  • Search this thread
  • Reply to this topic
21 replies to this topic | 5 praises
#1
Posted 24 December 2017 - 12:13 AM
Lmws214
  • THREAD STARTER
  • Premium member
    Lmws214
    NOS-ed
    Author Image
    10,185
I just changed engine oil a few days ago , using eh Motul 8100 X-cess engine oil.
My feel is that my car is more responsive and more importantly it can stretch more mileage, from the usual 9 km per litre to 10.5 km per litre (same mobil petrol I am using). Same driving style and same usual route I am taking.
This is a good engine oil so far I have used. So far I have used Redline, Shell, Elf, Mobil.
More info can be read here below:-
http://www.motul.com...oughest-demands
Tianmo praised this
Cheers,
#2
Posted 24 December 2017 - 05:28 AM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,273
what car you driving now? does other brand like redline, shell , elf and mobil gives you  similar mileage compared to motul that you using now?
#3
Posted 24 December 2017 - 05:54 AM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,966
Same weight,  Redline is thicker which may explain the better FC.
#4
Posted 24 December 2017 - 08:28 AM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    13,041
Motul is expensive and quite good. if your fuel consumption does improve then you’ll probably recover the extra cost easily.
#5
Posted 24 December 2017 - 03:04 PM
Lmws214
  • THREAD STARTER
  • Premium member
    Lmws214
    NOS-ed
    Author Image
    10,185
stream. other oil so far does not give me this mileage, This motul is light and smooth oil, like it very much
Cheers,
#6
Posted 24 December 2017 - 03:45 PM
Soya
  • Soya
    2Fast2Furious
    Author Image
    33,379
I used it b4 on my GTI. Packaging say it made in vietnam. Can't say good or no good coz after every oil change, engine always feels smoother anyway....
#7
Posted 24 December 2017 - 07:26 PM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,273
yes agreed. every new oil that goes in will feel smooth and quiet. after certain mileage it will be rough and noisy.  personally i think alloil is more of less the same. you change cheap oil you change more frequently. you change expensive oil you frequency of changing is not that often cos we have the mind set we paid very ex for the oil why drain out so fast? in actual fact, the more frequent you change the oil the better. Nothing beats fresh oil in the engine.
#8
Posted 31 December 2017 - 10:58 PM
Lmws214
  • THREAD STARTER
  • Premium member
    Lmws214
    NOS-ed
    Author Image
    10,185
Edited by Lmws214, 31 December 2017 - 11:20 PM.
Cheers,
#9
Posted 01 January 2018 - 01:47 PM
Lmws214
  • THREAD STARTER
  • Premium member
    Lmws214
    NOS-ed
    Author Image
    10,185
thanks for sharing.
Cheers,
#10
Posted 01 January 2018 - 03:32 PM
minyoro
  • minyoro
    Author Image
    -2
#11
Posted 04 August 2018 - 06:08 PM
pegasi
  • pegasi
    Banned
i have tried both motul xcess 8100 and 300v, both 5w30
300v price difference almost double of 8100
but i strongly recommend 300v
comparing both, 300v improves engine more - alot quieter during cold start and idling at traffic light cannot feel any engine noise or vibration
fc also improved and most important, pickup n acceleration is better
note that 8100 is good, its on par with castrol edge titanium 5w30
and is better than mobil one 5w30
is just that 300v is way better than 8100 and castrol edge ti of the same viscosity
btw i am not affiliated to motul, castrol, mobil
just a consumer sharing the user experience
'Stupid is as stupid does' - Forrest Gump
#12
Posted 04 August 2018 - 06:23 PM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    13,041
Why not send for oil analysis to be more certain.
https://m.blackstone-labs.com
#13
Posted 04 August 2018 - 06:59 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    38,831
Motul oil is group V oil which is made in the lab.
Mobil 1/Castrol is hydrocrack PAO. Group IV oil.
Of course better la.
Edited by Davidtch, 04 August 2018 - 07:00 PM.
#14
Posted 04 August 2018 - 07:13 PM
pegasi
  • pegasi
    Banned
my point is, even within the brand itself, different model has different performance and quality
i have used xcess 8100 and 300v
conclusion is 300v is worth the premium
#15
Posted 05 August 2018 - 12:48 AM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,966
300v power racing is 5w30
8100 Eco-nergy is 5w30
they have 5w30 for 8100 xcess??
300v will not be worth the premium if you require higher TBN.
#16
Posted 05 August 2018 - 08:14 AM
pegasi
  • pegasi
    Banned
ohhh could be 8100 eco for 30 and xcess for 40
btw try 300v, its like magic
haha
#17
Posted 05 August 2018 - 09:09 AM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,966
haha
IMHO,  it is important to know which oil was used to compare with 300v because of your this statement
(figures round off)
oil type / Viscosity at 40°C / Viscosity at 100°C
300v power racing 5w30 / 64 / 11
8100 Eco-nergy 5w30 / 57 / 10
8100 x-cess 5w40 / 86 / 14
On specs,  for cold start   8100-5w30 will flow fastest, follow by 300v, follow by 8100-5w40
A better oil flow will result in better start up protection. Since the engine parts are "protected",  there will be less noise.
Also, it may be due to the ester content in the 300v that it is quieter during cold start, as my understanding from postings, that it will "cling" to metal parts.
With lower viscosity Viscosity at 100°C, engine will be smoother and FC improve if it is 300v-5w30 vs 8100-5w40.
Also again,  is the winter grade e.g. 0w 5w 10w important?   A lot of opinion says not applicable.
Look at the Viscosity at 40°C for the EO below.  The lower viscosity,  the easier the oil will flow.
8100 Eco-nery 0w30 / 53 / 10
Like you said,  must try the 300v.
Another oil for consideration,  Redline 5w30
Redline 5w30 vs Motul 300v power racing 5w30
Viscosity at 40°C - 62 vs 64
Viscosity at 100°C - 10.6 vs 11
HTHS - 3.8 vs 3.5
How it translate in real world..... must try lor.  [laugh]
#18
Posted 05 August 2018 - 09:15 AM
pegasi
  • pegasi
    Banned
as mentioned in my other post, comparing motul 300v 5w30 with shell helix ultra, mobil one fuel eco, motul 8100 eco, Castrol edge titanium, redline signature, amsoil, all of the same weight 30
ranking from best to worst in terms of performance n fuel efficiency from my own experience is
1. motul 300v (best)
2. redline signature
3. amsoil
4. motul 8100eco/ castrol edge titanium
5. mobil one
6. shell (worst)
price wise, 300v is 4x price of shell
so what you pay is wat u get
btw i am not a oil seller or car mechanic and has no affiliation with any of the above brands
#19
Posted 05 August 2018 - 09:33 AM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,966
3. amsoil
5. mobil one
6. shell (worst)
For FC,  Shell will certainly be worse - Viscosity at 100°C is 12.2
The rest I would think is closer to 11.
The advantage I find Shell has is PurePlus - their active cleansing technology.
The price point, to me, makes it very suitable to use for regularly cleaning.
Also,  can reverse varnish build up.
Eh... I only car owner.   [laugh]
P.S. For my application,  you may want to remove castrol edge titanium if it is the same one as what was used by one of the AD.  Not very long lasting.
#20
Posted 15 August 2018 - 02:57 PM
pegasi
  • pegasi
    Banned
not only shell, castrol and mobil also doesn't give the x factor feel that amsoil signature and motul 300v has
guess what u pay is what u get
Dynamics Mechanic Pte Ltd
Motul 8100 X-cess 5W40 Engine Oil
Motul 8100 X-cess 5W40 Engine Oil  |  Rating   Submit Review
Reviewed by Sdf4786k  |  NOS-ed
As good and better then the rest.
Needed a oil to use for a 9 year oil car. Car was already using the usual oil recommended from the agent. Since it would probably be the last oil change, wanted to try something different. Seem a huge improvement overall.
Reviewed by bleahx  |  2nd Gear
Quality is what you pay for
You just have to try it. I have been using this engine oil for a couple for days now, but this is the first oil that I have used that there was an immediate difference. I noticed how much quieter the engine idles right away. I feel that acce... » Read More
Related Product Guide search on sgCarMart.com : Motul 8100 X-cess 5W40, Motul 8100 X-Clean 5W30
Quick Reply
Tags: motul, 8100, x-cess, 5w40 and 2 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
