hanayori 2nd Gear May 19, 2018 Share May 19, 2018 Wish to get help here. My car is Elantra Basic model. i crack the left tail light cover a few month ago. Now I got a new light and wish to change by my self. However, when I start to do DIY, I found there is an additional wire connect to the tail light. Is there anyone can advice what is this wire for? I think it looks like for the power source for reverse camera, or reverse sensor? The new light I bought do not have this wire. I attached the photos. Thanks The new light bought do not have this wire I checked the right tail light, do not have this wire ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Dadiao 1st Gear May 19, 2018 Share May 19, 2018 hmm ... just a asking a 'weird' question since never changed before ... is it possible to detach the cover from the chassis, and just change the cracked part, and keep all the electrical parts intact ? Less change, less problems ... 2 Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 19, 2018 Share May 19, 2018 Its a panel not a chasis. Find on YouTube how the whole housing is removed. Can't be that difficult to DIY. Link to post Share on other sites More sharing options...
hanayori 2nd Gear May 19, 2018 Author Share May 19, 2018 Its a panel not a chasis. Find on YouTube how the whole housing is removed. Can't be that difficult to DIY. Yes. I checked on the YouTube, do not have this wire. It is quite easy if do not have this wire. However, if have this wire it is difficult even you want to change the bulb of the light, because you can not remove the light from the car without cut it 1 Link to post Share on other sites More sharing options...
Cypher 4th Gear May 19, 2018 Share May 19, 2018 hmm ... just a asking a 'weird' question since never changed before ... is it possible to detach the cover from the chassis, and just change the cracked part, and keep all the electrical parts intact ? Less change, less problems ... Not recommended, the light assy is sealed(water proofed). Just changed the whole assy. Link to post Share on other sites More sharing options...
hanayori 2nd Gear May 19, 2018 Author Share May 19, 2018 hmm ... just a asking a 'weird' question since never changed before ... is it possible to detach the cover from the chassis, and just change the cracked part, and keep all the electrical parts intact ? Less change, less problems ... Can not find any information on change the cover only online. Change the whole light is easier than change the cover only, if without this wire. Because even in Hyundai manual they teach you how to change the bulb, which need to take the light out from car. Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear May 19, 2018 Share May 19, 2018 Can not find any information on change the cover only online. Change the whole light is easier than change the cover only, if without this wire. Because even in Hyundai manual they teach you how to change the bulb, which need to take the light out from car. Does your Elantra comes with reverse camera or reverse sensor? Perhaps you should try to connect the new tail-light, and engage reverse to see if the reverse sensor or camera working, if they are not working, that wire should be the power supply for the reverse camera and reverse sensor. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 19, 2018 Share May 19, 2018 Most likely grounding wire. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 19, 2018 Share May 19, 2018 could be power source tapping for spoiler light? your car got spoiler? Link to post Share on other sites More sharing options...
Cypher 4th Gear May 19, 2018 Share May 19, 2018 @TS, use this opportunity to do a proper wire tapping. Try to tap from the connector back end instead of splicing the new wire. Link to post Share on other sites More sharing options...
hanayori 2nd Gear May 20, 2018 Author Share May 20, 2018 I checked some friend in Hyundai, they do not know about this wire. Most likely Komoco locally added. I have written an email to Komoco service to asking. Actually should not have this kind of design. In this design, driver can not DIY change the lamp bulb, which should be ok to do DIY. (Even in user manual showed how to change bulb. ) Link to post Share on other sites More sharing options...
UncleAtas Turbocharged May 20, 2018 Share May 20, 2018 Wish to get help here. My car is Elantra Basic model. i crack the left tail light cover a few month ago. Now I got a new light and wish to change by my self. However, when I start to do DIY, I found there is an additional wire connect to the tail light. Is there anyone can advice what is this wire for? I think it looks like for the power source for reverse camera, or reverse sensor? The new light I bought do not have this wire. I attached the photos. Thanks IMG_8418.JPG The new light bought do not have this wire IMG_8423.JPG I checked the right tail light, do not have this wire IMG_8421.JPG U bought it brand new from Komodo? Link to post Share on other sites More sharing options...
hanayori 2nd Gear May 20, 2018 Author Share May 20, 2018 U bought it brand new from Komodo?Yes car bought from Komoco brand new. New lamp is not from Komoco Link to post Share on other sites More sharing options...
Cypher 4th Gear May 20, 2018 Share May 20, 2018 I checked some friend in Hyundai, they do not know about this wire. Most likely Komoco locally added. I have written an email to Komoco service to asking. Actually should not have this kind of design. In this design, driver can not DIY change the lamp bulb, which should be ok to do DIY. (Even in user manual showed how to change bulb. )Err.. which part of the design prevent you from changing the bulb yourself? 1 Link to post Share on other sites More sharing options...
hanayori 2nd Gear May 22, 2018 Author Share May 22, 2018 Err.. which part of the design prevent you from changing the bulb yourself?With that wire you can not dismount the lamp from the car. Link to post Share on other sites More sharing options...
GravityBlue 4th Gear June 4, 2018 Share June 4, 2018 With that wire you can not dismount the lamp from the car. Just a wild guess , it could be a signal source for reverse camera to activate when engage "R" gear. ↡ Advertisement Link to post Share on other sites More sharing options...
2024 Hyundai Kona Electric Debuts: Refreshed Design, 260-Mile Estimated Range
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
