  • 1
  • Search this thread
  • Reply to this topic
18 replies to this topic | 0 praises
#1
Posted 13 November 2015 - 09:21 PM
CeramicPROSingapore
  • THREAD STARTER
  • CeramicPROSingapore
    Sponsor
    Author Image
    18
PROVEN TECHNOLOGY, FORMULATED FOR SPECIFIC APPLICATIONS
SEE THE LINEUP OF CERAMIC PRO OFFERS PRODUCTS BASED ON THE SAME PROVEN NANO-TECHNOLOGY
Ceramic PRO Full Range of Products for Automotive Industry
Ceramic Pro products are all based on the same proven nano-ceramic coating technology. For the best experience and enhanced performance, each product variation is specially formulated for a given application. Learn what each Ceramic Pro formula has to offer.
Edited by CeramicPROSingapore, 21 December 2018 - 12:38 PM.
Ceramic PRO Singapore
W - ceramicpro.com.sg
E - info@ceramicpro.com.sg
F - facebook.com/CeramicPROSG/
#2
Posted 13 November 2015 - 09:30 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Introducing Ceramic PRO 9H -
Ceramic Pro is the number one nano-ceramic coating for paint protection. We have various formulas for specialized used when coating paint. These coatings are specially formulated depending if they are going to be used as a base coat, top gloss coat
post-115615-0-33102200-1446476096.jpgpost-115615-0-48755700-1446476096.jpg post-115615-0-57535400-1446477443_thumb.post-115615-0-39399700-1446477444_thumb.post-115615-0-95923700-1446476176_thumb.
Ceramic PRO 9H is a Permanent Nano-Ceramic Protective Paint Coating.
Ceramic Pro 9H forms a permanent bond with the surface and will not wash off or break down. Ceramic Pro 9H can only be removed by abrasion. It is a highly durable protective coating that protects your paintwork from damaging contaminants. 9H can be applied in multiple layers which means the thickness of the coating can be increased with additional layers allowing a thicker/harder coating with improved scratch resistance.
  • Scratch Resistance (Above 9H)
  • Super Hydrophobic Effect
  • Weather & UV Resistance
  • Thermal Resistance (up to 1200°C)
  • Anti-Graffiti
  • Advanced Chemical Resistance
  • Oxidation & Corrosion Resistant
  • High Gloss Finish
Ceramic PRO 9H can only be applied by Approved Applicators with certifications.
Attached File  Ceramic PRO 9H REACH-2016.pdf   283.41KB   24 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:09 PM.
#3
Posted 13 November 2015 - 09:39 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO LIGHT
Ceramic PRO LIGHT is a Nano-Ceramic Protective Paint Coating with durability of up to 24 months.
Ceramic PRO LIGHT is a protective coating with a durability of up to 24 months that features a High Gloss finish, superior Super Hydrophobic Effect, Chemical Resistance, UV Resistance, Thermal Resistance and Anti-Graffiti.
Both the Super Hydrophobic and Anti-Graffiti effect combined mean the surface coated with Light will stay cleaner for longer as dirt and grime will not stick to the surface and the super hydrophobic effect of the coating will cause water to bead up and roll of the surface with any dirt and grime.
The unique formulation of Light enables it to be layered up to 2 times for even more gloss and protection, for best results Ceramic PRO LIGHT can be applied over Ceramic Pro 9H to increase gloss and super hydrophobic effect.
Ceramic PRO LIGHT can only be applied by Approved Applicators.
  • Durability up to 24 months
  • High Gloss Finish
  • Anti-Graffiti
Ceramic PRO can only be applied by Approved Applicators with certifications.
Edited by CeramicPROSingapore, 16 November 2018 - 07:10 PM.
#4
Posted 13 November 2015 - 09:46 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO Rain is a Super Hydrophobic Coating for Glasses.
Ceramic PRO Rain is a coating specifically designed for glass with excellent durability without affecting the motion of the front wiper blades, the super hydrophobic effect of the coating means water will simply bead up and run off the glass whilst you are driving.
Unprotected glass can be a hazard in the rain as water can stick and sheet over the windows decreasing visibility and become a safety hazard, by having Ceramic Pro Rain on all windows this will increase visibility by repelling water and allowing it to bead up and roll straight off the glass, this will also keep the glass cleaner for longer as dirt and grime will no longer stick.
Ceramic PRO RAIN can only be applied by Approved Applicators.
  • Excellent Durability
  • Super Hydrophobic Effect – 140 degree
  • Excellent Wear Resistance
  • Keeps Glass Cleaner
  • Allows Water to Roll off Glass
Ceramic PRO RAIN can only be applied by Approved Applicators with certifications.
Ceramic PRO has been officially tested by “SGS” – www.sgs.com SGS is the world’s leading inspection, verification, testing and Certification Company
Test report - Ceramic Pro Rain REACH 2016
Attached File  Ceramic PRO Rain REACH-2016.pdf   283.31KB   15 downloads
#5
Posted 13 November 2015 - 09:54 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO Plastic is a Unique Coating for Plastic and Rubber Surfaces.
post-115615-0-82106000-1446479073.jpg post-115615-0-36946800-1446479074.jpgpost-115615-0-74380800-1446479143_thumb.
post-115615-0-20035300-1446730455_thumb.
Ceramic PRO Plastic is a unique coating for plastic and rubber surfaces, suitable for both interior and exterior use. Plastic and rubber surfaces coated with Ceramic Pro Plastic will feature a super hydrophobic effect with excellent wear resistance.
The coating will add a moderate sheen to the substrate making it a great permanent dressing for both exterior and interior plastics whether they are new or need restoring.
  • Easy to Clean
  • UV Resistance
  • Superior Wear Resistance
  • Moderate Sheen
Ceramic PRO PLASTIC can only be applied by Approved Applicators with certifications.
Test report - Ceramic Pro Plastic REACH 2016
Attached File  Ceramic PRO Plastic REACH-2016.pdf   283.34KB   9 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:11 PM.
#6
Posted 13 November 2015 - 10:01 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO LEATHER is a true Protective Coating for all Leather Surfaces..
 post-115615-0-06574400-1446532909_thumb.
Ceramic PRO Leather is a true protective coating for all leather surfaces. Leather surfaces coating with Ceramic PRO Leather will stay cleaner for longer reducing dirt and grime from becoming ingrained in the leather substrate.
The Leather coating also features a super hydrophobic effect so that any liquid spills will simply bead up on the surface and can be easily wiped away without affected the leather substrate. The UV Resistance of the coating will help reduce the ageing of the leather from uv damage and keep the leather soft whilst still keeping the factory look and feel.
Ceramic PRO Leather can only be applied by Approved Applicators.
  • Easy to Clean
  • UV Resistance
  • Keeps Leather Soft
  • Factory Look & Feel
Ceramic PRO LEATHER can only be applied by Approved Applicators with certifications.
Test report - Ceramic Pro Leather REACH 2016
Attached File  Ceramic PRO Leather REACH-2016.pdf   283.4KB   11 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:19 PM.
#7
Posted 13 November 2015 - 10:08 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO WHEEL & CALIPER
Ceramic PRO WHEEL & CALIPER is a protective coating for all Rims and calipers. Surfaces coating with Ceramic PRO WHEEL & CALIPER will stay cleaner for longer reducing brake dust, road tar from sticking on the rims, facilitating an easy to clean surface.
Ceramic Pro Wheel and Caliper can only be applied by Approved Applicators.
  • 9H Permanent Coating
  • Anti Graffiti & Anti Finger-Print
  • Xanthocromia Proof
  • Super Chemical resistance
  • UV & Thermal Resistance
  • High Gloss Finishing
Ceramic PRO WHEEL & CALIPER can only be applied by Approved Applicators with certifications.
Test report - Ceramic Pro Wheel & Caliper REACH 2016
Attached File  Ceramic PRO Wheel&Caliper REACH-2016.pdf   284.1KB   10 downloads
#8
Posted 13 November 2015 - 10:20 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO TEXTILE is a Super Hydrophobic Protective Textile Coating..
post-115615-0-63549700-1446534707_thumb.post-115615-0-81973200-1446534712_thumb.
Ceramic PRO TEXTILE comes from the high-tech industry of the photoelectron semiconductor assembly which is reliable and an inorganic compound. Ceramic PRO TEXTILE dramatically reduces the surface energy of textile or suede, so that when liquids come into contact with it, they form beads and simply roll off while keeping the textile substrate completely dry. This enables the fabric, suede and tissue surface to be free from the water/dust and all other liquids, without affecting the look or feel.
  • Super Hydrophobic Effect – 140degree
  • Repels Spills & Stains
  • Keeps Fibres Clean
Test report - Ceramic Pro Textile REACH 2016
Attached File  Ceramic PRO Textile REACH-2016.pdf   298.25KB   8 downloads
#9
Posted 13 November 2015 - 10:42 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO SPORT is a Maintenance Coating for 9H and LIGHT.
Ceramic Pro SPORT is a maintenance coating for Ceramic Pro 9H/LIGHT, the unique formulation of Sport is designed to restore the super-hydrophobic effect of 9H if compromised, the Sport maintenance coating is also suitable if hard water is an issue which can cause water spots, after the vehicle has been washed, Sport is applied to the lightly damp drying towel and wiped on the panel whilst drying, adding even further hydrophobic effect, gloss, sleekness and reducing any possibility of water spotting from hard water or rain water.
  • Easy to Use
  • Adds Further Hydrophobic Effect
  • Prevents Water Spotting
  • Improves Coating Characteristics
Dry Surface
Hard Water on Surface
Dried up
Area with SPORT Reduces Water Spots Drastically
Test report - Ceramic Pro Sport REACH 2016
Attached File  Ceramic PRO SPORT REACH-2016.pdf   298.22KB   16 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:21 PM.
#10
Posted 13 November 2015 - 10:50 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO TAG is an effective air purification, anti mold, anti-bacteria solution.
Ceramic PRO TAG is an air purification, anti mold, anti-bacteria and anti-virus solution with excellent weather ability. Ceramic Pro TAG is a Ti02 Photo-catalytic self-cleaning solution, meaning surfaces coated with titanium dioxide (TiO2) when in a anatase form are exposed to an ultraviolet light source such as the sun the coating’s oxidation property decomposes organic substances such as microbes or bacteria on the surface, combined with nano-Ag particles, the protection can be extended to the area without ultraviolet light to offer the best 24 hour protection.
  • Air Purification Solution
  • Anti Mould, Bacteria & Virus
  • Organic Decomposition Feature
  • Excellent Weather-ability
  • Improved Binding Strength
  • Ambient Temperature Curing
  • Easy to Use
Test report - Ceramic Pro TAG REACH 2016
Attached File  Ceramic PRO TAG REACH-2016.pdf   283.29KB   9 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:22 PM.
#11
Posted 13 November 2015 - 11:02 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO Nano Primer Polish is a non-abrasive primer and cleaner polish.
Ceramic PRO Nano Primer Polish is a non-abrasive polish that prepares the surface prior to applying Ceramic Pro paint coatings. Ceramic PRO Nano-Polish will refine and clean the paint work to ensure Ceramic Pro paint coatings can gain maximum adhesion, whilst removing any minor imperfections and increasing gloss levels of the paint work before they are locked in with a Ceramic Pro coating.
  • Prepares Surface for Coatings
  • Removes Minor Imperfections
  • Increases Gloss Level
  • Easy to Use
  • Non Abrasive
  • Silcon Free
Test report - Ceramic Pro Nano-Polish REACH 2016
Attached File  Ceramic PRO Nano-Polish REACH-2016.pdf   283.28KB   4 downloads
Edited by CeramicPROSingapore, 21 December 2018 - 12:32 PM.
#12
Posted 19 September 2018 - 09:18 AM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic PRO Air protects air vehicles from corrosion and icing on high altitudes.
THE NEW AGE OF PROTECTION IN AVIATION
Ceramic Pro coatings developed by NanoShine Group are transparent liquids containing nano-ceramic components.
Being applied to a surface, the product crystallizes from contact with air, forming an extremely thin protective layer.
A special matrix structure of the coating increases its hardness and resistance to scratches, solvents, acids, alkali, UV and oxidation.
Ceramic Pro Air improves aerodynamic properties of coated objects which has been proven by tests in wind tunnel. All the declared properties of the product including corrosion and aggressive chemicals resistances and hardness of the coating have been proven by certificates from SGS laboratory.
Benefits:
  • Durable and reliable surface protection
  • Hardness of 9H provides high wear resistance
  • Guarantees strong dirt and water repelling effect
  • Effectively permeates and protects the surface of various materials
  • High chemical resistance
  • Prevents oxidation and corrosion
  • Provides protection against extreme temperatures
  • High quality protection
  • Great weatherability; prevents aging surface damage
  • “Anti-graffiti” property preserves perfect appearance and provides easy-to-clean ability
  • Fluorine-free: safe for human health and environment
  • High resistance to salts
  • Easy washing and maintenance
Ceramic PRO AIR can only be applied by Approved Applicators with certifications.
Test report - Ceramic Pro Air REACH 2016
Attached File  Ceramic PRO AIR.pdf   459.05KB   12 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:26 PM.
#13
Posted 21 September 2018 - 04:24 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic Pro Marine protects the surface of any vessel above and below the waterline.
Benefits:
  • Permanent Protection
  • Easy to Maintain
  • Anti-Fouling and Anti-Graffiti
  • Thermal resistance from -50 °C to 1200 °C
  • Resistance to corrosion and oxidation
  • UV Protection
  • Perfect Gloss
  • Chemical Resistance
  • Passive air cavity effect
  • Low volatile components
  • Fluorine Free
  • Eco-Friendly
Harsh exploitation conditions are a well-known issue for the yachts and boats owners. Creating a protective barrier, Ceramic Pro prevents oxidation of treated surfaces and growth of sea organisms and algae on the Bottom.
The existing methods of cleaning vessels are expensive and are not safe for environment. Ceramic Pro makes treated surfaces water-repellent, reducing the influence of substances contained in sea water. At the same time the process of cleaning is significantly simplified: no need to pull the ship out of the water or use strong chemicals and solvents.
Ceramic PRO has been officially tested by “SGS” – www.sgs.com SGS is the world’s leading inspection, verification, testing and Certification Company.
Attached File  Ceramic PRO Marine REACH-2016.pdf   283.4KB   9 downloads
Verification of genuine of certification can be done with info@ceramicpro.com.sg with the following details:
  1. Location and Company where the company claims they use Ceramic PRO Products
  2. Personal making the claim
  3. An Image of the Certification
post-115615-0-49391300-1446476238_thumb.
Edited by CeramicPROSingapore, 26 September 2018 - 03:27 PM.
#14
Posted 24 September 2018 - 11:49 AM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic Pro IronX is a Multipurpose Cleaner for Complex Fouling.
Ironx is one of the best car cleaning product on the market for metal surfaces including the wheels, calipers, wheel disks and exhaust systems.
It can be used for the treatment of:
  • chrome elements
  • caliper
  • car body
  • wheel disks
  • exhaust systems
  • yacht
  • helicopters
  • various metallic painted surfaces
Benefits:
  • Easy to use
  • Super Detergent
  • Quick Cleaning
  • Environment-Friendly
  • Time- and Cost-Efficient
Cleaning with Ceramic Pro IronX does not Require Special Skills and Training. It effectively removes metal dust from wheel disks.
Ceramic PRO has been officially tested by “SGS” – www.sgs.com SGS is the world’s leading inspection, verification, testing, and Certification Company.
Test report - Ceramic Pro IronX REACH 2016
Attached File  Ceramic PRO IronX REACH-2016.pdf   283.84KB   9 downloads
#15
Posted 25 September 2018 - 09:57 AM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic Pro PPF&Vinyl & Top Coat is a Permanent Nano-ceramic Coating for Paint Protection Film and Vinyl Wrap.
The perfect protection of Ceramic Pro is available for vehicles and other surfaces covered with plastic wraps and vinyls. The new PPF&Vinyl system is perfect for this task and addresses to the very specific needs of such surfaces, prolonging the lifetime and improving the appearance.
It is used for the treatment of:
  • Car wraps
  • Billboards
Benefits:
  • Anti-Graffiti
  • Reduced Orange Peel
  • Less Maintenance
  • Extended Lifespan
  • High Gloss Finish
Ceramic Pro PPF & Vinyl was designed as a specialized protective coating for polyurethane films and vinyls. It protects films from contamination, weathering and orange peel effect, providing much easier cleaning of the surface.
The complete Ceramic Pro PPF & Vinyl protection program involves using a base coat and a top coat. Ceramic Pro PPF & Vinyl is the base coat. After base coat application coating layered with PPF & Vinyl Top Coat as a finish. The final layer is slightly softer than the main base protection coat. This allows for higher gloss and a deep wet look.
Test report - Ceramic Pro PPF&Vinyl REACH 2016
Attached File  Ceramic Pro PPF & VINYL TOP COAT.pdf   459.54KB   12 downloads
Attached File  Ceramic Pro PPF & VINYL.pdf   459.57KB   9 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 08:04 PM.
#16
Posted 26 September 2018 - 03:48 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic Pro Shampoo is a highly concentrated shampoo.
Ceramic Pro Car Wash Shampoo is a luxurious pH neutral rich gloss enhancing wash shampoo to care for your Ceramic Pro Paint Protection Coating.
The specially formulated wash shampoo is high foaming and lubricating and emulsifies and dissolves the toughest dirt and road grime to lift it away from the paint surface to ensure a swirl and scratch free wash.
We recommend that you always wash your car with our unique Microfiber Sponge and dry with our Microfiber Chamois to avoid swirl marks or damage during the wash process.
  • Body wash car
  • Disc cleaning
  • Engine cleaning
  • Domestic use
Benefits:
  1. Super Detergent for Fast Cleaning of Surfaces
  2. Excellently Removes Fats, Oils and other Contamination
  3. Highly Concentrated Detergent
  4. Environment-Friendly Formula
  5. Wide Application Range
Application method
Dilute with water as recommended:
  • For a very dirty surface (e.g. motor) 1:0-2
  • For medium oil foulness (e.g. wheel rims) 1:3-10
  • Car body wash 1:10-40
Test report - Ceramic Pro Shampoo REACH 2016
Attached File  Ceramic PRO Shampoo REACH-2016.pdf   283.34KB   8 downloads
#17
Posted 01 October 2018 - 10:39 AM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic Pro Strong is a Multifunctional Protective Nanoceramic Coating for Industrial Use!
Ceramic PRO Strong is clear and transparent as water. It becomes a hard film as glass to permanently protect the foundation. With 3D Matrix technology, Ceramic PRO STRONG offers above 9H glass coating, excellent scratch resistance and long life. Ceramic PRO Strong creates a very good barrier to chemical bonding to the foundation, which provides an “easy-to-clean surface to prevent water, dirt, grease and other stains. The protected material can be used multiple times without reapplying. Ceramic PRO Strong is resistant to solvents, acids, alkalis and chemicals, it is offered as composite coating and requires no mixing with other substances. At room temperature, it is completely cured within 2 hours and tack-free after 7 days.
Strong Ceramic PRO is easy to use and has various application methods, you can choose between dip, spray and brush on to achieve the desired result.
  • Yachts and boats
  • Maritimes
  • Constructions
  • Aircraft
  • Pools
  • Metal
  • Natural and artifical materials
  • Ceramincs/ Bathrooms/ Toilers
  • Factory lines and heavy industry
  • Oil industry
  • Architecture monuments
  • Art objects
Benefits:
  1. Scratch Resistance (Above 9H)
  2. Super Hydrophobic Effect
  3. Weather & UV Resistance
  4. Thermal Resistance (up to 2200°C)
  5. Anti-Graffiti
  6. Advanced Chemical Resistance
  7. Oxidation & Corrosion Resistant
  8. Wind Drag reduction
post-165681-0-12967500-1537319660_thumb.
Test report - Ceramic Pro Strong REACH 2016
Attached File  Ceramic PRO STRONG REACH-2016.pdf   283.37KB   11 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:36 PM.
#18
Posted 04 October 2018 - 09:40 AM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic Pro BRAVO is the permanent protective nano-ceramic coating for boats and yacht owners.
It is a 100% green and safe permanent Nano-Ceramic coating that features a High Gloss finish, unmatched Non-Stick Effect, Scratch Resistance, Chemical Resistance, UV Resistance, Thermal Protection and Anti-Graffiti properties. Ceramic Pro’s self-cleaning properties create a non-stick surface that allows water to effortless release dried on stains quickly. Ceramic Pro Bravo forms a permanent bond to surfaces. Which means this product will not wash away or break down and can only be removed by abrasion, making it a highly durable protective coating for your stainless appliances, chrome parts, deck and interior parts, shower glass, sinks, indoor and outdoor furniture. Ceramic Pro Bravo - 9H Durable permanent coating for metal and plastic protection.
  • Painted surface
  • Chrome parts
  • Deck parts
  • Boat interior
  • Surfaces above waterline
Benefits:
1. Oxidation and Corrosion Resistance
Ceramic Pro protects paint and metal from coming into contact with water and oxygen preventing oxidation and corrosion. The ASTM B117 Salt Spray Corrosion Test provides a controlled corrosive environment which has been utilized to produce relative corrosion resistance information for specimens of metals and coated metals exposed in a given test chamber. The chemical tests conducted by SGS and internally are: 5% salt spray for 350 hours with results of no visible damage, as well as 5% salt spray for 5000 hours with no visible damage (internal test).
2. Chemical Resistance
The coating has 100% resistance against damaging contaminants and harsh chemicals. Once cured, the only way to remove the coating is through heavy abrasion. The chemicals tested and conducted by SGS include JIS K5400 Alkali, Acids and Salt. This test method identifies how well the coating resists sodium carbonate, sulfuric acid, and sodium chloride despite heavy exposure. Result: 5% Na2CO3 for 24 hours: No visible damage, 5% H2SO4 for 24 hours: No visible damage, and 5% NaCl for 96 hours: No visible damage.
3. Hardness
Pencil test conducted by SGS (JIS K5400) a coated panel is placed on a firm horizontal surface. The pencil is held firmly against the film at a 45° angle (pointed away from the operator) and pushed away from the operator in a 0.256-inch strokes. On a scale ranging from 6B (softest) to 9H (hardest), Strong has been tested and classified above 9H. impact In the Impact resistance testing conducted by SGS (ASTM D2794 test) coatings attached to substrates are subjected to damaging impacts during the manufacture of articles and their use in service. This test method for impact resistance is useful in predicting the performance of organic coatings and their ability to resist cracking caused by impacts. Result: 80/80 inch pounds.
4. Nontoxic
Ceramic Pro is a non-toxic product and the tests that have been conducted by SGS are ASTM F963-08 (4,3,5) Heavy Metal Lead, Antimony, Arsenic, Barium, Cadmium, Chromium, Mercury, Selenium. Result: Not detected in all tested substances.
ECHA REACH test Ceramic Pro has been tested against 144 substances of very high concern (SVHC) screening. SVHC candidate list based on the publication by European Chemicals Agency (ECHA) on June 2013. Result: Not detected in all tested substances.
VOC Ceramic Pro Strong is VOC compliant at 5.2 g/liter.
5. Flexibility
Ceramic Pro has proven to be a perfect coating for surfaces that are exposed to expansion and deformation. The test conducted by the SGS is the Mandrel Bend Test (ASTM D522 test). This test is useful in evaluating the flexibility of coatings on substrates. Result: 0 mm of coating loss at 180° rotation.
6. Adhesion
The test conducted by SGS is the ASTM D3359 Adhesion test. This test covers procedures for assessing the adhesion of coating films to metallic substrates by applying and removing pressure-sensitive tape over cuts made in the film. Result: 5B (No coating loss when using strongest tape).
7. UV Protection
The UV protection keeps paint, rubber and plastic from aging. The tests conducted by SGS; ASTM G154-06 and ASTM D2244 determine color changes on surfaces exposed to UV rays. Result: No color change
8. Weight
A cured layer of Strong weighs between 0.2 to 1 gram/square foot depending on porousness of the surface.
9. Hydrophobisity
A surface level of hydrophobia is dependent on the water contact angle of the surface. The higher angle the less dirt or liquid will attach to the surface. Strong 2.0 has a contact angle of at least 110 degrees.
10. Gloss and Color Change
The coating does not always increase gloss. It preserves the shine of a surface at the time of treatment. Color and shine depend on the surface being treated.
Test report - Ceramic Pro BRAVO
Attached File  Ceramic Pro Bravo REACH 2018.pdf   395.54KB   32 downloads
Edited by CeramicPROSingapore, 16 November 2018 - 07:37 PM.
#19
Posted 16 November 2018 - 07:24 PM
CeramicPROSingapore
  • THREAD STARTER
    Sponsor
    Author Image
    18
Ceramic Pro Cleaner is used for the treatment for car wash, disc cleaning, engine cleaning or domestic use.
Highlights:
  • Coupling Process before Coating
  • Improves Coating Chemical Bonding
  • Extends Coatings' Lifetime
  • Removes Residues of Buffing Works
  • Time-Saving
  • Cost-Efficient - Low-Cost Surface Cleaning
Cleaning with Ceramic Pro Cleaner does not require special skill or training.
 Test report - Ceramic Pro Cleaner REACH 2016
 Attached File  Ceramic PRO Cleaner REACH-2016.pdf   283.44KB   13 downloads
  • 1
Back to Ceramic PRO  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: ceramicpro, nano-ceramic coating and 2 more...
