Brass 6th Gear February 3, 2018 Share February 3, 2018 Yes,my friend got 1,long Jams at Causeway,will overheat the Gearbox...Subaru,parts more expensive.Rather pay more for parts than have a toasted gearbox for snack... ↡ Advertisement Link to post Share on other sites More sharing options...
flashbang Turbocharged February 3, 2018 Share February 3, 2018 Arent both 2L car have same performance?Subaru has AWD, and better FC. Boxer engine is also supposed to have lesser vibration. Link to post Share on other sites More sharing options...
Zze121 3rd Gear February 3, 2018 Share February 3, 2018 Yes,my friend got 1,long Jams at Causeway,will overheat the Gearbox...Subaru,parts more expensive. That could be due to cooling system design issue, my stock 2 litre NA Subaru used to jam in custom for 3 hours x2times for every weekends and never had an overheating issue. Subaru parts can get cheap from stockies, maintenance outside are not that ex. In my 9yr plus usage, only a radiator change, a set of timing belt and spark plugs changed, water pump and front wheel bearing units changed which are costly, rest are usual running cost like brake pad, ATF oil, diff oil which only change in every 40km. Link to post Share on other sites More sharing options...
Diesel 1st Gear February 3, 2018 Author Share February 3, 2018 Am driving the 2L tucson for 2 years now. It is a reliable and comfortable family SubCompac SUV. The ride is good , taking on humps without hassle. With traction control ON, it can tackle twisty roads. I ride on ECO mode daily with fuel consumption at 9L/100km. Full tank 95 ron is about $100. The only gripe is the engine is 2L MPI with normal 6 speed auto. This gives it a sedate composure. If you are more enthusiatic, I would urge you to get the Tucson with 1.6 T with Dual Clutch. I am getting the Kona for my son. Reason being its fuel efficient and 1.0 T manual. He likes the ride. Maybe you can test drive too. Hi, thanks for sharing 9L/100km is quite acceptable for me. Have tried both the 1.6T & 2L back to back and felt the DCT gear shifting not as smooth/gradual as expected, maybe its my driving style. the kona 1.0T is also a feature-full car but the interior space didn't work out for me. My colleague just booked 1 2 weeks back awaiting delivery. to my pleasant surprise as well, YES! Tucson rear has aircon vent? Link to post Share on other sites More sharing options...
ER-3682 Twincharged February 3, 2018 Share February 3, 2018 That could be due to cooling system design issue, my stock 2 litre NA Subaru used to jam in custom for 3 hours x2times for every weekends and never had an overheating issue. Subaru parts can get cheap from stockies, maintenance outside are not that ex. In my 9yr plus usage, only a radiator change, a set of timing belt and spark plugs changed, water pump and front wheel bearing units changed which are costly, rest are usual running cost like brake pad, ATF oil, diff oil which only change in every 40km. The DCT Gearbox overheated is the Hyundai,not the Subaru is using CVT. Link to post Share on other sites More sharing options...
Watwheels Supersonic February 3, 2018 Share February 3, 2018 I think some ppl got some things wrong. Subaru parts aren't expensive. It's the labour that's expensive. Reason for being expensive is becoz of the boxer engine. Unlike an inline4 engine its spark plugs, timing belt, water pump are very hard to reach. Just search Youtube to see why. It's labour intensive. The bill reflects the parts cost inclusive of the labour but dan the labour cost is not reflected. LoL... Same with all workshops. Subaru being an awd takes more effort to move from stand still and up to speed hence fuel economy will suffer if you have plenty of start stop driving. Having a cvt gb isn't going to help much. IMO awd is just a marketing gimmick becoz driving on tarmac you cannot have the torque equally distributed front and rear on the wheels. The tires will burn out literally. So it's either front or rear wheel biased. Not much diff from a fwd or rwd car in our road conditions. There's not much offroad for you drive unless you go Malacca. If you want something predictable, easy to maintain I think the choice is clear between the two. No doubt predictable also means boring. Your choice I think will depend on your priorities. If me I will choose the one with an inline4 engine mated to a planetary gb and is fwd. 1 Link to post Share on other sites More sharing options...
Friendstar Supercharged February 3, 2018 Share February 3, 2018 Hi. I don't get you on the tarmac AWD part. Can explain? Link to post Share on other sites More sharing options...
Watwheels Supersonic February 3, 2018 Share February 3, 2018 (edited) Hi. I don't get you on the tarmac AWD part. Can explain? For awd or 4x4 means the power or torque is send to all 4 wheels front and rear and distributed equally. Let's say your car's engine produce 200Nm of torque hence each wheel receive 50Nm of torque(ignore transmission loses). I think that's easy to understand. This works well off road becoz grip isn't always there on all of the 4 wheels but on tarmac the grip on 4 wheels don't have a problem. The friction will burn it out after some driving. I was warned many times when I was going for off road course during NS. Cannot drive full time 4wd on tarmac. The differential must be disengaged. Differential is to connect the front and rear wheels to make them 4 wheel driven. Disengage will make the land rover go back to 2 wheel drive. Modern cars equipped with 4wd or awd are electronic and you have no mechanical controls like a land rover defender. Meaning the controls are done via the computer. It decides when to be 4wd/awd, not you. So in the mean time it's in 2wd most of the time. You can see for yourself. You have no controls to put how much % to the front or rear wheels becoz the car maker is worried you dunno how to use and break/damage the system. Awd system are more complex. They have more torque in 2 wheels and much less on the other 2 so that the tires won't burn out. But in terms of % torque distribution the car maker won't say. It's all computer controlled. Edited February 3, 2018 by Watwheels 1 Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear February 3, 2018 Share February 3, 2018 If me I will choose the one with an inline4 engine mated to a planetary gb and is fwd. This is excellent advice. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 3, 2018 Share February 3, 2018 just get a turbo forester. 3 Link to post Share on other sites More sharing options...
wpy 4th Gear February 3, 2018 Share February 3, 2018 Have short-listed these 2 and would like some comments on both models. Forester for good handling with better safety rating Tucson for better interior space & updated looks/design 1 Link to post Share on other sites More sharing options...
Erictan111 1st Gear February 3, 2018 Share February 3, 2018 Why dont consider toyota harrier turbo? Link to post Share on other sites More sharing options...
Zze121 3rd Gear February 3, 2018 Share February 3, 2018 Fun part abt AWD is it stick to the ground nicely round the corners. 1 Link to post Share on other sites More sharing options...
Lotr8445r 5th Gear February 4, 2018 Share February 4, 2018 (edited) just get a turbo forester.If u are willing to help him topup the difference, why not?Why dont consider toyota harrier turbo?Then he should consider X5, Q5 or GLC as they are even much better. At least more preimum in term of badge than Harrier Edited February 4, 2018 by Lotr8445r 3 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 4, 2018 Share February 4, 2018 If u are willing to help him topup the difference, why not? Then he should consider X5, Q5 or GLC as they are even much better. At least more preimum in term of badge than Harrier It's better to ignore troll like you. 5 dislike from me. 1 Link to post Share on other sites More sharing options...
Lotr8445r 5th Gear February 4, 2018 Share February 4, 2018 (edited) It's better to ignore troll like you. 5 dislike from me.LOL I was trying to made u see yourself as a troll by making the similar comment as want you have posted to TS. If TS is willing or can afford the price of Forester Turbo, he would not have made this post. You are just making 2 cents feedback to him. So i help him to do the same to u by answering u back. What a joke, u give me 5 dislike saying i am a troll instead. Dont worry, i will not give u 5 dislike back Cheers Edited February 4, 2018 by Lotr8445r 3 Link to post Share on other sites More sharing options...
Pocy Hypersonic February 4, 2018 Share February 4, 2018 Sunday morning leh .............. relax ..... peace ✌ 3 Link to post Share on other sites More sharing options...
The_mark 2nd Gear February 4, 2018 Share February 4, 2018 For awd or 4x4 means the power or torque is send to all 4 wheels front and rear and distributed equally. Let's say your car's engine produce 200Nm of torque hence each wheel receive 50Nm of torque(ignore transmission loses). I think that's easy to understand. This works well off road becoz grip isn't always there on all of the 4 wheels but on tarmac the grip on 4 wheels don't have a problem. The friction will burn it out after some driving. I was warned many times when I was going for off road course during NS. Cannot drive full time 4wd on tarmac. The differential must be disengaged. Differential is to connect the front and rear wheels to make them 4 wheel driven. Disengage will make the land rover go back to 2 wheel drive. Modern cars equipped with 4wd or awd are electronic and you have no mechanical controls like a land rover defender. Meaning the controls are done via the computer. It decides when to be 4wd/awd, not you. So in the mean time it's in 2wd most of the time. You can see for yourself. You have no controls to put how much % to the front or rear wheels becoz the car maker is worried you dunno how to use and break/damage the system. Awd system are more complex. They have more torque in 2 wheels and much less on the other 2 so that the tires won't burn out. But in terms of % torque distribution the car maker won't say. It's all computer controlled. Subaru are permanent AWD and what you described that owners cant control when the car goes into 2WD is only true for some of the other car brands using selectable 4WD system. https://www.subaru.com.au/car-advice/awd-vs-4wd ↡ Advertisement 1 Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
New Subaru XV
New Subaru XV
New Hyundai Tucson
New Hyundai Tucson
Kia EV9 Concept
Kia EV9 Concept
Kia Stonic
Kia Stonic
