Meemee 5th Gear February 23, 2018 Share February 23, 2018 A fren spent a lot and bought all the best brands and no one wanted to sit the back seat of his car. Sound too boomy. It's not only the equipment it's also the tuning. ð Tune for the owner to listen not for the friend....... That what a audio shop told me ↡ Advertisement Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 23, 2018 Share February 23, 2018 Tune for the owner to listen not for the friend....... That what a audio shop told me Problem is my fren a bit deaf. Too much clubbing. Young people don't go clubbing. Spoil your ears only. 1 Link to post Share on other sites More sharing options...
Meemee 5th Gear February 23, 2018 Share February 23, 2018 Correct..... Then beat is ask gal to club in the car.. . Boom.boom.... boom .... Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic February 23, 2018 Share February 23, 2018 juz enquired a component speakers that could be nicely mounted onto the A-pillar, bringing the high and mid nearer to our ears ...costs $2k what is the brand and model? 2k include pillar or pod or just the speaker set? Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic February 23, 2018 Share February 23, 2018 Hello fellows, Are there any good speakers for a recommendation? Can name me a few of brand? I preferred good speakers, not the super high-end type (e.g. audiophile) because I do not intend to put the woofer in my car anymore as I need the space. So when I have the low taken away, I need to get a replacement to cover it. Again, I do not that super low end as well. i assume u r asking for 2-way components. any budget? personally i like DLS. The Helix sounds ok for the price too. the best ones i've heard are Focal Utopia Berylliums and the Morel Supremos. of course the source, amps and tuning differs. i don't like Ground Zero, German Maestro, Rainbow and Micro Precision Series 3. the MP 5 and above sound good though but it's quite expensive. you need to soundproof your front doors to create a box to achieve a deeper and fuller sound. Link to post Share on other sites More sharing options...
dcb Turbocharged February 23, 2018 Share February 23, 2018 Looking to replace the stock paper cone speakers in my ride. Plan to spend like $200 only. Any good brand to recommend for the value for money thing? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 23, 2018 Share February 23, 2018 Will u all believe if I say my direct hu driven eol diamond m651 component sounded better than my previous mosconi amped helix b62c component spkrs? Both current n ex cars front door dual layer sound proofed There r certain soft sounding instruments that I just couldnt hear fr my previous setup 1 Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic February 24, 2018 Share February 24, 2018 Just my two cents worth. Theres actually quite a few things that you can make improvements with your head unit. Explore the physics behind time arrival differences between audio sources. https://en.wikipedia.org/wiki/Interaural_time_difference And really, the more audio sources you have ie speakers, the more comb filtering you have. The "delay" function can really do wonders if you have a calibration microphone and a FFT software to analyze and compensate for comb filtering. Again, the key word here is "compensate" so no miracles expected. Also, proper crossovers do help in reducing the over distortion levels of individual ways of speakers. If your HF for example doesnt have a filter applied, then it'll be forced to produce low frequencies like 80hz for example that isnt supposed to be intended to HF drivers/tweeters. this 80HZ frequency when applied to a HF causes the diaphragm to move within its unintended range. Its simple to say when you're pumping in a pure sine wave of 80hz but when you're dealing with music which is a complex waveform, then it takes away a lot of imaging and clarity as the physical diaphragm is vibrating at a unintended frequency. Just my two cents worth :) Time alignment is for imaging. SQ is still dependent on the source, amplified by the amps and reproduced by the speakers. Proper staging and imaging and tuning complete the setup. Equipment and tuning, each have their role to play. Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 25, 2018 Share February 25, 2018 Will u all believe if I say my direct hu driven eol diamond m651 component sounded better than my previous mosconi amped helix b62c component spkrs? Both current n ex cars front door dual layer sound proofed There r certain soft sounding instruments that I just couldnt hear fr my previous setup I believe cos its simple physics. An amp adds distortion and the more distortion you hear the less details you hear. Common mistakes in hifi Adding amp always make the sound better Component is always better than Coaxail. Vacuum amps are always better than solid state Monkey hear monkey say. 1 Link to post Share on other sites More sharing options...
Yeobt Supercharged February 25, 2018 Share February 25, 2018 what is the brand and model? 2k include pillar or pod or just the speaker set? i cant recall the brand, but the circular speakers itself can be fixed right onto the A pillar without any mod to the pillars. they are sold in xtreme. Link to post Share on other sites More sharing options...
RadX Moderator February 25, 2018 Share February 25, 2018 Tan CHUAN Jin not bad Oh sorry .. wrong speaker 6 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 25, 2018 Share February 25, 2018 I believe cos its simple physics. An amp adds distortion and the more distortion you hear the less details you hear. Common mistakes in hifi Adding amp always make the sound better Component is always better than Coaxail. Vacuum amps are always better than solid state Monkey hear monkey say. Tks for enlightening. For me is paid few K to realize that Link to post Share on other sites More sharing options...
Hosaybo 6th Gear February 25, 2018 Share February 25, 2018 Tan CHUAN Jin not bad Oh sorry .. wrong speaker Ya lor.... Should be Halimah lah! Link to post Share on other sites More sharing options...
Meemee 5th Gear February 25, 2018 Share February 25, 2018 Tks for enlightening. For me is paid few K to realize thatSchool fees .. Some pay more then that also never learn ... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 25, 2018 Share February 25, 2018 School fees .. Some pay more then that also never learn ... Not easy, most times is trial n err esp spkr n amp combo since can't test n only can hear fr fren setup then become monkey see n do Link to post Share on other sites More sharing options...
Meemee 5th Gear February 26, 2018 Share February 26, 2018 (edited) Not easy, most times is trial n err esp spkr n amp combo since can't test n only can hear fr fren setup then become monkey see n doWell don't have to follow and audition other set.... Just be contented :) Don't always go around listen to others setup..... It have the ktv effect. The gal beside always more pretty ...... :) Price of speaker does not always justify the SQ..... And also depend on personnel preferences Edited February 26, 2018 by Meemee 3 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 26, 2018 Share February 26, 2018 Well don't have to follow and audition other set.... Just be contented :) Don't always go around listen to others setup..... It have the ktv effect. The gal beside always more pretty ...... :) Price of speaker does not always justify the SQ..... And also depend on personnel preferences Another issue is hearing shop setup n when installed on ride may sound diff, so I guess there r still some hits n misses Link to post Share on other sites More sharing options...
Meemee 5th Gear February 26, 2018 Share February 26, 2018 (edited) Another issue is hearing shop setup n when installed on ride may sound diff, so I guess there r still some hits n missesSome shop any how tune when speaker or amp is installed in the car .... Hoping you can be their return customer for upgrading project ...aka carrot head Recently, I have retune 2 of my friend car. One the staging is toward the right bottom Another no eq setting.... sound like junk .... Really disappointed with these audio shop... Friend drive off smiling off my carpark after tune the processor Edited February 26, 2018 by Meemee ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Audio Shop Recommendation
Any recommendation for ear digging?
