  • 1
  • Search this thread
  • Reply to this topic
14 replies to this topic | 20 praises
#1
Posted 02 May 2017 - 04:25 PM
Surf2004
  • THREAD STARTER
  • Premium member
    Surf2004
    1st Gear
    Author Image
    97
Hi, I plan to install Pioneer 8850 HU with front pair of components and rear coaxial speakers. Plus an active sub. All Pioneer brand.
Is it necessary to add an amplifier ? TIA !
#2
Posted 02 May 2017 - 05:39 PM
Fuelsaver
  • Premium member
    Fuelsaver
    Author Image
    8,598
Imho, if all pioneer brands no need since u have 13-band eq & time alignment to play with. The spkrs r not as premium to need amp. Install n demod cost oso lesser. Dual layer sound proof for doors will have some diff. Also add spkr front sponge ring to help direct all sound towards door spkr grille.
That being said, I'm not audiophile type. Just can hear all vocal & musical instruments is gd enuf for me..
FS
#3
Posted 02 May 2017 - 05:48 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    41,515
HU + Front component + Rear Coaxial + Active Sub.
No amp sure sound like sxxt
#4
Posted 02 May 2017 - 09:40 PM
Icetee168
  • Premium member
    Icetee168
    3rd Gear
    Author Image
    306
pioneer 8850 comes with its own amplifier but its only enough to power the stock speakers...for your case a amplifier is a must (at least is for me as everyone requirements for sound is different)
as for the active sub most comes with build in amplifier too esp those underseat woofer...
further if u r really into audio...it will b more cost efficient to upgrade amplifier first then follow by speakers...cheers n 2 cents
#5
Posted 03 May 2017 - 01:13 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    433
Depends a lot on how far u wanna go..
Work out your budget first then decide on what to do first. Doing everything 1 shot with cheaper equipments will make u upgrade very fast and that is going to cost u lots more $ in the long run.
Sometimes upgrading step by step is a nice process. Slow, but u learn and experience more and also saves you $$.
#6
Posted 03 May 2017 - 05:23 PM
Budgetice
  • Budgetice
    4th Gear
    Author Image
    624
Ur speakers are easy to drive type , dont need amp..
Fuelsaver praised this
be thankful... and life will be beautiful
#7
Posted 03 May 2017 - 05:59 PM
Jamesc
  • Premium member
    Jamesc
    2Fast2Furious
    Author Image
    192,518
Not necessary
but if you have money to burn why not?
It will make your hifi sound nicer.
:D
2BDriver and Mercs praised this
Say no to harsh artificial chemicals
that pollute the earth
and go natural. [thumbsup]
#8
Posted 05 May 2017 - 07:48 AM
Kar_lover
  • Premium member
    Kar_lover
    Author Image
    8,317
Your question is whether it is NECESSARY - so answer is simple: No.
But if you do install a good one then you will reap some benefits. My suggestion is don't install first and try it out. If you happy already then don't need. If after trying without amp you don't like, then you can add the amp later.
Not that i am bashing pioneer, but i am not sure how good your pioneer speakers are. Even if you add an amp, you still may not hear much difference if you speakers not up to it. You might have considered getting better speakers in the first place.
#9
Posted 05 May 2017 - 11:31 AM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    433
Nice to see diy stuffs...
#10
Posted 12 May 2017 - 10:02 PM
AlainDupuis
  • AlainDupuis
    3rd Gear
    Author Image
    389
An external amplifier is not required but it will improve the quality of the sound.
You can get entry level amps for less than SG$400 and it is worth the investment to optimise the aftermarket speakers performance.
The idea is not to play louder but cleaner. More power helps to drive the cone of the speaker accurately. Aftermarket speakers have much larger coils and magnets than stock junk that comes with most cars as standard OEM equipment. Have a look at the difference between your new speakers and the old ones, you will be surprised by the huge gap. They are designed to response more precisely to the electrical signals there are sent to them. A weak amplifier will struggle to power the larger speaker's coil for the cone to follow that signal resulting in distorted sound. At high power this can turn into clipping, sending DC current to the coil with potential damage to the amplifier or the speaker.
#11
Posted 12 May 2017 - 10:18 PM
ChristopherChia
  • ChristopherChia
    4th Gear
    Author Image
    613
For adding amp, which part of the car needs to be dismantled? The HU area only or the doors also?
Thanks.
Still2016 praised this
#12
Posted 16 May 2017 - 10:59 AM
Altis72
  • Premium member
    Altis72
    3rd Gear
    Author Image
    343
Thanks.
The amp can be installed under the car seats or in the car boot (if you have space.
#13
Posted 16 May 2017 - 05:18 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    433
Thanks.
All needs to be dismantled.
Dismantle headunit area to connect RCA to amp.
Dismantle door panels so that output from amp goes straight to speakers.
Bear in mind that lots of crappy installer will not dismantle your door panel, they will just connect the wire from amp to speaker wiring at your kick panel. Meaning the connections from the speaker to amps is 2 parts, the part from the speaker side being the lousy one will greatly limit what u can achieve.
#14
Posted 16 May 2017 - 07:45 PM
ChristopherChia
  • ChristopherChia
    4th Gear
    Author Image
    613
Wah, like that ah, i dont do already cos fixing the component, coaxial and tweeter speakers already heart pain....
#15
Posted 16 May 2017 - 09:31 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    433
Bro, no need heart pain. Since dismantle before, just do it again.. Hehee
  • 1
Back to In-Car-Entertainment  ·  Aftermarket Top Reply to this topic
Audison AP4.9 bit
Audison AP4.9 bit  |  Rating   Submit Review
Reviewed by Jaycee  |  Neutral Newbie
Awesome amp with build-in processor
This 4 channel or 2 way amplifier is built to cater for people like me looking for lots of power in it. Categorise in D class all range, has a 9 channel build-in processor in it to open up new possibilities out there. Unlike 31-band graphic e... » Read More
Pioneer GM-D8604 Multi-Channel Amplifier
Pioneer GM-D8604 Multi-Channel Amplifier  |  Rating   Submit Review
Reviewed by Acrispyhobo  |  Neutral Newbie
Compact in size, powerful bass too!
Recommended by Eric from TS Auto as I am looking for a amplifier after taking over my friend's de-kitted 2 channel speakers and subwoofer. I must say that this amplifier is really small compared to all the other brands. It instantly enhanced... » Read More
Related Product Guide search on sgCarMart.com : 1-Channel Amplifier, 2-Channel Amplifier, Multi-channel Amplifier
Quick Reply
Tags: amplifier, pioneer, head unit and 4 more...
