  • 1
  • Search this thread
  • Reply to this topic
7 replies to this topic | 5 praises
#1
Posted 29 September 2018 - 12:00 PM
DACH
  • THREAD STARTER
  • DACH
    2Fast2Furious
    Author Image
    62,713
DS7 Crossback E-Tense 4×4 – SUV PHEV with 296 hp
https://paultan.org/...ev-with-296-hp/
This is the DS7 Crossback E-Tense 4×4, a plug-in hybrid variant of the French SUV that was revealed in 2017. According to the company, the PHEV model marks an important point in its future as all new models will be electrified versions thereafter.
Focusing on the powertrain first, the DS7 Crossback E-Tense 4×4 features a 1.6 litre turbocharged four-cylinder PureTech petrol engine that makes 197 hp (200 PS) at 5,550 rpm and 300 Nm of torque at 3,000 rpm. An EAT8 eight-speed electrified automatic transmission is mated to the engine.
The internal combustion engine (ICE) is helped along by two 107 hp (109 PS or 80 kw) electric motors – one on each axle to provide all-wheel drive. DS Automobiles notes that the unit at the front has a higher torque output at 337 Nm compared to the 166 Nm at the rear.
Put together, the end result is a total system output of 296 hp (300 PS) and 450 Nm, which is good for a 0-100 km/h time of 6.5 seconds, while the usual highway overtaking sprint from 80-120 km/h takes just 4.4 seconds. While running on the ICE, the vehicle’s top speed is 220 km/h but is lowered to 135 km/h when only the electric motors are in play.
Those motors draw power from a vehicle floor-mounted, 120 kg, 13.2 kWh lithium-ion battery (90 kW power rating) that operates between 240-400 volts, allowing the SUV to travel on electricity alone for up to 50 km (WLTP). Meanwhile, the claimed combined fuel consumption figure is around 2.2 litres per 100 km (WLTP), while CO2 emissions is below 49 g/km.
By default, the car starts in Zero emission mode whereby only the electric motors provide the motivation. Drivers can also swap to Hybrid mode that summons the ICE into action when needed, Sport mode for maximum performance, and 4WD mode when optimum traction is necessary on varying terrain. A final mode, E-Save, preserves enough energy to drive in all-electric mode for the last 10-20 km of a journey.
As for recharging the battery, it’ll take about two hours when the SUV is plugged (Type 2 connect) into a 6.6 kW charger linked to a 32 A power point, four hours with a 14 A plug, and eight hours on a domestic 8 A plug. Other means of getting the battery juiced up are via regenerative braking or using the ICE as a generator.
Visually, the car looks largely indifferent from a regular DS7 Crossback aside from the addition of a charging port on the left side of the vehicle, as well as the letter ‘E’ embossed on the gear lever – a nod to the DS E-Tense concept from 2016.
DS7-Crossback-E-Tense-2-e1537852403596-8
Carbon82 praised this
Dream car: Lamborghini Murcielago 6.2
#2
Posted 27 December 2018 - 07:24 PM
DACH
  • THREAD STARTER
  • DACH
    2Fast2Furious
    Author Image
    62,713
Seems like this car is on sale in Singapore.
#3
Posted 28 December 2018 - 04:04 AM
Koster
  • Premium member
    Koster
    2nd Gear
    Author Image
    220
How to charge if dont stay in landed property?
#4
Posted 28 December 2018 - 09:12 AM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    38,188
Charging station.
#5
Posted 28 December 2018 - 09:15 AM
Koster
  • Premium member
    Koster
    2nd Gear
    Author Image
    220
Charging station.
Have to leave it there for a few hours. Wouldn't it be a hassle?
#6
Posted 28 December 2018 - 09:21 AM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    38,188
Please read up on EV.
Over lunch, you will get 80% of battery charged.
#7
Posted 28 December 2018 - 09:37 AM
Koster
  • Premium member
    Koster
    2nd Gear
    Author Image
    220
I see. Thanks for sharing.
#8
Posted 30 December 2018 - 09:38 PM
mel1888
  • mel1888
    1st Gear
    Author Image
    98
Looks good....wait....its french, skip.
  • 1
Back to Conti Talk  ·  Car Brands Top Reply to this topic
Quick Reply
Tags: citroen, ds7, hybrid, crossback and 1 more...
