Vratenza Supersonic August 28, 2018 Share August 28, 2018 You go check LED headlamps if spoil is change whole headlamp or just the LED diode. Well, if im on Halogen light bulbs, i dun mind switching to Auto Headlights.But HID.... ↡ Advertisement Link to post Share on other sites More sharing options...
sHy3r 4th Gear August 28, 2018 Share August 28, 2018 (edited) You go check LED headlamps if spoil is change whole headlamp or just the LED diode. Hmm... i thot same as HID? Where it consist of Bulb, Balast and ECU? If change whole headlamp... mine cost above $1100... Edited August 28, 2018 by sHy3r Link to post Share on other sites More sharing options...
DACH Supersonic August 28, 2018 Share August 28, 2018 Hmm... i thot same as HID? Where it consist of Bulb, Balast and ECU? If change whole headlamp... mine cost above $1100...I think for BMW is change the while thing. Link to post Share on other sites More sharing options...
Mkl22 Twincharged August 28, 2018 Share August 28, 2018 Depending on your car ride height, it could also be because they adjusted their headlamp projection angle higher, hence making it seem as though they are on high-beam when they aren't. Alternatively, could also be headlight fault or they accidentally turned it on, and didn't notice. Hence, regular and active maintenance - as well as understanding how your car operates - should be strived for. However, there are those who will regard cars as means of transport and not bother. We can't win them all. BMW should be able to code. Check and see if can code your sensor sensitivity. old 2011 car lei bro.. going to send to metallic hell in about 2+ years. If the car model is bound for Europe most likely it has a headlight leveling system. Most cars with HID now have auto leveling as standard. Link to post Share on other sites More sharing options...
Mkl22 Twincharged August 28, 2018 Share August 28, 2018 You go check LED headlamps if spoil is change whole headlamp or just the LED diode. Yah change the whole lamp assembly. I have seen quite a few face lifted w212 with part of the rear leds blown. Sim tia to change the whole light. Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear August 28, 2018 Share August 28, 2018 I hate instrument clusters with lights that cannot be switched off in the day time.It's pointless to have clusters lit up when you are driving in the day because only a blind can't see what the needle is pointing.If you need to look at the speedo while driving, you can't drive. Stop driving. Get a bus. Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear August 28, 2018 Share August 28, 2018 Buy euro car is like that one lah.. every part is modular.. you can't change the single component. Has to replace entire module. Stupid if you must ask. Making money .. definitely. I can't stress which country's car is the cheapest to maintain. I believe all knows. Just a stigma in yourself being seen driving a "cheap"car cheapens you ?I believe in pocket got money. Not a car with no money in pocket. 1 Link to post Share on other sites More sharing options...
Inlinefour Twincharged August 28, 2018 Share August 28, 2018 BMW should be able to code. Check and see if can code your sensor sensitivity. The headlamps are really 1 kind Today afternoon dark sky cum heavy rain...Auto also never on Will go back AD to fix it Thanks Bro Link to post Share on other sites More sharing options...
Terrylmt Supercharged August 28, 2018 Author Share August 28, 2018 Also must remember to indent the 10k signal stalk option. I also indented one. What car bro? Well, if im on Halogen light bulbs, i dun mind switching to Auto Headlights. But HID.... Link to post Share on other sites More sharing options...
Inlinefour Twincharged August 28, 2018 Share August 28, 2018 LED bulbs r not expensive than HID. Link to post Share on other sites More sharing options...
DACH Supersonic August 28, 2018 Share August 28, 2018 If led headlamps or taillights gone...must replace whole unit It is very dear Depends on which car model. Link to post Share on other sites More sharing options...
Philipkee Twincharged August 28, 2018 Share August 28, 2018 To those airheaded and lofty-minded ones - Iâd ask them, what if we have a blackout suddenly? Crash and burn? That is why I sometimes gets frustrated when people don't on the headlights DURING daytime when driving in the tunnels like KPE or CTE tunnels. Link to post Share on other sites More sharing options...
TedBurnings Neutral Newbie August 28, 2018 Share August 28, 2018 Pure driver error but it's really annoying... and very dangerous too when you try to pass someone and then bam some dude that forgot to turn on his lights appears lol Link to post Share on other sites More sharing options...
Beanoyip Turbocharged August 28, 2018 Share August 28, 2018 That is why I sometimes gets frustrated when people don't on the headlights DURING daytime when driving in the tunnels like KPE or CTE tunnels. Tunnels still ok, since its quite brightly lit. It's usually the housing estate roads which are dangerous. Link to post Share on other sites More sharing options...
Philipkee Twincharged August 28, 2018 Share August 28, 2018 Tunnels still ok, since its quite brightly lit. It's usually the housing estate roads which are dangerous.I was replying to the other post. What if there was a sudden blackout? Don't forget the speed is high in tunnels. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic August 28, 2018 Share August 28, 2018 Switch on the headlights (and radio) while in Tunnel is always instructed by signs on the entrances of the tunnels. Reasons: - in case of sudden black out, the tunnel will be thrown into pitch black darkness. - if everyone does their part, the tunnel will still remain partially lit enough by the headlights to be driveable. - those who do switch on their headlights are riding on those who did for their own safety. - switch on radio so that important announcement can be broadcast to those in the tunnel, eg. If there is a major accident requiring the cars to evacuate via one of the exits. 3 Link to post Share on other sites More sharing options...
StingerGT 5th Gear August 29, 2018 Share August 29, 2018 Tunnels still ok, since its quite brightly lit. It's usually the housing estate roads which are dangerous.Not sure why nowadays really got more goondus without headlights on at night. You tap horn or flash light then gesture, all act blur, don’t want turn & acknowledge.. siao one. Link to post Share on other sites More sharing options...
Vratenza Supersonic August 29, 2018 Share August 29, 2018 It's because usually those that forget to switch on their headlights probably belong to the same group as road hoggers ....so they are pretty immune to being horned or flash. Not sure why nowadays really got more goondus without headlights on at night.You tap horn or flash light then gesture, all act blur, don’t want turn & acknowledge.. siao one. ↡ Advertisement Link to post Share on other sites More sharing options...
Unusual or Rare Cars - Part 3
Electric cars
Electric cars
Cars at Expo - Apr 2024
