which shop? i did also email Singapore Mcgard distributor but no reply from them. My story here - Mine broke recently because i suspected "Previous tyreshop use pressure gun while tighten the flower nut". End up have to use a small socket to hammer over the nuts to remove them. Edited January 6, 2023 by Ekiden Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 6, 2023 Share January 6, 2023 (edited) Wheel Lock Nut removal Kit Edited January 6, 2023 by Yeobh Link to post Share on other sites More sharing options...
Ekiden Clutched January 6, 2023 Share January 6, 2023 @Yeobh Thank you yup i managed to remove them already 🙂 Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 6, 2023 Share January 6, 2023 @Ekiden Great Link to post Share on other sites More sharing options...
Deadsoulz 1st Gear January 6, 2023 Share January 6, 2023 @EkidenI experienced same issue as you, I even went to multiple tyre shop trying to hammer out, but not successful. I got my very expensive lock key frm : EWINS PTE LTD 39 Sungei Kadut Avenue SINGAPORE 729663 Telephone (65) 6459 3311 ↡ Advertisement Link to post Share on other sites More sharing options...
Lancer ex 1.6 can't accelerate
Mayhem in Afghanistan after US troops evacuate, 2021
What's So Special About These Cars
Large screw punctures man's motorcycle tyre along TPE -- a month after he paid $650 to change it
Man broke into house to PCC into panties
Ad hoc meetup with special guests and great food
Can't renew road tax - what happened?
