Sdf4786k Twincharged January 31, 2018 Share January 31, 2018 Was having a kopitiam discussion and someone express that a more laychay loop hole for subletting is not explore. That is to rent the fate first n then do paperwork of adding more people into the flat via the hdb updates for people staying there. Then the main tanant move out n collect rental income for the room. Is it a must for the main tanant to still stay there if the original tanant can move out and collect more rental from subletting the rooms out? ↡ Advertisement Link to post Share on other sites More sharing options...
Kzone 3rd Gear January 31, 2018 Share January 31, 2018 you can marry someone then sublet the place to her? Link to post Share on other sites More sharing options...
Acemundo Supercharged January 31, 2018 Share January 31, 2018 it is not only leychey it is unethical as well. in any case, any landlord worth his salt will have already drafted in tenancy agreement no subletting is allowed. so adding in more tenants only means you are violating the rules of the tenancy agreement. 3 Link to post Share on other sites More sharing options...
LPPL 6th Gear January 31, 2018 Share January 31, 2018 If you want to rent out whole unit to family. Just sign 2 room rental agreements with the same family but for 2 tenants and make sure that the total amount to the rental for the whole unit. If HDB ask, just say you are still occupier, just renting out rooms lor. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 31, 2018 Author Share January 31, 2018 it is not only leychey it is unethical as well. in any case, any landlord worth his salt will have already drafted in tenancy agreement no subletting is allowed. so adding in more tenants only means you are violating the rules of the tenancy agreement. But there is no rule to say if there is 3 rooms and the main tenant rented out the whole house and the other rooms can be sublet out ? Just that the main tenant just need to collect the money from the sub letted unit ? Link to post Share on other sites More sharing options...
Showster Twincharged January 31, 2018 Share January 31, 2018 (edited) But there is no rule to say if there is 3 rooms and the main tenant rented out the whole house and the other rooms can be sublet out ? Just that the main tenant just need to collect the money from the sub letted unit ? Every decent tenancy agreement and every decent agent will include the clause of non subletting. Subletting, or sharing of tenancy is allowed with the permission of the landlord. Some landlords also openly allow if you can pay the rent evey month and secure the tenants, subject to HDB and private limits of numbers. Most landlords will also raise the rent if the tenant numbers go up, factoring in potential wear and tear. But any tenant need to be properly registered. Else it is illegal. Edited January 31, 2018 by Showster 2 Link to post Share on other sites More sharing options...
Acemundo Supercharged February 1, 2018 Share February 1, 2018 But there is no rule to say if there is 3 rooms and the main tenant rented out the whole house and the other rooms can be sublet out ? Just that the main tenant just need to collect the money from the sub letted unit ? as @showster have elucidated and my earlier point as well, the main tenant would have signed a tenancy contract which in most likelihood, prohibit subletting. if main tenant still proceed to sublet without informing landlord, he is in breach of the tenancy agreement. 1 Link to post Share on other sites More sharing options...
Atrecord Supersonic February 1, 2018 Share February 1, 2018 Was having a kopitiam discussion and someone express that a more laychay loop hole for subletting is not explore. That is to rent the fate first n then do paperwork of adding more people into the flat via the hdb updates for people staying there. Then the main tanant move out n collect rental income for the room. Is it a must for the main tanant to still stay there if the original tanant can move out and collect more rental from subletting the rooms out? Don't understand leh. You meant the main tenant is trying to make $$ by subletting out the whole flat after he has rented the whole flat from landlord, but is not staying there himself thereby having more space/room to be rented out? I tot all subtenants details should be provided and included in the tenancy contract between the landlord and the main tenant? And any changes (add or reduce tenants) must be agreed by the landlord? 1 Link to post Share on other sites More sharing options...
Showster Twincharged February 1, 2018 Share February 1, 2018 Anything you can think of as gaps, the rules will eventually cover. Even subletting of bedrooms requires application to HDB as they re-state. The number of people has also dropped from 9 to 6, in line with private housing. Flat owner plus occupier plus tenant = 6 max. From May 1, occupancy cap for 4-room and larger HDB flats will be reduced from 9 to 6 people: HDB HDB announced the new occupancy cap in a press release on Thusday (Feb 1), adding that all flat owners must also obtain its prior approval before renting out their flats or bedrooms. "The changes seek to minimise disamenities caused by overcrowding, and to maintain a conducive living environment in our public housing estates," HDB said. The cap for 3-room and smaller flats remains unchanged at 6 persons and 4 persons respectively. 3 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged February 1, 2018 Author Share February 1, 2018 (edited) Don't understand leh. You meant the main tenant is trying to make $$ by subletting out the whole flat after he has rented the whole flat from landlord, but is not staying there himself thereby having more space/room to be rented out? I tot all subtenants details should be provided and included in the tenancy contract between the landlord and the main tenant? And any changes (add or reduce tenants) must be agreed by the landlord? yup thats true. Reason being is that there will be cases where the landlord or owner place it with the agent to rent out. The tenancy of the new potential landlord also expired at the current / old place. So far still not a problem. The problem is the new tanant manage to secure a new flat. So after reno and everything 3 months can shift out liao. BUT, being untruful for lack of a better word A$$hole, the new tenant will never volunteer this infor to the landlord or the agent as not many would rent the place out for 3 months, else the going rate would not be as cheap vs one year rental. In this case pretend to be stupid and sign a one year agreement with the intend to break the lease lor. So being even more greedy, start to sublet the whole unit and collect rental from newbie who needs just a room. I suppose with the recent rule to curtail the number of person for 3 rooms and 4 rooms would eradicate this type of behavior. Edited February 1, 2018 by Sdf4786k Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged February 1, 2018 Share February 1, 2018 maybe my engirsh lousy but i don't understand what talking you 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged February 1, 2018 Author Share February 1, 2018 maybe my engirsh lousy but i don't understand what talking you Haha sorry 1. Landlord get agent to rent out. 2. Agent unknowingly, never check the true intend of the new potential tanant 3. New tanant move in liao, but lease is one year. Yet already got keys to another unit that was purchase 4. The existing old landlord do not agree to 3 months rental so the tanant LL have to try to rent 5. Found out no one wants to lease for 3 months so pretend to rent for a year with the intent to break lease at 3 months 6. As the current job there has lots of people who also wants to rent but only a room, rent out room but tell new landlord to include the new tenant additional person in . 7. month 3 move out and continue to collect the rent from the 3 rooms and pay rent to existing landlord. Link to post Share on other sites More sharing options...
Vidz 6th Gear February 2, 2018 Share February 2, 2018 oh please, hope Singaporean can be more considerate and think of the neighbours living around. the rules are there to protect the neighbourhood (everyday folks living around) and not for selfish landlord to exploit. just saying 1 Link to post Share on other sites More sharing options...
Kusje Supersonic February 2, 2018 Share February 2, 2018 Haha sorry 1. Landlord get agent to rent out. 2. Agent unknowingly, never check the true intend of the new potential tanant 3. New tanant move in liao, but lease is one year. Yet already got keys to another unit that was purchase 4. The existing old landlord do not agree to 3 months rental so the tanant LL have to try to rent 5. Found out no one wants to lease for 3 months so pretend to rent for a year with the intent to break lease at 3 months - never collect 1m deposit meh? break lease still got to follow contractual terms. 6. As the current job there has lots of people who also wants to rent but only a room, rent out room but tell new landlord to include the new tenant additional person in . LL doesn't have to accept a change of tenant or additional tenants. 7. month 3 move out and continue to collect the rent from the 3 rooms and pay rent to existing landlord. LL finds out, can kick the sub-tenants out. Link to post Share on other sites More sharing options...
Watwheels Supersonic February 2, 2018 Share February 2, 2018 maybe my engirsh lousy but i don't understand what talking you You are not the only one. I'm guessing this is the intent... "Can I sublet my apartment w/o telling my landlord?" Tenant subletting the rooms out to others. Which is not legal. 2 Link to post Share on other sites More sharing options...
Othello Supersonic February 2, 2018 Share February 2, 2018 Haha sorry 1. Landlord get agent to rent out. 2. Agent unknowingly, never check the true intend of the new potential tanant 3. New tanant move in liao, but lease is one year. Yet already got keys to another unit that was purchase 4. The existing old landlord do not agree to 3 months rental so the tanant LL have to try to rent 5. Found out no one wants to lease for 3 months so pretend to rent for a year with the intent to break lease at 3 months 6. As the current job there has lots of people who also wants to rent but only a room, rent out room but tell new landlord to include the new tenant additional person in . 7. month 3 move out and continue to collect the rent from the 3 rooms and pay rent to existing landlord. Sounds doable to me ................. if can solve 6 & 7 6. kinda uncertain. I guess adding one more is ok. Other than that, most landlords will not agree. 7. If inexperienced tenants, still can smoke. Those with experienced in renting or those who are careful, will ask for proof of ownership (Landlord/Owner) Aiyah, if want to keng, still got other ideas. The idea above presents too many variables and subsequent "problems" Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged February 2, 2018 Share February 2, 2018 why is this even being discussed? Link to post Share on other sites More sharing options...
Icedbs Turbocharged February 2, 2018 Share February 2, 2018 Haha sorry 1. Landlord get agent to rent out. 2. Agent unknowingly, never check the true intend of the new potential tanant 3. New tanant move in liao, but lease is one year. Yet already got keys to another unit that was purchase 4. The existing old landlord do not agree to 3 months rental so the tanant LL have to try to rent 5. Found out no one wants to lease for 3 months so pretend to rent for a year with the intent to break lease at 3 months 6. As the current job there has lots of people who also wants to rent but only a room, rent out room but tell new landlord to include the new tenant additional person in . 7. month 3 move out and continue to collect the rent from the 3 rooms and pay rent to existing landlord. If the LL don't allow 3 months rental, then just look for another house. Why continue to rent one year with the intention to break lease after 3 months? ↡ Advertisement Link to post Share on other sites More sharing options...
Properties info
Properties info
Renovation budget that blows your mind
All HDB households to get S$300 in Climate Vouchers 2024-2027
Hdb flat renovation
Hdb flat renovation
Lawyer beating staff caught on cctv
Does HDB profit from selling flats?
Home-stay for holiday instead of Hotel? (AIRBNB)
Will my HDB flat be worth $0 when the lease expires?
