  • Search this thread
  • Reply to this topic
233 replies to this topic | 778 praises
#1
Posted 15 December 2017 - 09:06 PM
dcb
  • THREAD STARTER
  • Premium member
    dcb
    2Fast2Furious
    Author Image
    21,986
Need to change some lighting stuffs for the house. Any good electrician to recommend?
Hyundai Accent 2003, Honda GD1 Jazz 2004, Honda GE6 FIT 2008, Volkswagen Polo 6R 2012, Mazda 2 DJ Deluxe 2015............
#2
Posted 15 December 2017 - 09:16 PM
Jman888
  • Jman888
    Moderator
I am not sure what is the market rate, I asked one that I found from Gumtree.
they came to take out the 3 old ceiling lights and install the new ones I bought. $40 each light for their service.
but I won't recommend the one I engaged [laugh] they are not that bad but probably 80% of my expectations [sweatdrop]
Edited by Jman888, 15 December 2017 - 09:17 PM.
骑白马的不一定是王 ,可能是唐僧;带翅膀的也不一定是天使,有时候是鸟人。
#3
Posted 15 December 2017 - 09:18 PM
dcb
  • THREAD STARTER
  • Premium member
    dcb
    2Fast2Furious
    Author Image
    21,986
Wah $40 for each ceiling lights changed seems rather expensive. However good guideline bro Jman888
#4
Posted 15 December 2017 - 10:37 PM
Lmws214
  • Premium member
    Lmws214
    NOS-ed
    Author Image
    12,145
Look for Ah Peng.
He works for an electrician wiring company. He did my lighting points wiring for my flat. They may provide bulb changing services. His mobile is :- ‭+65 9653 3308‬
dcb and 1 Anonymous member praised this
Cheers,
#5
Posted 16 December 2017 - 09:26 PM
dcb
  • THREAD STARTER
  • Premium member
    dcb
    2Fast2Furious
    Author Image
    21,986
Will give Peng a call. Thanks. [thumbsup]
Look for Ah Peng.
#6
Posted 17 December 2017 - 06:56 AM
Othello
  • Premium member
    Othello
    2Fast2Furious
    Author Image
    54,325
Yes, best to find all these workers that do freelance outside working hours.
What exactly do you need to do ?
"O, devil, devil! If that the Earth could teem with woman's tears, Each drop she falls would prove a crocodile. Out of my sight!" (Act IV Scene I)
#7
Posted 17 December 2017 - 07:21 AM
Victor68
  • Premium member
    Victor68
    NOS-ed
    Author Image
    12,702
By right, you should engage one with licence. This is to ensure the installation is properly done for safety.
https://www.ema.gov....ed_Workers.aspx
By left, simple work can engage someone who really have enough experience. use the correct cable size, connect properly with good insulation, protected with the right mccb rating, wiring done with good mechanical protection.
Do be careful. [;)]
#8
Posted 17 December 2017 - 08:06 AM
dcb
  • THREAD STARTER
  • Premium member
    dcb
    2Fast2Furious
    Author Image
    21,986
Change the existing T5 bulbs in my cove light to LED T5 bulbs.
#9
Posted 17 December 2017 - 08:21 AM
Aristotle
  • Aristotle
    5th Gear
    Author Image
    1,958
Let me know how much they charge you. Am also thinking to do the same. Also cove ceiling lights
#10
UncleAtas
  • Premium member
    UncleAtas
    Author Image
    8,947
Your home high ceiling? Need long ladder?
Refer to signature guidelines
#11
Posted 17 December 2017 - 08:23 AM
Colin03
  • Premium member
    Colin03
    4th Gear
    Author Image
    868
Hi Bro,
You can give this guys a call for a Quote -->
Ahmad 96948309
Sam 83168324
Rex 86301299
Ricky 97369196
#12
Posted 17 December 2017 - 08:47 AM
dcb
  • THREAD STARTER
  • Premium member
    dcb
    2Fast2Furious
    Author Image
    21,986
Standard 5 room HDB flat
#13
Posted 17 December 2017 - 08:57 AM
UncleAtas
  • Premium member
    UncleAtas
    Author Image
    8,947
If its just swapping bulbs to LED. Should be easy. Cove lights u just pull out as it's just on a clip..
#14
Posted 17 December 2017 - 09:53 AM
Aristotle
  • Aristotle
    5th Gear
    Author Image
    1,958
I tried DIY, and some LED lights didn't light up. Also the terminal points are slightly different. So, for me getting an electrical expert to come in to take a look at my current setup will be the best option
#15
Posted 17 December 2017 - 10:25 AM
Jman888
  • Jman888
    Moderator
that was mine concern too, I bought some LED ceiling light from JB and thought of changing myself, open the cover and give up [laugh]
pay $40 each for them to dismantle and install with some drilling, etc. At least I dun get killed [sweatdrop] [laugh]
#16
Posted 17 December 2017 - 11:23 AM
Othello
  • Premium member
    Othello
    2Fast2Furious
    Author Image
    54,325
Do be careful. [;)]
Yeah, but it'll cost an arm and 2 legs!
Should be plug and play. Look at yourT5 lamp fitting. If its 2 hole power socket, just get back 2 hole ones
LED T5 usually is whole fitting, not tube
Actually is simple enough to DIY. Of cos I'm slightly exposed to the industry... Haha
Edited by Othello, 17 December 2017 - 11:28 AM.
#17
Posted 17 December 2017 - 11:36 AM
Victor68
  • Premium member
    Victor68
    NOS-ed
    Author Image
    12,702
Simple wrong connection of the cables can cause danger when replacing blubs even with the light switch in off position. so it good to play it safe.
Othello praised this
#18
Posted 17 December 2017 - 11:43 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    54,232
If it's fluorescent whether it's the round tube or the long tube the setup is different of that from the LED.  The fluorescent uses a ballast and starter while the LED uses a driver. So you need to remove the ballast and starter setup and replace it with a driver setup. Yeah. You will need someone qualified to do it if you dunno how.
If you are using the E127 lightbulb (screw type) it's quite straight forward and only requires a direct led bulb replacement.
Edited by Watwheels, 17 December 2017 - 11:43 AM.
Feel so rich. Or just an illusion?
#19
Roadrunner2029
  • Roadrunner2029
    2Fast2Furious
    Author Image
    37,129
If the screw holes are the same then it's easy if not then got to screw new holes either on ceiling or in light, a lot more work. I bought once Samsung magnetic type just use magnet to attach to existing light frame, no screws.
Wiring should be nothing special. LED should come with own driver, and don't connect to ballast for florescent light.
You did the right thing, if not sure then get help.
Edited by Roadrunner2029, 17 December 2017 - 12:00 PM.
#20
Posted 17 December 2017 - 11:46 AM
Othello
  • Premium member
    Othello
    2Fast2Furious
    Author Image
    54,325
Problem with this industry or A/C, plumbing etc... Many carry huge knives. And dishonest.
dcb and Mustank praised this
Quick Reply
