DACH Supersonic May 26, 2018 Share May 26, 2018 Normally the lower end Business edition 320 will be sold at a 1 series prices. Normally all chope quite fast Looks like its just me, but it sure looks like a reincarnated Mitsubishi Galant from those pics And the steering wheel looks more like a Honda one. ↡ Advertisement Link to post Share on other sites More sharing options...
Carbon82 Moderator May 27, 2018 Author Share May 27, 2018 Normally the lower end Business edition 320 will be sold at a 1 series prices. Normally all chope quite fast Looks like its just me, but it sure looks like a reincarnated Mitsubishi Galant from those pics You are not alone. But more obviously, it is a mini G30, from all angles. 5 Link to post Share on other sites More sharing options...
Inlinefour Twincharged May 27, 2018 Share May 27, 2018 (edited) Is it due to VES +10k? F30 still ves $0...except 330e is -10k Just overall RRP increased Edited May 27, 2018 by Pohhenry Link to post Share on other sites More sharing options...
Dannnn 4th Gear May 28, 2018 Share May 28, 2018 (edited) Heard so much about the dying of diesel engine etc, but Seems like 320d still producing 330d seems better specs than 330i Edited May 28, 2018 by Dannnn 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic May 28, 2018 Share May 28, 2018 Heard so much about the dying of diesel engine etc, but Seems like 320d still producing 330d seems better specs than 330i 330e would be a better choice. 1 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged May 28, 2018 Share May 28, 2018 Thank goodness, there are still buttons to press in this new car! Not all touchscreen like Audis! Link to post Share on other sites More sharing options...
Mockngbrd Supersonic May 30, 2018 Share May 30, 2018 3 series is handsome.... but here in SG, PML after short while will start to bring in lelong low spec tiny engine models to sell to wannabes and rich housewives... destroy the image.Destroy how long liao still haven't destroy yet? Link to post Share on other sites More sharing options...
Rayoflight 5th Gear May 30, 2018 Share May 30, 2018 As usual, need to see the whole car in Msport kits to look nice Link to post Share on other sites More sharing options...
DACH Supersonic June 27, 2018 Share June 27, 2018 https://youtu.be/ni0HC_jwxfA 1 Link to post Share on other sites More sharing options...
Davidklt 6th Gear June 27, 2018 Share June 27, 2018 Surprised they used Hankook. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged June 28, 2018 Share June 28, 2018 330e would be a better choice. but the batt weight seems to kill part of the driving fun. Link to post Share on other sites More sharing options...
Rayoflight 5th Gear June 28, 2018 Share June 28, 2018 S.korean beat Germany in world cup mah Link to post Share on other sites More sharing options...
inlinesix Supersonic June 28, 2018 Share June 28, 2018 but the batt weight seems to kill part of the driving fun.True. Can on pure electric up to 50km if got place to charge Link to post Share on other sites More sharing options...
inlinesix Supersonic June 28, 2018 Share June 28, 2018 Thank goodness, there are still buttons to press in this new car! Not all touchscreen like Audis!I think most VAG high end products moving towards touchscreen Link to post Share on other sites More sharing options...
Carbon82 Moderator August 16, 2018 Author Share August 16, 2018 BMW has released the first details about the 2019 3-Series Expected to debut at the Paris Motor Show, the redesigned sedan promises to be sportier than ever as the automaker says the car’s center of gravity has been lowered by 10mm (0.4 inches). The car also weighs up 55 kg (121 lbs) less than its predecessor. The upgrades don’t stop there as engineers “significantly enhanced” rigidity levels and kept the car’s weight distribution at a perfect 50:50. BMW went on to say agility and steering precision has been improved thanks to a wider track and new axles. The 3-Series is renowned for its handling and engineers paid special attention to the car’s suspension. As part of this effort, they developed an innovative damping system which uses lift-related dampers. BMW says they operate “continuously and progressively in relation to the respective spring travel” and this allows road imperfections to be neutralized “gently and precisely.” While the standard suspension aims to strike a balance between sporty and comfortable, the M Sport Suspension definitely favors the former. Cars equipped with the sport suspension will have a 10mm (0.4 inch) reduced ride height and 18-inch lightweight wheels with mixed tires. According to BMW’s Head of Driving Dynamics, Peter Langen, the damping forces on the M Sport Suspension are approximately 20 higher than those on the standard suspension and this means the difference is “much more perceptible than before.” He went on to say the M suspension is now “much sportier, with more rigid bearings and stabilizers, harder springs and additional body struts.” Cars outfitted with the M Sport Suspension will only be available with the Variable Sports Steering system. BMW says the latter has been “specially reconfigured” for the redesigned sedan and will provide “much greater precision to slight steering movements, without seeming nervous in central position.” Other performance features include an M sports differential with an electronically controlled locking function that is linked to the Dynamic Stability Control system. BMW says this allows the differential to preemptively influence both understeering and oversteering without brake intervention. BMW was tight-lipped about performance specifications, but confirmed the 3-Series will be offered with a “thoroughly revised” four-cylinder petrol engine. The engine will be the most powerful four-cylinder ever fitted in a production BMW and it will be approximately five percent more fuel-efficient than its predecessor. Part of this increased efficiency is due to the car’s improved eight-speed automatic transmission. Speaking of eco-friendliness, the engine will come equipped with a particulate filter. BMW says this, along with other changes, will allow the engine to meet Euro 6d-TEMP standards. 6 Link to post Share on other sites More sharing options...
Inlinefour Twincharged August 16, 2018 Share August 16, 2018 Thank goodness, there are still buttons to press in this new car! Not all touchscreen like Audis! Not only buttons but handbrakes all gone for new models. :( Link to post Share on other sites More sharing options...
Aaronlkl Supersonic August 16, 2018 Share August 16, 2018 PML huat ah! 2 Link to post Share on other sites More sharing options...
Angcheek Hypersonic August 16, 2018 Share August 16, 2018 PML huat ah! many PI now doing BMW too ↡ Advertisement 1 Link to post Share on other sites More sharing options...
All BMW owner thread
MAZDA 6
MAZDA 6
My EV journey to the i4
