Spring Moderator October 23, 2017 Share October 23, 2017 apparently so, if want wet ones, have to wait for the 1.5 I thought all the facelifted Golfs come with wet clutch? So strange if some versions come with dry whilst others come with wet? ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Eyke Supercharged October 23, 2017 Share October 23, 2017 I thought all the facelifted Golfs come with wet clutch? So strange if some versions come with dry whilst others come with wet?dry ones for lower torque engine applications, thus the dry 1.0L. previous gens GTI/R using wet oso, so shouldn't be a surprise Link to post Share on other sites More sharing options...
Spring Moderator October 23, 2017 Share October 23, 2017 dry ones for lower torque engine applications, thus the dry 1.0L. previous gens GTI/R using wet oso, so shouldn't be a surprise Ok tks for info! They shld have brought in the 1.5l then, if anything to regain confidence back for the Golf which is an otherwise good car bar the GB issue. Then again I see the 1.0l being sold at $105k, so the 1.5l would likely be $10k more? in which case it wouldn’t be priced competitively. 4 Link to post Share on other sites More sharing options...
Eyke Supercharged October 23, 2017 Share October 23, 2017 Ok tks for info! They shld have brought in the 1.5l then, if anything to regain confidence back for the Golf which is an otherwise good car bar the GB issue. Then again I see the 1.0l being sold at $105k, so the 1.5l would likely be $10k more? in which case it wouldnât be priced competitively.depends on whether they bringing in the 128hp/148hp versions of the 1.5 Link to post Share on other sites More sharing options...
Felipe 3rd Gear October 23, 2017 Share October 23, 2017 dry ones for lower torque engine applications, thus the dry 1.0L. previous gens GTI/R using wet oso, so shouldn't be a surprise for the record, F1 uses a dry clutch. talk about lower torque. Link to post Share on other sites More sharing options...
Eyke Supercharged October 26, 2017 Share October 26, 2017 for the record, F1 uses a dry clutch. talk about lower torque. f1 change parts like change underwear 3 Link to post Share on other sites More sharing options...
Felipe 3rd Gear October 26, 2017 Share October 26, 2017 (edited) f1 change parts like change underwear but their cars are pushed to far greater limits than road cars so the more regular change is understandable. Each gearbox supposed to last around 4 races. The previous Ferraris till F430 all also used dry clutches. Anyway, if the concern was the dry clutch couldn't handle high torque, then it obviously isn't true. It just needs more regular parts changes. To put into perspective, while the wet clutch needs less regular changes, it also is a significantly more expensive part. So in the end, it doesn't have any monetary benefit over the dry. Edited October 26, 2017 by Felipe 1 Link to post Share on other sites More sharing options...
Eyke Supercharged October 27, 2017 Share October 27, 2017 To put into perspective, while the wet clutch needs less regular changes, it also is a significantly more expensive part. So in the end, it doesn't have any monetary benefit over the dry. not having gearbox die on u on the roads is a significant benefit. 2 Link to post Share on other sites More sharing options...
Felipe 3rd Gear October 27, 2017 Share October 27, 2017 not having gearbox die on u on the roads is a significant benefit.The gb won’t die on the road when clutch is wearing out. There’ll be pretty bad jerks which by then the mech will recommend to change. If it dies, it’s due to the actuators or pump which happens to either wet or dry clutch. Of cos if it dies n u don’t change, like timing belt, then u only have yourself to blame Link to post Share on other sites More sharing options...
Eyke Supercharged October 27, 2017 Share October 27, 2017 The gb wonât die on the road when clutch is wearing out. Thereâll be pretty bad jerks which by then the mech will recommend to change. If it dies, itâs due to the actuators or pump which happens to either wet or dry clutch. Of cos if it dies n u donât change, like timing belt, then u only have yourself to blame compare DSG failure to timing belt? do the DSG cars that suffered failure come with owner's manual that indicate the time/mileage to service DSG so it doesn't fail, as they do in the case of timing belt? if it doesn't, u still want to blame the owners? u VW white knight/apologist ah? Link to post Share on other sites More sharing options...
Enye Hypersonic October 27, 2017 Share October 27, 2017 (edited) compare DSG failure to timing belt? do the DSG cars that suffered failure come with owner's manual that indicate the time/mileage to service DSG so it doesn't fail, as they do in the case of timing belt? if it doesn't, u still want to blame the owners? u VW white knight/apologist ah? if he is an apologist, then it also means you are a basher Edited October 27, 2017 by Enye Link to post Share on other sites More sharing options...
Felipe 3rd Gear October 28, 2017 Share October 28, 2017 (edited) compare DSG failure to timing belt? do the DSG cars that suffered failure come with owner's manual that indicate the time/mileage to service DSG so it doesn't fail, as they do in the case of timing belt? if it doesn't, u still want to blame the owners? u VW white knight/apologist ah? Did i blame vw owners? Of cos it’s not their fault. But vw isn’t the only brand tat has problems outside of manufacturer recommended parts replacement. For eg, my relative mini need ignition coil change around 80k. Especially on conti cars or even jap cars, not possible to state every part major or minor due to be serviced to prevent failure. If stating what practically happens to many brands make me a vw white knight, then i guess im one for many car brands. And lastly, u may wana stick with jap cars if u have tat level of perfection in terms of reliability. Even a Ferrari would leave u disappointed im afraid if he is an apologist, then it also means you are a basher ð The basher doesn’t argue rationally Edited October 28, 2017 by Felipe Link to post Share on other sites More sharing options...
Keithchue 5th Gear November 7, 2017 Share November 7, 2017 hold up guys, anything about GB jerks and usage can ask me 3 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged November 7, 2017 Share November 7, 2017 (edited) compare DSG failure to timing belt? do the DSG cars that suffered failure come with owner's manual that indicate the time/mileage to service DSG so it doesn't fail, as they do in the case of timing belt? if it doesn't, u still want to blame the owners? u VW white knight/apologist ah? no timing belt. Use Timing Chain. just that the timing chain guide is the weakest link. Did i blame vw owners? Of cos it’s not their fault. But vw isn’t the only brand tat has problems outside of manufacturer recommended parts replacement. For eg, my relative mini need ignition coil change around 80k. Especially on conti cars or even jap cars, not possible to state every part major or minor due to be serviced to prevent failure. If stating what practically happens to many brands make me a vw white knight, then i guess im one for many car brands. And lastly, u may wana stick with jap cars if u have tat level of perfection in terms of reliability. Even a Ferrari would leave u disappointed im afraid The basher doesn’t argue rationally VW also need to replace coil Pack. but its not that ex. Jus change to to an upgraded S3 part or R8 part that is compatible and it should last. I would say VW / VAG are in general have their own set of quirks. Audi 2.0 T with wet clutch. You would think would be utimate liao. Yes ? good interior. Reasonable gearbox. Robust engine like the GTi. But it consumes engine oil like a RX8. Even the latest MK7 golf and to a lesser extend Jetta have a peculiar coolant tank/ water thermostat/ water pump failure at 40,000km mark. And we not even talking about modded Golf. Edited November 7, 2017 by Sdf4786k Link to post Share on other sites More sharing options...
Keithchue 5th Gear November 20, 2017 Share November 20, 2017 no timing belt. Use Timing Chain. just that the timing chain guide is the weakest link. VW also need to replace coil Pack. but its not that ex. Jus change to to an upgraded S3 part or R8 part that is compatible and it should last. I would say VW / VAG are in general have their own set of quirks. Audi 2.0 T with wet clutch. You would think would be utimate liao. Yes ? good interior. Reasonable gearbox. Robust engine like the GTi. But it consumes engine oil like a RX8. Even the latest MK7 golf and to a lesser extend Jetta have a peculiar coolant tank/ water thermostat/ water pump failure at 40,000km mark. And we not even talking about modded Golf. choy choy, mine 143 K Km, water pump still going strong, twin charged also Link to post Share on other sites More sharing options...
Jellandross Supersonic November 20, 2017 Share November 20, 2017 (edited) My GTI's water pump finally surrendered at 130k along with one of the two fans. I reckon that some of the rubber seals are dying too as water and oil leakages are starting to surface. I think there's no comparison with jap cars for wear and tear as the turbo stresses the parts like pipes and seals more than NA engine. The GB and clutch still swee swee no run water hopefully it'll last until end of COE *touch wood* Edited November 20, 2017 by Jellandross Link to post Share on other sites More sharing options...
Keithchue 5th Gear November 20, 2017 Share November 20, 2017 but hor, now I step oil, seems like the supercharger is spooling up with a bit of noise, some time have, sometime don't have Link to post Share on other sites More sharing options...
Felipe 3rd Gear December 6, 2017 Share December 6, 2017 My GTI's water pump finally surrendered at 130k along with one of the two fans. I reckon that some of the rubber seals are dying too as water and oil leakages are starting to surface. I think there's no comparison with jap cars for wear and tear as the turbo stresses the parts like pipes and seals more than NA engine. The GB and clutch still swee swee no run water hopefully it'll last until end of COE *touch wood* It’s not turbo. It’s jap ↡ Advertisement Link to post Share on other sites More sharing options...
Xpeng is Coming to Town
2017 Hyundai i30
2017 Hyundai i30
Kia Stonic
Kia Stonic
Volkswagen Sharan..
Volkswagen Sharan..
2011 VW New beetle
2011 VW New beetle
Formula 1 (2017)
Formula 1 (2017)
