awhtc 6th Gear August 23, 2018 Share August 23, 2018 Hearsay that Direct Injection accumulates carbon more easily as compared to Multi Point Injection but dunno how true ... Just to share lah cos I also hearsay niah ... So at times, it is recommended to add some of these cleaners to your fuel tank to do a 'Clean Up' ... A YouTube I watched showed that such additives are not effective. You need to dismantle and clean the injectors by force and solvent. ↡ Advertisement Link to post Share on other sites More sharing options...
Contipro 5th Gear August 23, 2018 Share August 23, 2018 A YouTube I watched showed that such additives are not effective. You need to dismantle and clean the injectors by force and solvent. Some recommend use good EO up to "SN plus" requirement. also more regular oil change. how regular oil change is regular, i have no specific info. Link to post Share on other sites More sharing options...
Si4dr 5th Gear August 26, 2018 Share August 26, 2018 Tks all bro for the input. Will try Kopites method first... Link to post Share on other sites More sharing options...
Kopites Supersonic August 26, 2018 Share August 26, 2018 Tks all bro for the input. Will try Kopites method first...yes try it. Off econ for one to two full tank. Off stop/start. If work (mksfiring at idling gone) than other can go down that route as well. if dont work than proceed to workshop. 1 Link to post Share on other sites More sharing options...
w7_lee 4th Gear August 27, 2018 Share August 27, 2018 yes try it. Off econ for one to two full tank. Off stop/start. If work (mksfiring at idling gone) than other can go down that route as well. if dont work than proceed to workshop. Nice to know. My friend's 2.5 year old Vezel also having occasional vibration problem (when at stop). It felt like the engine going to stall. He went to the mechanic and they connect the electronic thing to the car. It showed cylinder 2 not normal, so they replace with Denso OEM spark plugs (all 4) and vibration got worst. So the workshop put in original plugs from Honda. According to my friend, there is still occasionally vibration at stop but not obvious like before. I'll ask him to try using 95 and ECON off. Link to post Share on other sites More sharing options...
Golf7roy 4th Gear August 27, 2018 Share August 27, 2018 could be throttle body. consider SKM workshop to check the issue. 1 Link to post Share on other sites More sharing options...
Leo72 6th Gear August 27, 2018 Share August 27, 2018 Nice to know. My friend's 2.5 year old Vezel also having occasional vibration problem (when at stop). It felt like the engine going to stall. He went to the mechanic and they connect the electronic thing to the car. It showed cylinder 2 not normal, so they replace with Denso OEM spark plugs (all 4) and vibration got worst. So the workshop put in original plugs from Honda. According to my friend, there is still occasionally vibration at stop but not obvious like before. I'll ask him to try using 95 and ECON off. It's a known issue that Honda Vezel engine will encounter cylinder 2 misfire issue after certain mileage which will cause vibration problem. Just need to go to a workshop which specialise in fuel injector cleaning to do fuel injector cleaning. Link to post Share on other sites More sharing options...
therock Supersonic August 27, 2018 Share August 27, 2018 It's a known issue that Honda Vezel engine will encounter cylinder 2 misfire issue after certain mileage which will cause vibration problem. Just need to go to a workshop which specialise in fuel injector cleaning to do fuel injector cleaning. What kind of mileage are we talking about bro? Thanks Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 28, 2018 Share August 28, 2018 (edited) Sggarage is quite well verse in Honda Vezel stuff ... Can give them a ring for the injector misfire issue ... Just for reference niah ... me no collect commission from them one hoh ... http://sggarage.com/index.php?main_page=product_info&cPath=130_98&products_id=798 Edited August 28, 2018 by Mzrmazda3 2 Link to post Share on other sites More sharing options...
Browser 2nd Gear August 30, 2018 Share August 30, 2018 (edited) Tks all bro for the input. Will try Kopites method first... Nice to know. My friend's 2.5 year old Vezel also having occasional vibration problem (when at stop). It felt like the engine going to stall. He went to the mechanic and they connect the electronic thing to the car. It showed cylinder 2 not normal, so they replace with Denso OEM spark plugs (all 4) and vibration got worst. So the workshop put in original plugs from Honda. According to my friend, there is still occasionally vibration at stop but not obvious like before. I'll ask him to try using 95 and ECON off. Would be nice if you guys could report back with whatever fixes the problem. Whether it is econ off, clean fuel injector, go to sggarage, etc. Edited August 30, 2018 by Browser 1 Link to post Share on other sites More sharing options...
Kopites Supersonic August 30, 2018 Share August 30, 2018 Would be nice if you guys could report back with whatever fixes the problem. Whether it is econ off, clean fuel injector, go to sggarage, etc. ok..again I repeat. my case miss-firing during idling. my mechanics advised me to drive with econ mode off for a tank or two. Which i continued with my 95, econ off and the missfiring gone after a few weeks. Didn't cost me a single cent. if dont work good. otherwise than go to get it rectify at the workshop. no harm trying everyone. Link to post Share on other sites More sharing options...
issac6 Neutral Newbie September 1, 2018 Share September 1, 2018 hi guys, can i check, my left seat window seem to stuck, the window cant come down when i press the window down button. even i press the left seat window button, it dont have any reaction as well. is it faulty already? thank you Link to post Share on other sites More sharing options...
Kopites Supersonic September 1, 2018 Share September 1, 2018 hi guys, can i check, my left seat window seem to stuck, the window cant come down when i press the window down button. even i press the left seat window button, it dont have any reaction as well. is it faulty already? thank you likely to be the motor up lorry. Shouldnt be stuck otherwise you would hear tuk tuk sound. If motor spoil likely to be 100 to 200 plus range replacement. no big issue. Link to post Share on other sites More sharing options...
w7_lee 4th Gear September 8, 2018 Share September 8, 2018 Nice to know. My friend's 2.5 year old Vezel also having occasional vibration problem (when at stop). It felt like the engine going to stall. He went to the mechanic and they connect the electronic thing to the car. It showed cylinder 2 not normal, so they replace with Denso OEM spark plugs (all 4) and vibration got worst. So the workshop put in original plugs from Honda. According to my friend, there is still occasionally vibration at stop but not obvious like before. I'll ask him to try using 95 and ECON off. Spoke to my friend about driving with ECON off over the week. According to him, since the spark replacement, he's not been feeling the vibration after the first couple of days. 1 Link to post Share on other sites More sharing options...
Dp26 5th Gear September 11, 2018 Share September 11, 2018 Anyone changed their tyres already? What would you recommend for normal usage for stock 16” tyres? Thanks in advance! 1 Link to post Share on other sites More sharing options...
Tian6970 1st Gear September 11, 2018 Share September 11, 2018 Hi, Anyone went for the 60K full servicing. What is the damage ? Like to know estimated, so that I will not be carrot ! I know a few things had to replace, like coolant, spark plugs, ATF etc... Thanks in advance. 1 Link to post Share on other sites More sharing options...
Quicko Neutral Newbie September 13, 2018 Share September 13, 2018 Hi - my Vezel is 6mths old and has experienced the right windshield wiper juddering. Tried bending the wiper as seen on youtube. It helps but juddering come back after 2 days. Anyone had the same issue? 1 Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear September 13, 2018 Share September 13, 2018 Hi - my Vezel is 6mths old and has experienced the right windshield wiper juddering. Tried bending the wiper as seen on youtube. It helps but juddering come back after 2 days. Anyone had the same issue? Do you wax your ride often? If yes, then it is inevitable to get juddering cos your windscreen kena the wax residue liao Otherwise it might be the rubber on your wiper blade hardened liao and need a new replacement But if your windscreen is contaminated with wax residue or other stuff, change si mi wiper also useless one cos it will just continue to judder There are some cleaning agents which might be able to clean off the contaminants on the windscreen but if you do detailing using wax quite often, the same problem will come back. The above is from my experience after all these humble years of car ownership ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
