Mustank Hypersonic December 23, 2017 Share December 23, 2017 My colleague tell me home plugs is useless as he tried before. However he recommends changing to an Asus router for better wifi coverage.Starting that time My power line adaptation have to be restarted at an average of 2 months once for it to workI use for a few years Liao Recently it has to be restarted every week I think end of life liao Well nothing last forever ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 23, 2017 Share December 23, 2017 Took some photos. Shifted the router out of the cabinet but improvement little only. If shift to center of flat, sure will have better wifi signal in master bedroom. Inside the cabinet Master bedroom sockets 6 Link to post Share on other sites More sharing options...
Mustank Hypersonic December 24, 2017 Share December 24, 2017 Took some photos. Shifted the router out of the cabinet but improvement little only. If shift to center of flat, sure will have better wifi signal in master bedroom. Router desired location.jpg Inside the cabinet Inside cabinet.jpg Master bedroom sockets Master bedroom sockets.jpg Buy power line adaptor and one more router (set to bridge mode. Popular and challenger got cheap one for $30) lorSure work Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 24, 2017 Share December 24, 2017 Bro.. Yr cabinet has all lan cable run there. Juz add a strong AP in yr bed room will do. Link to post Share on other sites More sharing options...
Adrianli Hypersonic January 22, 2018 Share January 22, 2018 Just to update, i got a xiaomi mini mi router. Set it to bridge mode and changed the SSID to the same as my Singtel router. Connected the Mio tv to the mini mi router and it works. However my S8+ or Mipad do not auto switch wifi to the strongest signal. So have to manually select it. 2 Link to post Share on other sites More sharing options...
Kusje Supersonic January 23, 2018 Share January 23, 2018 Just to update, i got a xiaomi mini mi router. Set it to bridge mode and changed the SSID to the same as my Singtel router. Connected the Mio tv to the mini mi router and it works. However my S8+ or Mipad do not auto switch wifi to the strongest signal. So have to manually select it. Just turn off the wifi function on the xiaomi and use the wifi on my from the best placed router. 1 Link to post Share on other sites More sharing options...
Alpha78 6th Gear January 23, 2018 Share January 23, 2018 Just to update, i got a xiaomi mini mi router. Set it to bridge mode and changed the SSID to the same as my Singtel router. Connected the Mio tv to the mini mi router and it works. However my S8+ or Mipad do not auto switch wifi to the strongest signal. So have to manually select it. My two cents suggestion for your problems: First, I suspect in the newer flats the contractors should be using 2 sets of UTP network cables per room, one to provide network, the other to provide phone. If yes, you are in luck. The idea is to connect the ONT network port into the utility room panel port that leads to your room that's nearest the centre of the flat. Then in that room you setup your router. In order to feed the LAN signals back to the rest of the rooms, you will need to change the phone port into a LAN port in your room, as well as at the utility cabinet, then plug the LAN port on your router into this new port. Then you use a switch at the utility cabinet to link all these ports together. Option 2, get Google Wifi or mesh wireless devices. Use the LAN port to link back to the main router. This way you don't need to relocate your router, and by using LAN points, you will get maximum throughput. And you can put up as many devices as you need, to get enough WiFi coverage. The key advantage of mesh device over normal AP is that they can handover to each other seamlessly. Hope it helps. 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 23, 2018 Share January 23, 2018 Heng I go internet learn how to set up router and how to set up other routers as access points Link to post Share on other sites More sharing options...
DACH Supersonic January 23, 2018 Share January 23, 2018 Heng I go internet learn how to set up router and how to set up other routers as access points Good. Go learn this kind of things.Don't Google piak piak on the Internet. 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 23, 2018 Share January 23, 2018 Good. Go learn this kind of things. Don't Google piak piak on the Internet. Simi pika pika good hor Link to post Share on other sites More sharing options...
szekt 2nd Gear April 12, 2018 Share April 12, 2018 Hi looking to fix my LED lights: unable to switch on and suspect might be problem with driver; driver located at ceiling; any recommendations please? TIA 1 Link to post Share on other sites More sharing options...
Othello Supersonic April 12, 2018 Share April 12, 2018 (edited) Hi looking to fix my LED lights: unable to switch on and suspect might be problem with driver; driver located at ceiling; any recommendations please? TIA Go back to the shop where you bought to get the driver. Its not easy to find back a driver with same specs, have to really walk around and find. What sort of lamp is it ? Edited April 12, 2018 by Othello Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 12, 2018 Share April 12, 2018 Can get it from Aliexpress. Link to post Share on other sites More sharing options...
Buadongdong Twincharged April 12, 2018 Share April 12, 2018 (edited) Hi looking to fix my LED lights: unable to switch on and suspect might be problem with driver; driver located at ceiling; any recommendations please? TIA Maybe you can bring it back to where you bought it from and ask them to test it on the spot to verify. Remember to test the replacement on the spot as well if they do replace it for you. There are many range of LED lights available in the market. Some are classified from Bin 1(best grade) to Bin 4 (lousiest). Ask the supplier which bin it belongs to. If they don't know what you are talking about, then most prob those LEDs are cheapo ones with sub-standard drivers. Better to go with Reputable brands to last you a longer time. Edited April 12, 2018 by Buadongdong 3 Link to post Share on other sites More sharing options...
szekt 2nd Gear April 12, 2018 Share April 12, 2018 Thanks for all the replies; my LED was installed by developer and getting the designated electrician would cost me an arm and leg; hoping to “outsource” the repair to an external electrician 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 13, 2018 Share April 13, 2018 Thanks for all the replies; my LED was installed by developer and getting the designated electrician would cost me an arm and leg; hoping to “outsource” the repair to an external electrician Open it, take a photo and post it here. Clearly show the written markings on the driver. 1 Link to post Share on other sites More sharing options...
szekt 2nd Gear April 13, 2018 Share April 13, 2018 Don’t know how to post photos... a bit of a noob; I do know it is 20W driver Link to post Share on other sites More sharing options...
grandis123 4th Gear April 13, 2018 Share April 13, 2018 Don’t know how to post photos... a bit of a noob; I do know it is 20W driver ↡ Advertisement Link to post Share on other sites More sharing options...
Traffic junction without traffic lights
Simple home DIY repairs
Home Aircon
Home Aircon
