QiQiDude Clutched October 28, 2018 Share October 28, 2018 Hello,i have a little problem after i did a stage 1 ecu remapmy mpg has decreased significantlywhen driving in town i can see the km range drop every 5 - 10 seconds by 1 kmexample whan i start up the car i have 250km left on fuel and after mayby 5km of driving it dropped to 210,while driving very normalwhen driving on the highway and using cruise control it comsumes fuel normally (or even better?)does anyone knows what the problem is?its a bmw 520d - year 2010- manual - 163hp versioni have asked the tuner to just push the engine to it's limits without dangering the car componentsi did not ask him anything about fuel efficiencycould it be that he remapped the engine so i have non stop torque at the low rpm's (like 0 - 2000 rpm)if so, would lowering the torque from 0 - 2000 rpm will get me a better fuel efficiency?i have added a picture, these are the results of the remapthank you in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Zxcvb Turbocharged October 28, 2018 Share October 28, 2018 BMW 5 series in manual transmission?? That’s very very rare in Singapore. Link to post Share on other sites More sharing options...
QiQiDude Clutched October 28, 2018 Author Share October 28, 2018 hi im from belgium not singapore Link to post Share on other sites More sharing options...
Ishiwgao 3rd Gear October 28, 2018 Share October 28, 2018 (edited) Hello, i have a little problem after i did a stage 1 ecu remap my mpg has decreased significantly when driving in town i can see the km range drop every 5 - 10 seconds by 1 km example whan i start up the car i have 250km left on fuel and after mayby 5km of driving it dropped to 210,while driving very normal when driving on the highway and using cruise control it comsumes fuel normally (or even better?) does anyone knows what the problem is? its a bmw 520d - year 2010- manual - 163hp version i have asked the tuner to just push the engine to it's limits without dangering the car components i did not ask him anything about fuel efficiency could it be that he remapped the engine so i have non stop torque at the low rpm's (like 0 - 2000 rpm) if so, would lowering the torque from 0 - 2000 rpm will get me a better fuel efficiency? i have added a picture, these are the results of the remap thank you in advance carr.png Hello. welcome. for your info this is a Singapore car forum, hence many topics are linked to singapore. regarding your concern on the torque, you can see from the torque lines (orange lines that looks like an inverted "V") that the before and after is different only at 2000rpm. the torque before 2000rpm is the same as stock. Therefore, your suggestion of "lowering the torque from 0 - 2000 rpm" will not change anything. regarding yoru concern on mpg decreased after ecu remap. ecu remap isn't some magic of just changing your torque vs rpm graph. it requires changing parameters such as ignition timing, fuel injection timing and cycles, fuel pressure, throttle input maps, torque limiting map, turbo boost etc. increasing torque can be as simple as removing the torque limiting map (though it's always not so simple). In your case, I don't know what the tuner did, but he might have adjusted fuel injection, fuel pressure and ignition parameters on top of the torque limiting map. Because those are changed, it affects your engine performance at all rpms, so driving around town will give you lower mpg than normal. regarding your REAL problem "when driving in town i can see the km range drop every 5 - 10 seconds by 1 km" , this is not a problem. every car experiences the same thing, and it has nothing to do with your ecu remap. the 250km range shown on your car is just an estimate calculated by the computer based on an averaged city/highway driving. if you drive around town, the car consumes more fuel due to idle and low speed driving, so of course the range estimated by the computer will keep decrease. when driving on the highway, the car consumes less fuel, so it is only normal that you will get "better" driving range. it's not technically better, because that's what the car can do originally. you only think it's better because of what the ecu tells you before. Edited October 28, 2018 by Ishiwgao 5 Link to post Share on other sites More sharing options...
QiQiDude Clutched October 28, 2018 Author Share October 28, 2018 (edited) thank you for the explanation makes allot of sense now i know my problem is not the torque below 2000rpm you are right its normal that your km range drop while driving after start up but after the remap it drops by 40 - 50 km and not 4 - 10km like before the remap should i go back to the tuner and ask him if he can finetune the remap so i get normal mpg driving in town? or what should i ask him? (because i don't know much about cars) Edited October 28, 2018 by QiQiDude Link to post Share on other sites More sharing options...
Vratenza Supersonic October 28, 2018 Share October 28, 2018 Most of the time, tuning the Ecu is a zero sum game unless you have upgraded components added. Almost all of the time, car manufacturers would have already spent hundreds if not thousands of manhours tuning and refining the Ecu maps of each model before releasing it. What you can achieve out of tuning the stock factory car is to achieve certain driving characteristics eg. More low end torque but that will usually means at higher end you might loss power. Something's gotta give. For driving around town, 467nm of torque arriving at 2k rpm is overkill and waste of fuel as you will just be burning up fuel at faster rate for the kind of acceleration you don't need around town. Something's gotta give... And in this case is your fuel consumption. 1 Link to post Share on other sites More sharing options...
QiQiDude Clutched October 29, 2018 Author Share October 29, 2018 (edited) So wait I cant go back and ask him to finetune the remap? Like more mpg for mayby less power? should i ask him to finetune all the things that ishiwgao said like changing the parameters such as ignition timing, fuel injection timing and cycles, fuel pressure, throttle input maps, torque limiting map, turbo boost etc. he is doing this business /service for 20 years remapping ecu's im sure he knows how to do his job but the problem is i don't know what to ask him What would you guys ask him? Edited October 29, 2018 by QiQiDude Link to post Share on other sites More sharing options...
Kb27 Supersonic October 29, 2018 Share October 29, 2018 There's no free lunch. Power comes from fuel. You want more power, you consume more fuel. 1 Link to post Share on other sites More sharing options...
Saablover 2nd Gear October 29, 2018 Share October 29, 2018 So wait I cant go back and ask him to finetune the remap? Like more mpg for mayby less power? should i ask him to finetune all the things that ishiwgao said like changing the parameters such as ignition timing, fuel injection timing and cycles, fuel pressure, throttle input maps, torque limiting map, turbo boost etc. he is doing this business /service for 20 years remapping ecu's im sure he knows how to do his job but the problem is i don't know what to ask him What would you guys ask him? Then why you want to remap the ECU in the first place?? Should have leave it as stock if you want less power and more mpg isn't it?? Link to post Share on other sites More sharing options...
Watwheels Supersonic October 29, 2018 Share October 29, 2018 I believe the root of the issue lies with the engine. Nothing to do with the tuning. Usually for diesel engine the most common issue is with the high pressure fuel pump, the fuel rail and fuel injectors. Have all these items overhauled and cleaned before you do your tuning. Link to post Share on other sites More sharing options...
Ishiwgao 3rd Gear October 29, 2018 Share October 29, 2018 So wait I cant go back and ask him to finetune the remap? Like more mpg for mayby less power? should i ask him to finetune all the things that ishiwgao said like changing the parameters such as ignition timing, fuel injection timing and cycles, fuel pressure, throttle input maps, torque limiting map, turbo boost etc. he is doing this business /service for 20 years remapping ecu's im sure he knows how to do his job but the problem is i don't know what to ask him What would you guys ask him? you should be able to ask him to fine tune the remap, but it's gonna cost you more money. also, if you dont have a deep understanding of ecu remapping, i suggest you don't act smart and ask your tuner about ignition timing, fuel injection etc. it'll only make you look like a fool in front of him, and considering he's done this work for 20 years, he might just become mad at you. as what bro Kb27 said, there is no free lunch. you wanted more power, you get less mpg. since you asked the tuner to push it to the limits, this is your result. you can probably ask him to tune it down a bit to get more mpg, but the result may not be as you expect. it may not even go back to normal (ie, before the tuning). ecu remapping is a complicated business, where big companies spent much money on. one guy/a few guys are not going to be able to do what thousands of people have done. hard truth, sorry to say. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear October 29, 2018 Share October 29, 2018 TS.. Change Car Link to post Share on other sites More sharing options...
QiQiDude Clutched October 29, 2018 Author Share October 29, 2018 Ok Thanks I will ask him to tune down or if he knows what he is doing, leave up to him He can also do eco tune where its more mpg than anything Considering that as Well if the rest fails The car only got 40000km on it its still looking and driving like new No need for new car Link to post Share on other sites More sharing options...
t0y0ta Supercharged October 30, 2018 Share October 30, 2018 Hello, i have a little problem after i did a stage 1 ecu remap my mpg has decreased significantly when driving in town i can see the km range drop every 5 - 10 seconds by 1 km example whan i start up the car i have 250km left on fuel and after mayby 5km of driving it dropped to 210,while driving very normal when driving on the highway and using cruise control it comsumes fuel normally (or even better?) does anyone knows what the problem is? its a bmw 520d - year 2010- manual - 163hp version i have asked the tuner to just push the engine to it's limits without dangering the car components i did not ask him anything about fuel efficiency could it be that he remapped the engine so i have non stop torque at the low rpm's (like 0 - 2000 rpm) if so, would lowering the torque from 0 - 2000 rpm will get me a better fuel efficiency? i have added a picture, these are the results of the remap thank you in advance carr.png You are quite a funny and innocent lamb. You expect to tune up the car big time and maybe save more fuel? If there was such a good way, BMW would have done it for you already. Welcome to the real world. Link to post Share on other sites More sharing options...
Raychay 5th Gear October 30, 2018 Share October 30, 2018 When you go to a tuner, you must tell him what you want. Some ask for more torque for better drivability. Some ask for better fuel efficiency. In your case, you got what you wanted when you told him to just push it to it's limit which means maximum horsepower. 1 Link to post Share on other sites More sharing options...
QiQiDude Clutched October 30, 2018 Author Share October 30, 2018 (edited) Yes it was totally my mistakeNo other to blameI hope he can balance all the things that needed to be balanced so i can get the best of both worlds edit: just to be sure, im not screwed right? i mean, it's ok for me if i don't get the original mpg (but also not too far off the original mpg) it's not like im stuck in this situation i hope? thank you Edited October 30, 2018 by QiQiDude Link to post Share on other sites More sharing options...
Jozy Clutched October 31, 2018 Share October 31, 2018 you drive 520d and you still complain about fuel MPG lol i am sure it is just your imagination about the MPG. it should be the same as before. just that after your remapping you now pay more attention and start to tell yourself things. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 31, 2018 Share October 31, 2018 (edited) Ppl who does ecu remapping but don't bother to do some reading and expect their car to perform to their expectations. The so called engine tuning or ecu remapping, (assuming there's no hardware changes done on your engine) isn't going to give you a "kick" in your back or will give you excellent fuel economy. Anyway it don't make sense if after tuning your car's engine is going to give better fuel economy and better performance at the same time. You see gains after tuning because the factory tune is to meet emission standards, fuel economy and engine reliability. Your engine's potential is held back for that 3 reasons. After the engine's potential has been "unlocked" the tuner will do the engine tuning by adjusting the mapping parameters. So what exactly does the tuner do? I use the torque curve to explain. It's easier that way. This is what he will do. Adjust the torque curve that originally looks like a "hill" and change it to look like a "plateau". Adjust the "plateau" to stretch as far as possible. So that you will have peak torque in almost every engine rpm. I randomly took this pic online and modify in black to show as an example. This is why they call it ecu remapping. If you have not done any significant engine modification before/after your engine tuning your fuel economy should not change drastically. That's why I say in my first post it has nothing to do with the tuning and the issue lies with your engine. Most likely the diesel delivery system. For a turbo diesel engine its performance and fuel economy largely depends on its fuel delivery system. If it's clogged with carbon or the seal kit for the high pressure fuel pump needs to be replaced you will see your engine performance and mpg suffer. Simple as that. Edited October 31, 2018 by Watwheels ↡ Advertisement 2 Link to post Share on other sites More sharing options...
[Official] 2024 8th Generation BMW 5 Series (G60)
Is It Really Cheaper To own An EV Versus A Gas Car?
2021 2nd Generation BMW 4 Series (G22 / G26)
